#407 |
Drives: Firestorm FR-S
Okay here is a rule question: USDM Fog Lights which are now available. STX legal? Are they considered C&C? Safety? Or do they count as being from a dealer catalog?
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
#408 | |
Plus, I doubt anyone could argue that fog lights gave you a performance advantage. |
#409 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Out of curiosity, would a lightweight flywheel and CF driveshaft be STX legal?
I'm going to end up in one of the Street mod classes eventually with the blower, but in the interim I wanted to try out a lightweight driveline. |
#410 |
no and no. Not sure if the driveshaft is even SP legal.
#411 |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
It's not.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
#412 |
Corner Junkie
Ah well. Wasn't building this for competition anyways.
#413 |
In the slipstream
#414 |
Drives: Subaru & Mazda
They are a manufacturer option so they are even Stock legal.
#415 | |
Troll Level: Expert
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
I frequently run time trials as well as autocross STX.
Nick K.
NASA ST5/TT5 #130 Southeast Region |
#416 | |
Drives: GR86
#417 |
Drives: Ultramarine FR-S 6MT
So I'm autocrossing on the OEM Bridgestone all-season tires right now, until the stars align and I can afford wheels and tires. I am pretty new to autocross and suspension setups in general,so for now I've just gone at this with totally stock setup. However, I'm getting some wear on the outside edge of my front tire tread, which I know is b/c the tread is rolling over somewhat and my terrible driving is causing this segment to rub against the ground.
I want to avoid that (no crap, really? :P ) so I am looking at getting an alignment done with camber bolts. My question for you guys is, how far should I go with the camber to maintain daily-driver status (i.e. not waste my tires in 5000 miles on camber wear) while still protecting the tire from the wear I have been experiencing? Ideally, this adjustment will remain legal for STX, and if it doesn't I might just supercharge the damn car
| The Following User Says Thank You to Ingen For This Useful Post: | GeorgeJFrick (01-24-2014) |
#418 | |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I have ran about 2 degrees in my WRX on 380 tread wears for about 25k miles with a bit of toe out in the front too. Depends alot on the surface your region runs on as well with tire wear.
![]() Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) |
| The Following User Says Thank You to SubiePig For This Useful Post: | GeorgeJFrick (01-24-2014) |
#419 | |
AutoX Nut
Drives: 2020 Toyota Supra
SubiePig's advice on tire pressure is very good and should also help with easing the amount of wear the outside edge of your tires get. |
#420 |
Drives: FRS, IS300, 911sc
Question: with a change to 4.7 final drive, which scca class would a FRS goes to? SM?
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
