08-07-2015, 12:14 PM | #29 | |
BOXER FR
Drives: WRB BRZ Limited
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
08-07-2015, 12:35 PM | #30 |
tickle fight referee
Drives: 2015 Subaru BRZ
Celery man
Electrical space wizard |
The Following User Says Thank You to Icanfaptothis86 For This Useful Post: | drewbot (08-07-2015) |
08-07-2015, 02:11 PM | #31 |
Drives: '23 BRZ Limited
lolz at alignment specs and complaining about sharper turn-in.
What tracks are you running at that you're having a problem? |
08-07-2015, 02:17 PM | #32 | |
Drives: 2014 FR-S
How much the front end feel changes after you do that, however, will be somewhat profound.
-Mike
#24 CS/CSR |
The Following 3 Users Say Thank You to TrqlessWonder For This Useful Post: |
08-07-2015, 02:38 PM | #33 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
You mention you want turn in but please post full alignment specs, wheel and tire combo, tire pressures
08-07-2015, 02:53 PM | #34 |
Drives: 2015 BRZ
Like others have said, a 1/16" of toe out would be a good place to start. Won't affect tire wear appreciably, but the car may tend to "wander" at higher speeds. Not strongly, but enough you'll have to keep a hand on the wheel.
Also look into sways. The "sharper feel" you're after is accelerated weight transfer on turn in, and sways are a very cost effective way to do that. Full analysis to follow in our build thread, but we just came off track with our new Whiteline sways, and we dropped our roll stiffness by 20%. |
The Following 3 Users Say Thank You to GSpeed For This Useful Post: |
08-07-2015, 02:53 PM | #35 | |
Can be found in his build thread: http://www.ft86club.com/forums/showthread.php?t=42284 Also should be noted that having weight on the passenger side is good to offset the weight of the driver
Celery man
Electrical space wizard Last edited by Icanfaptothis86; 08-07-2015 at 02:54 PM. Reason: i suck at expressing myself |
08-07-2015, 02:57 PM | #36 | |
08-07-2015, 02:58 PM | #37 | |
Drives: 2005 Toyota Camry
There is no tangible benefit performance-wise other than your perception of an improvement in performance. If all you want is to lighten the car, that should be it. There is zero need to justify it any further, and any more attempts to make it sound performance-oriented will make your justification look stupid. -alex |
The Following 2 Users Say Thank You to mav1178 For This Useful Post: | strat61caster (08-07-2015), why? (08-06-2018) |
08-07-2015, 02:59 PM | #38 |
No argument at all I was just sharing info
Celery man
08-07-2015, 03:08 PM | #39 |
08-07-2015, 05:08 PM | #40 | |
BOXER FR
no need to get all pissy about it. you can call my "justification" stupid in person when i see you at the 86 cup. thanks, Andy
08-07-2015, 05:10 PM | #41 |
BOXER FR
Drewbot that is all the alignment spec I have. I`m running on Enkei RC-T4 18x8.5 mounted on Michelin pilot super sports 245/35/18 square. usually run 38psi up front 35 at the rear cold.
08-07-2015, 05:16 PM | #42 | |
A rear weight bias is ideal but next to impossible with a front engine, if you can put the engine up front and get a 50/50 weight bias you've pretty much done as much as you possibly can to get the best bias possible (rearward). Thing is most people will never have the money or skill to utilize such dynamics (hence my marketing comment above), the F/R layout allows for more accessible control and fun without the other edge of the blade to cut you (snap oversteer, small window of traction, yada yada) by having an even or front static weight bias. Which is why I suggested aerodynamic modifications, you get the traction when you need it, at speed, with very little compromise to counteract the car's sub-optimal static weight distribution. Look at the fastest cars in the world (around a track), the hypercars and the F1 cars, they sit around 45/55 all the way down to 35/65 F/R weight distribution, that is not a mistake or compromise (hell the Nissan Deltawing is 27/73). Tons of stuff to read up on if you're into it, formulas and such to derive. |
The Following User Says Thank You to strat61caster For This Useful Post: | why? (08-06-2018) |
Similar Threads | ||||
Making the BRZ ever lighter | Alabang BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 04-16-2014 08:57 AM |
Are dry carbon fiber front 1/4 panels lighter than OEM? | Superhatch | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-27-2013 03:47 AM |
Better to go wider or lighter? | BRAWL | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 08-02-2012 09:48 PM |
Increased whp by having lighter wheels | mechaghost | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 07-03-2012 12:46 AM |
What return from going with lighter wheels? | bazguitarman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 06-01-2012 09:35 AM |
