#29 | ||
Drives: Asphalt frs
#30 |
Drives: 2JZ FRS
ive been through 3 stock transmissions. once you make traction its over. ranging from 400-600hp
| The Following User Says Thank You to spitfire481 For This Useful Post: | SoCal80six (10-08-2015) |
#31 |
Drives: Asphalt frs
#32 |
Drives: Asphalt frs
#33 |
Drives: 2JZ FRS
399whp/355tq on an avo kit, stock motor, e85
522whp/414tq on a 5858 and built motor 590whp/441tq on a 6262 we are doing a GM auto trans swap currently for drag racing/street. thats what im building the car for
#34 |
Drives: Asphalt frs
Nice when did you start burning through transmission?after built motor or while running avo kit?
#35 |
Drives: 2JZ FRS
didn't break any gears with the avo setup but that trans had horrible synchro issues, especially at higher rpm's
#36 |
Drives: Asphalt frs
#37 |
Drives: 2013 FR-S Whiteout
Is this transmission honestly that fragile? I never had this issue with or worry with my 04 STI . This is becoming a big concern now with the power levels in trying to hit. I'm just a bit confused because 3 tuning companies I spoke with personally said the transmission would be fine at the power I'm trying to attain. One of those companies was FBM to name one. Are they hoping I yardsale my transmission to get more money out of me? This is getting serious now because there aren't many if any options or there for the transmission in this car to hold the power
Sent from my SM-G900V using Tapatalk |
#38 |
Drives: 2013 Raven FR-S
just send your car and a blank check to FBM and everything your little heart desires will come true
#39 | |
Drives: Asphalt frs
#40 |
#41 |
Plus I was hoping to do a bunch of work myself to better learn things. I've worked on all my previous cars. Just nothing this extensive
| The Following User Says Thank You to flat4-86 For This Useful Post: | SoCal80six (10-08-2015) |
#42 | |
...Just add nauseum
Drives: 2003 (AP1) S2000
And I have no idea what people are b*tching about on the synchros. If your clutch is set up correctly, and you shift correctly, power should not affect synchro wear. Period. I have never had any synchro issues whatsoever. I bought it in Alaska, Drove on many mornings at -20f or colder. No issues. 90+ degree days in NY, no issues. 270 whp on 93 & 7psi, no issues.
There are many ways to displace.
-Spartarus |
| Forced Induction HELP! | surfuxalot | Forced Induction | 22 | 06-20-2015 01:56 PM |
| Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 04:42 PM |
| NOS or Forced Induction? | v3rgil | AFRICA | 1 | 11-08-2012 08:17 AM |
| 6AT (+) Forced Induction | RYU | Forced Induction | 18 | 09-10-2012 12:14 AM |
| Forced Induction | Primo86 | Engine, Exhaust, Transmission | 11 | 05-29-2012 08:50 PM |
