View Poll Results: FWD: put bad tires in front or rear
Bad tires in front 22 40.74%
Bad tires in rear 32 59.26%
Voters: 54. You may not vote on this poll
Old 12-09-2015, 03:12 PM   #29
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Again, modern car have ABS & TC to reduce this issue... but food for thought.
Never thought about this that way. I guess this is my first car with electric windows and keyless entry, much less abs and tc... still learning something new err'day
Toyarzee is offline   Reply With Quote
The Following User Says Thank You to Toyarzee For This Useful Post:
ichitaka05 (12-09-2015)
Old 12-09-2015, 03:12 PM   #30
PMPB
Drives: BRZ Sport-tech
I want to further what ichi said.
A lot of people think that front brakes are made bigger than the rear brake because the front handles the bulk of the braking forces. This is partly true, however, I submit that the rear brake is made SMALLER than the front brake, so that in the event of a hard braking maneuver, the front tires are more likely to break traction before the rear tires. Combine that with ABS and the car is able to steer and maintain control even during braking maneuvers that would otherwise cause a spin.
PMPB is offline   Reply With Quote
The Following User Says Thank You to PMPB For This Useful Post:
Old 12-09-2015, 03:14 PM   #31
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I guess I'd probably go with the tirerack consensus now.... :/
Old 12-09-2015, 03:23 PM   #32
All those years I did it wrong (well not to many years with FWD and bad tires) still managed to never have over steer or spin out even in the worst condition and really bad tires.
I guess if your tires are that bad you just learn to drive more carefully. I do sometimes miss the sound of steel belts sticking out and creating that cool swish swish swish swish sound though.
strat61caster (12-09-2015)
Old 12-09-2015, 03:30 PM   #33
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I'm too chicken to drive a car w steel wires sticking out. I've always replaced my tires way before recommended time.
Tcoat (12-09-2015)
Old 12-09-2015, 03:36 PM   #34
I was too poor not to at one point in time. Also even more fun when no two tires on the car are the same size.
Ultramaroon (12-25-2015)
Old 12-09-2015, 03:42 PM   #35
ichitaka05
Site Moderator
ichitaka05's Avatar
Haha, I had no two tires on the car are the same size before. It was temporary thing (3 days), but done that.
Even I was poor, I made sure brakes, tires & fluids were good in the car... even shaving my food budget (which is a big deal for me lol)
Old 12-09-2015, 03:44 PM   #36
Wife and two little kids. My car came a distant last. She had a car that was safe while I drove a shitbox just to get around.
ichitaka05 (12-09-2015), Ultramaroon (12-25-2015)
Old 12-09-2015, 03:45 PM   #37
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Well, my last FWD car made just under 300 lb/ft of torque to the wheels, so it ate front tires at an alarming rate and needed all of the grip it could get.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Tcoat (12-09-2015)
Old 12-09-2015, 03:48 PM   #38
Pretty sure mine made 30. On a good day. With the right weather conditions.
Old 12-09-2015, 03:56 PM   #39
ichitaka05
Site Moderator
ichitaka05's Avatar
Well, I'm still a single man, so I don't have to worry bout wife or kid.
All my money is go into car parts & food lol
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
soulreapersteve (12-11-2015), Tcoat (12-09-2015)
Old 12-09-2015, 04:11 PM   #40
DarkSunrise
DarkSunrise's Avatar
Originally Posted by totopo View Post
How do you plan on catching oversteer in a FWD car? You have to mash gas. What if you don't have space on the outside? what if you aren't expecting it? what if you aren't in a low gear? you are screwed.
If you're on the track in an understeering FWD car, there is no question you want your better tires up front. I've run my GTI like that plenty of times. Yes there is more lift throttle oversteer. Yes there is more grip on corner exit. Yes both are preferable qualities if we're talking about an understeering FWD car on the track. Put the better tires up front.
This is exactly why I said it depends on the circumstances. Would my response change for a driver who was not used to oversteer in a car with no traction control and it was snowing outside on the street? Probably.
2022 BRZ Build
2013 FR-S Build
Old 12-09-2015, 04:11 PM   #41
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by Toyarzee View Post
Forgetting inclement weather for a minute, if you're driving down the freeway and everyone comes to a sudden stop, would you not be more likely to stop safely if you have sufficient traction up front?
Pretty sure this has been answered already, but thanks to physics, your car does not have the same points of momentum front to back. In other words, if you "panic stop," the front tires bite sooner than the rear, and suddenly the front of the car is moving more slowly than the rear. At this point, the car will want to spin since the front is still connected to the rear. By having higher grip at the back, you reduce the likelihood of a spin occurring as there is more resistance to sideways movement in the fresher tires.
Grip is also increased in the front due to more weight usually being over the front axle because of the engine, hence why cornering would be easier with the more worn tires on the front.
It has priests in it?
The Following 2 Users Say Thank You to HunterGreene For This Useful Post:
Tcoat (12-09-2015), Toyarzee (12-09-2015)
Old 12-10-2015, 04:29 AM   #42
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Really, really interesting thread. I feel this was a plot by @stugray.
In which case, I would love to hear his own answer to this as well.
PSA: Don't drive like me (unless you want a bent wheel) mav1178 Tracking / Autocross / HPDE / Drifting 11 07-25-2015 03:37 PM
FS: 245/40/18 Yokohoma S Drive Tires Rabbit86 Canada Classifieds 10 04-24-2015 09:20 AM
OK wheel gurus, wheel are here, now for tires FRSGT86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-12-2013 01:36 AM
TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? No5ki Scion FR-S / Toyota 86 GT86 General Forum 27 01-06-2013 08:30 PM
How to drive your tires to go fast. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-06-2012 03:01 PM
