Old 11-26-2015, 12:45 AM   #29
Hawk77FT
Drives: GTS 86
Ok, quick update.
I have taken it to the dealer, and they replaced the oil with Castrol VMX 80 which supposedly should be good for cold starts and such. To me it sounds like they are trying to mask the problem. I will give it another couple of days and see how it goes, and then call them back if the noise is still there.
Sounds like there is plenty of play in there!
Hmm!
Hawk77FT is offline   Reply With Quote
Old 11-26-2015, 01:06 AM   #30
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I had this same issue with mine.
The dealer replaced the transmission and I never noticed it afterwards. Unfortunately, I can't say for sure if it fixed it because I no longer have the BRZ.
Sent from my Nexus 5X using Tapatalk
Bobblehead is offline   Reply With Quote
Old 11-28-2015, 04:26 PM   #31
FRStock
Drives: 13 FRS
I have the same problem but all stock.
Curious what the outcome is.
FRStock is offline   Reply With Quote
Old 12-02-2015, 02:24 AM   #32
Hawk77FT
Drives: GTS 86
Update: had the transmission oil changed to VMX80 and it seems that the noise is not as obvious however I am afraid that the issue is being masked rather than resolved!
I will wait for another week or tow and see how this is going!
Old 12-09-2015, 10:37 PM   #33
Hawk77FT
Drives: GTS 86
Noise is still there after a week's worth of driving! Damn it!
Old 12-13-2015, 03:58 AM   #34
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
You change your flywheel? Never had an aftermarket flywheel that didn't sound like a cement truck.
Luftwaffel is offline   Reply With Quote
Old 12-17-2015, 12:56 PM   #35
86Tony
Drives: 2015 AOZORA EDITION
Alot of guys have this noise for quite sometime now. So far nothing has failed yet just noise. When i do my clutch i will change the Input bearing too and maybe the input shaft aswell
Sent from my SM-N920W8 using Tapatalk
86Tony is offline   Reply With Quote
Old 12-17-2015, 02:50 PM   #36
Nickosport
Drives: 2015 WRB BRZ Premium
This sounds like flywheel rattle to me.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
Valvetrain chatter on KW SC FRS nlowell Issues | Warranty | Recalls / TSB 4 05-03-2015 12:20 PM
Flywheel Chatter samisons Issues | Warranty | Recalls / TSB 13 12-05-2014 10:30 AM
Drivetrain chatter on cold mornings? jm1681 Issues | Warranty | Recalls / TSB 7 10-24-2014 11:48 AM
Diff chatter when cold? BRZrkr BRZ First-Gen (2012+) — General Topics 1 06-23-2014 10:17 AM
Odd Chatter Noise? Chrisposey Forced Induction 5 05-05-2014 10:37 PM
