#29 |
Hey, it could be worse; Mercedes-Benzes have a left-to-right motion to change gears with the manual mode... you wanna talk about counter-intuitive? I don't know what they were thinking. Never much cared for M-B anyway...
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#30 |
Drives: 2013 Scion FR-S Hot Lava 6AT
I too would like to know if a way of swapping up/down shift is found...
I found + towards driver very intuitive on my MR2-Spyder... and I keep doing it wrong on my FR-S.. .. I kinda feel like James May and the dogleg 1st gear when i do it. |
| The Following User Says Thank You to Kurenai For This Useful Post: | Laika (09-07-2012) |
#31 |
Drives: SWP Subaru BRZ Sport-Tech 6AT
#32 | |
Reverse Burnouts
Drives: 2013 Argento FRS
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#33 |
Drives: Red 86 GTS Auto
Ummm.... If you were in a stick shift car, then under braking you will be both pulling and pushing the stick as you go down the gears...
It would be nice though if there was a standard for the autos across all manufacturers and models. Makes the transition to new cars a lot eaiser. Point in case, yesterday I had to jump in and out multiple times and drive a VW polo, and a Toyota Corolla. Given that the indicators for each car was on the opposite sides to each other, it was a pain in the azz. Towards the end of the day I figured it was just easier when I needed to indicate, to hit both left and right hand stalks. Indicating to turn with wipers...
Current drive: 2012 Toyota 86 GTS
#34 |
Akaytch
Drives: TSX, tC2(sold), FRS(waiting)
Instead of swapping the wires or reprogramming the ECU
Try to reprogram you're brain, it's cheaper, faster... and easier
#35 |
Drives: SSM LT MT BRZ
a couple of things.
this is an AUTOMATIC you are talking about, it is not related in any way shape of form to a sequential roller barrel actuated race box, please remove all such thoughts from your head. YOU ARE WRONG...let that sink in....better than 75% of all auto boxes are forward to shift....as are most upshifts in what has been standard for years....the 5 speed h pattern gearbox...1st UP 3rd UP 5th UP...only second and fourth are down,,,,in down shifting it is a split... Automatics have been manually selectable for some time with the standard P R N D 3 2 1 pattern...and since you are driving an automatic...not a manual....it makes far more sense to maintain this same pattern...because this is a street car, if you want a reverse manual selection, switch the wires and be done with it, if you want a manual transmission....well....you paid extra for an auto...so obviously you didn't... |
| Automatic Transmission | devinclfalcons | Engine, Exhaust, Transmission | 60 | 04-29-2014 09:42 PM |
| Do you think FT-86 will have automatic? | TRD | Engine, Exhaust, Transmission | 217 | 08-03-2013 09:36 AM |
| Red Automatic FRS available | BRZ88 | NY / NJ / CT / PA | 0 | 06-01-2012 12:04 PM |
| automatic pdf :D enjoy | carbonBLUE | Engine, Exhaust, Transmission | 4 | 04-26-2012 11:17 PM |
| Anyone Else Considering an Automatic FR-S? | iff2mastamatt | Scion FR-S / Toyota 86 GT86 General Forum | 410 | 02-16-2012 12:41 PM |
