Old 07-22-2013, 07:24 AM   #407
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
Okay here is a rule question: USDM Fog Lights which are now available. STX legal? Are they considered C&C? Safety? Or do they count as being from a dealer catalog?
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Old 07-22-2013, 07:35 AM   #408
UncleFester
They are from the Catalog, not the TRD (performance) catalog, so I think you're fine.
Plus, I doubt anyone could argue that fog lights gave you a performance advantage.
UncleFester is offline   Reply With Quote
Old 07-22-2013, 09:16 AM   #409
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Out of curiosity, would a lightweight flywheel and CF driveshaft be STX legal?
I'm going to end up in one of the Street mod classes eventually with the blower, but in the interim I wanted to try out a lightweight driveline.
Old 07-22-2013, 09:42 AM   #410
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
no and no. Not sure if the driveshaft is even SP legal.
celica73 is offline   Reply With Quote
Old 07-22-2013, 09:47 AM   #411
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
It's not.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 07-22-2013, 10:19 AM   #412
Draco-REX
Corner Junkie
Draco-REX's Avatar
Ah well. Wasn't building this for competition anyways.
Old 07-22-2013, 10:41 AM   #413
Robbie
In the slipstream
You could definitely use them under C&C.
Robbie is offline   Reply With Quote
Old 07-22-2013, 11:02 AM   #414
NYR Solo
Drives: Subaru & Mazda
They are a manufacturer option so they are even Stock legal.
NYR Solo is offline   Reply With Quote
Old 07-22-2013, 11:26 PM   #415
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
Originally Posted by dwx View Post
I submitted a letter to create an allowance for oil coolers and radiators in ST, so write in support of it if they publish it.
The radiator rule would follow the SP one, you have to have one which weighs as much and has the same capacity as the stock one. Which isn't hard in our car, the radiator is smaller than most AC condensors.
I submitted a letter as well regarding oil coolers a few months ago. Hopefully they will change the rule. It offers no benefit other than engine longevity.
I frequently run time trials as well as autocross STX.
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
Old 08-02-2013, 09:46 AM   #416
Stevo22
Stevo22's Avatar
Drives: GR86
What is the status of your letter?
Stevo22 is offline   Reply With Quote
Old 08-02-2013, 11:40 AM   #417
Ingen
Drives: Ultramarine FR-S 6MT
So I'm autocrossing on the OEM Bridgestone all-season tires right now, until the stars align and I can afford wheels and tires. I am pretty new to autocross and suspension setups in general,so for now I've just gone at this with totally stock setup. However, I'm getting some wear on the outside edge of my front tire tread, which I know is b/c the tread is rolling over somewhat and my terrible driving is causing this segment to rub against the ground.
I want to avoid that (no crap, really? :P ) so I am looking at getting an alignment done with camber bolts. My question for you guys is, how far should I go with the camber to maintain daily-driver status (i.e. not waste my tires in 5000 miles on camber wear) while still protecting the tire from the wear I have been experiencing? Ideally, this adjustment will remain legal for STX, and if it doesn't I might just supercharge the damn car
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 08-02-2013, 12:00 PM   #418
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
What kind of tire pressure are you running? Street tires like those I will normally fill to about 40 PSI and work my way down. I don't think that the crash bolts add a large amount of camber, under 2 degrees for sure. Max them out and run 0 toe in the front and 1/32 toe in at the back. Next event with that setup start at the high pressure and work down till you find a balance and tire roll that is right.
I have ran about 2 degrees in my WRX on 380 tread wears for about 25k miles with a bit of toe out in the front too. Depends alot on the surface your region runs on as well with tire wear.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 08-02-2013, 12:05 PM   #419
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Camber bolts are definitely STX legal and should give you somewhere between -1 and -1.5 degrees of negative camber in the front. Go ahead and max out what the camber bolts will give you. Even at -1.5 it won't produce a ton of camber wear for daily driving. I've been daily driving/autocrossing with front camber bolts for over a year and the majority of my tire wear is still on the outside edge of the tire.
SubiePig's advice on tire pressure is very good and should also help with easing the amount of wear the outside edge of your tires get.
jprice130 is offline   Reply With Quote
Old 08-24-2013, 01:35 PM   #420
Turbo Den
Drives: FRS, IS300, 911sc
Question: with a change to 4.7 final drive, which scca class would a FRS goes to? SM?
Turbo Den is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
