CANADA Canada
Old 02-11-2019, 01:06 PM   #29
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
It's still a bit early for me at 65000kms and just under 6 years but I've got valve spring recall service coming up next month so I'm getting my plugs done at the same time, only being charged parts. Glad that I won't have to worry about it for another 7-8 years at least with 0 trouble and added expense to myself.
Lynxis is offline   Reply With Quote
Old 02-12-2019, 10:12 PM   #30
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Originally Posted by Mr.ac View Post
Save your self some money do it yourself.
You'll need to buy some tools,
Magnetic flexible pick up tools,
Long reach needle nose pilers,
Some short/long wrench extensions,
A 6 pack of beer or your choice,
Fingers less gloves,
Band aids,
Loud music to cover up you cursing like a sailor.
That should do it. Just take your time, practice removing extensions one handed, and with needle noses. Oh and make sure to do back stretching exercises. You'll be bent over for a while.
This vid should help out, it did with mine.
I attempted this last weekend and it went well athought it did take about 4 hours. It was still better then spending a few hundred dollars. The money I saved I ended up getting a Sonos speaker for the garage to cover up the cursing. Haha.
TRAKRAVN is offline   Reply With Quote
The Following 2 Users Say Thank You to TRAKRAVN For This Useful Post:
Busybee (10-13-2022), Turbo (02-13-2019)
Old 02-13-2019, 04:54 PM   #31
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Plugs from Toyota: $136
Local shop to do the work: $449
Getting this done in the winter on the same day we get high winds and 1.5ft of snow: priceless.
Prices in CAD, after tax.
pushrod is offline   Reply With Quote
Old 02-14-2019, 09:32 PM   #32
VirUzxZ
Drives: Black on Black on Black
Valve spring recall
28$ a plug
no labor
yassssss
VirUzxZ is offline   Reply With Quote
Old 03-12-2019, 07:39 PM   #33
unicron
unicron's Avatar
Drives: frs 2015
oil in the spark plug recess after 98000km! I just did mine myself; watching videos and reading what everyone else has done was great. I used an old rubber gas line to screw the plugs in (like I saw in a video) and had a towel stuffed in there to stop tools from falling down. A bolt did actually end up falling down but I used a boroscope camera to find and pick it up with a magnet. I also wanted to check out the inside of the cylinders and noticed there is oil in the spark plug recess. What’s the deal with that? It’s not an easy job. I wouldn’t recommend anyone try it without a bunch mechanical skills, correct tools, patience, and you have at least a six pack of you favorite beer!. Would the oil leak be a warranty thing?
unicron is offline   Reply With Quote
Old 03-13-2019, 10:30 AM   #34
wparsons
wparsons's Avatar
Oil is probably from a leaking valve cover gasket, you could try for warranty repair on it but they'll probably fight hard. IIRC you have to pull the engine to replace the "gasket" (sealant I believe).
flickr
Old 04-30-2019, 12:21 PM   #35
Yousend
Drives: 2014 FR-S
Originally Posted by VirUzxZ View Post
Valve spring recall
28$ a plug
no labor
yassssss
Just called Toyota for plugs, $28 a piece. Get transferred to Service to ask how much labour would be. $99 for the entire service. Spark Plugs included. Sounds too good to be true, but I booked an appointment ASAP.
Yousend is offline   Reply With Quote
Old 04-30-2019, 01:28 PM   #36
Noahsark
Noahsark's Avatar
Drives: Fr-s
Loosening the motor mounts and jacking the engine per each side will help you get to the hard reach areas, makes taking the spark plugs out very easily.
Noahsark is offline   Reply With Quote
Old 04-30-2019, 02:24 PM   #37
wparsons
wparsons's Avatar
$112 without labour, $99 with. Guaranteed they priced the wrong car for the service with labour. They'll correct it when you show up, and expect it to be at least $500 with parts.
flickr
Old 04-30-2019, 02:27 PM   #38
Yousend
Drives: 2014 FR-S
I'm going to ask to sign the paperwork before they start the work, but yeah I'm sure she quoted the wrong car, but I even specified "Even for an FR-S?" and she was quick to say yes.
Old 04-30-2019, 04:47 PM   #39
wparsons
wparsons's Avatar
I'm sure they'll catch it before getting you to sign it. IIRC it's like 5 hours of time, and they won't have booked things properly for the day without accounting for that.
flickr
Old 04-30-2019, 09:31 PM   #40
Yousend
Drives: 2014 FR-S
Will still test my luck. Worst case I cancel and change it on my own as I was planning to anyway.
Old 05-01-2019, 09:31 PM   #41
Silverz
Drives: Black frs
Made a deal with one of the dealership mechanic to do it at his house on the side. $140 for labor and I provided the spark plugs. paid $87 for the spark plugs on eBay.
Silverz is offline   Reply With Quote
Old 05-02-2019, 11:22 AM   #42
wparsons
wparsons's Avatar
Did you ask him about getting his cost on parts too? Might've been a bit cheaper, I forget what the markup is like on the plugs.
flickr
Spark Plug Removal Tools JimmyMac Engine, Exhaust, Transmission 28 07-15-2016 12:25 AM
Spark Plug Time !!!! RFB Scion FR-S / Toyota 86 GT86 General Forum 26 11-24-2014 08:46 PM
Spark plug replacement and P0301 errors Jacques Blom AFRICA 1 12-23-2013 05:04 PM
Spark plug question Wilsonk227 BRZ First-Gen (2012+) — General Topics 19 07-03-2013 01:57 AM
Spark plug type and heat ft86-UAE Engine, Exhaust, Transmission 4 06-10-2012 11:21 AM
