#29 |
I'm not an engineer, but I might be able to answer your questions.
Also, tagging is not working properly for some reason, cuz I totally got to this thread by chance, rather than being tagged... |
| The Following User Says Thank You to CSG Mike For This Useful Post: | stockysnail (08-22-2015) |
#30 | ||
Drives: '14 981CS, '99 NB1
| The Following User Says Thank You to johan For This Useful Post: | Ultramaroon (08-22-2015) |
#31 | |
#32 |
That said.... he never did break his supercharged car. Yet his turbocharged cars always seem to be broken before I get a chance to drive them in their "upgraded" states.
| The Following 4 Users Say Thank You to johan For This Useful Post: |
#33 |
Step 1: Confirmed OEM plug on our cars does plug into OEM k20/j3x throttle bodies
Step 2: Started car, throttle body plate does not respond to gas pedal, so maybe wiring issue? Step 3: Studying wiring diagrams... |
| The Following 3 Users Say Thank You to johan For This Useful Post: |
#34 |
not playing cards
Oooo... Nothing fried, I hope. Recommend whenever possible reversing steps 2 and 3. ...if the diagrams are available.
#35 |
#36 | |
Honda: Subaru: |
#37 | |
not playing cards
#38 |
#39 |
Turning is for Nerds
Drives: 35 characters is not enough
For Subaru (assuming they use similar labeling to Toyota)
Well M+ and M- should be your signal wires to the throttle servo VTA1 and VTA2 are TPS sensor and TPS sensor fault detection (should be a voltage that changes based on throttle position) That leaves E1 and VC which will be power for the throttle servo and the TPS (constant voltage) |
#40 |
not playing cards
Are you repinning the TB, or the plug? I will tell you what goes where.
#41 | ||
Subaru pin => Honda pin 1 => 5 Throttle servo - 2 => 6 Throttle servo + I might have the next two backward 4 => 3 TPS Sens A 6 => 1 TPS Sens B Next two are going to be weird Find the voltage source at Subaru 3 and 5 that matches what is expected at Honda 2 (on the Subaru I think one will be 5V and one will be 12v) and connect it, leave the other disconnected. Wire Honda 4 to separate ground 3or5 => 2 other one N/C chassis ground => 4
#42 |
Can't repin the TB, it'd be the plug.
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| | CounterSpace Garage | Forced Induction | 66 | 08-09-2016 02:59 PM |
| Tour of Edelbrock and their new Supercharger! August 28th | The Racers Line | Northern California | 62 | 09-04-2015 03:59 PM |
| Edelbrock's Custom BRZ with SC | Lonewolf | Southern California | 9 | 08-02-2015 06:17 PM |
| Thoughts on Kraftwerks C-Type Rotrex Supercharger | Piper606 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 07-31-2015 10:59 AM |
