Old 03-28-2015, 09:23 PM   #1
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Thumbs up Spark Plug Removal Tools
Not sure if spark plug removal has been posted before, but I'll post it anyways. I took out my #4 spark plug without jacking the engine. If you have big hands, this may be very hard to do. I'm not giving a how to. I'm just showing you the tools I used. If you can get to the coil packs then you can do spark plugs. The following tools were used:
14mm extended socket (Mine was a plain socket so it did not have the rubber insert inside to grab the spark plug.)
3/8" swivel or u-joint
1.5" extension
3/8" Flex Handle
*Extra convenience tools*
13mm Gear Wrench with Socket Adapter (Used this instead of socket wrench due to low profile to fit between spark plug and wheel well wall.)
Curved tip needle nose (To pull out the spark plug. A magnet could also be used.)
Basically you just put together the 14mm socket assembly in the order as shown. The socket will fit into the head at an angle and then slide onto the spark plug. It's not hard to break loose. Once I got the plug loose enough, I pulled off the wrench (or flex handle) and started turning the socket assembly by hand. Once I felt the plug was loose, I pulled out the socket assembly and used the curved needle nose to pull out the spark plug. (You'll know the plug is loose because it will be laying down and no longer centered in the head.) It was as simple as that. I'm not sure if a rubber insert in the 14mm socket would help or hinder this process. If you try it, let us know how it works out.
Hope this helps someone. Enjoy...
JimmyMac is offline   Reply With Quote
Old 03-28-2015, 09:41 PM   #2
stevesnj
stevesnj's Avatar
Just curious why you needed to remove the spark plug?
My 2016 Build thread
Old 03-28-2015, 10:26 PM   #3
JimmyMac
JimmyMac's Avatar
Troubleshooting... misfires and other codes. Next up is the wiring. http://www.ft86club.com/forums/showt...=30879&page=11
Old 03-28-2015, 10:48 PM   #4
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Nice. Will a similar method work on spark plugs 1, 2, and 3, or are these much easier or harder to remove?
Old 03-28-2015, 11:09 PM   #5
JimmyMac
JimmyMac's Avatar
It should work. Position #4 is a little tighter than #2. On side 1 & 3 you will need to remove the injector driver to gain access as you would doing a coil swap.
Old 03-31-2015, 03:22 AM   #6
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Dear god that plug looks beat. How many miles are on it? Are you boosted or running a super rich tune?
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 03-31-2015, 04:18 AM   #7
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Might as well do a How To while you're at it 😊
Carlitoz3 is offline   Reply With Quote
Old 03-31-2015, 09:20 AM   #8
JimmyMac
JimmyMac's Avatar
About 39,000 miles. I was having coil/misfire problems with this cylinder after turbo install. That's why I pulled it. (Turned out to be a main harness connection issue.) I had less than 100 miles boosted. Lots of unburnt gas through this cylinder. (No not through the whole 100 miles.)
Old 03-31-2015, 09:40 AM   #9
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
Might as well do a how to
BlueSky is offline   Reply With Quote
Old 03-31-2015, 09:54 AM   #10
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Subbed
hmong337 is offline   Reply With Quote
Old 03-31-2015, 10:37 AM   #11
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
1.5" extension
3/8" Flex Handle
Thanks. A few people had posted a list of tools, but nothing speaks better than a picture.
Old 03-31-2015, 11:21 AM   #12
JimmyMac
JimmyMac's Avatar
I might do a quick video. We'll see if I have time this weekend. If I do I'll just show you how to remove one of the plugs for the driver's side. Then maybe a separate for the passenger side.
Old 04-01-2015, 12:00 PM   #13
jcw99
Drives: swp mt '14 brz premium
14 mm plugs?
This is my first introduction to 14mm plugs. Are they common now? All my sockets are either 16mm or 13/16(which are getting 'dusty').
jcw99 is offline   Reply With Quote
Old 04-23-2015, 06:02 PM   #14
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
nice. make DIY!!! you'll be a hero in forum!
#nosympathy, #notourcars
Spark plug removal? Changed your feelings for BRZ? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 89 02-07-2015 09:46 AM
Spark Plug Time !!!! RFB Scion FR-S / Toyota 86 GT86 General Forum 26 11-24-2014 07:46 PM
Spark plug replacement and P0301 errors Jacques Blom AFRICA 1 12-23-2013 04:04 PM
Spark plug question Wilsonk227 BRZ First-Gen (2012+) — General Topics 19 07-03-2013 12:57 AM
Spark plug type and heat ft86-UAE Engine, Exhaust, Transmission 4 06-10-2012 10:21 AM
