Old 12-13-2015, 04:35 PM   #29
xiayu0320
Drives: 2013 GBS BRZ
Originally Posted by shaynek View Post
happens to me all the time. what i do is unplug oft and then plug it back in to flash.
Thanks, your car can't start also when that error happens to you?
xiayu0320 is offline   Reply With Quote
Old 12-13-2015, 08:51 PM   #30
xiayu0320
Finally I found out the problem today. Voltage was lowered while OFT flashing the file into the ECU. First time flashing shows completed but actually not. Then I tried to start my car, car won't start because file was incomplete and voltage was too low. The voltage was too low when I tried second and third times to flashing the ECU, so OFT shows error. Today I tried to charging the battery and then car started. I flashed stg2 uel 93oct into the ECU and it worked.
Big thanks to @FRSBRZGT86FAN and @steve99 helped me finding the problem out.
Old 12-15-2015, 01:09 PM   #31
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
I never tried to start my car but i may have a bad battery as well
shaynek is offline   Reply With Quote
Old 12-15-2015, 06:55 PM   #32
thambu19
Drives: Scion FRS
If you have used incorrect def file to edit it likely written a corrupt rom to ecu.
Use the oft to write bact the Original File to the ecu the one in the top slot.
if it still wont write try this
Switch off ignition
Remove positive battery terminal
With battery disconnected, depress brake pedal to bleed off and redidual power
Replace battery terminal
Flash your original tune to car on first turn on of ignition
Ie plug in oft turn ignition on go to write , wtite original tune without turning ignition off even if oft asks you to.
After that i think you got big problem, contact the oft guys.
With the time and effort you are putting into the community you need to start charging people . Not kidding, I am serious. We understand that you are passionate but you have saved the A$$ of hundreds of folks here and I am sure they would wish to thank you for it.
I totally suggest setting up a donation account. Again not kidding... If others approve this please like/thank the post and if you get ten likes/thanks then you setup an account
thambu19 is offline   Reply With Quote
error sokol Cars for Sale/Trade 9 12-09-2014 03:22 AM
ECUtek error 37 NickFRS Software Tuning 5 06-29-2014 04:14 PM
Unichip Error Code Ingeberger Engine, Exhaust, Transmission 5 12-29-2013 01:09 PM
Paperwork error Rob_g Scion FR-S / Toyota 86 GT86 General Forum 4 05-24-2012 11:38 PM
Driver error Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 5 07-14-2010 07:25 PM
