Old 04-14-2017, 12:47 PM   #407
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Once I have all the LS swap gear in hand, I'll start that part of the project. Engine should be here in the next month or so, I don't have the transmission yet either, still need the hydraulics and motec. Better pick a clutch soon, I'll probably go with a Clutch Masters unit.
I have lots to do though.
I'm going to install the 8.8 diff first (I have the diff but have not yet received the axles, hubs or drive shaft.
Then the suspension and brakes and wheels.. I have everything but the sway bars and MCS coil overs (which I expect any day now.)
That's a lot of work to get dialed so I'll be busy with that for a while.
Pretty much waiting on parts ...that's my hold up.
ILLSMOQ is offline   Reply With Quote
Old 04-14-2017, 04:52 PM   #408
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Originally Posted by DustinS View Post
Also. Hood pins and trans tunnel wrap came in.
Where do these come from?
IceFyre13th is offline   Reply With Quote
Old 04-14-2017, 04:54 PM   #409
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Quik-Latch. Same company that makes the little ones for holding the bumper on.
DustinS is offline   Reply With Quote
Old 04-16-2017, 07:52 PM   #410
all4spl
im hoping that those headers fit with no issues. That could make things much cheaper and easier.
all4spl is offline   Reply With Quote
Old 04-17-2017, 09:31 AM   #411
DustinS
DustinS's Avatar
Well I have Wednesday off, and It's suppose to be the only nice day... So hopefully we find out how well the engine fits So then we check how well the header fits in the chassis.
Old 04-17-2017, 09:58 AM   #412
DustinS
DustinS's Avatar
Didn't get a lot done over the weekend unfortunately. Got the engine mounts off, still need to grind down the spot welds, and the long weld at the bottom. Engine bay is filthy again because of the rain/pollen. I really need a garage haha
I also tore into the wiring harness to try and hide the large engine harness at the back of the bay. It's proving to be difficult as I didn't want to cut anything.
Edit: Trying to get the car running asap. Thinking on the clutch master, I think I should be able to just mount the master to the firewall. I will need to cut the threads down a bit and make an adapter. My plan was two nuts the same thread of the master welded to two nuts of the same thread size of the old master so I can use the part that fits the pedal.
My grandpa brought up a good point as we were both staring at the transmission on my Lunch break. What are we doing for hardware bolting the transmission to the engine... Guess I need to do some research on that oops.
Old 04-17-2017, 08:34 PM   #413
Zer0
Drives: 2015 frs
Glad to see you got your transmission delivered. I just ordered my mounts and driveshaft Friday.
Zer0 is offline   Reply With Quote
Old 04-17-2017, 09:38 PM   #414
ILLSMOQ
hahaha! There is that super obvious thing you were missing!
Old 04-18-2017, 10:00 AM   #415
DustinS
DustinS's Avatar
Did a bit more work last night. Got the e85 out of the tank. Drilling the spot welds sucked. I only got one side off of the trans mounts.
Got the old FA20 Engine harness tucked into the cabin. What I giant pain.
Now to try and find where to put the wires...
Old 04-18-2017, 10:29 AM   #416
all4spl
Why did you pull the main Engine harness back through the cabin?
Old 04-18-2017, 10:31 AM   #417
DustinS
DustinS's Avatar
It's not needed (or at least I can't see why it would be) and I didn't want to leave that giant bundle of wire just hanging there. (as it seems is done in all the other swaps I have seen)
Old 04-18-2017, 01:27 PM   #418
all4spl
Oh I gotcha. I forgot your going to use the GM ECU in the engine bay.
Old 04-18-2017, 02:54 PM   #419
DustinS
DustinS's Avatar
So I was looking for the reverse lockout lever, only to find the magnum xl has electronic reverse lockout. Usually tied into the brake pedal. I will probably just wire it up to a switch for now, but later I want to integrate a momentary switch into a hidden button in the top of a shift knob. Push the top of the knob and you can shift into reverse.
I have also decided to just attach the 2.5" flanges to the a 3" merge to get the car up and running for right now. (mostly because I have 2.5" exhaust tubing). I will have my friends shop weld up the 3" from header back down the road.
Old 04-18-2017, 04:11 PM   #420
all4spl
No don't do that. The GM ECU has an input for that. it uses the VSS and everything else so that you cannot shift into reverse when the car is moving.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
