| Northwest AK, ID, OR, WA |
#29 | |
not playing cards
If in either of those scenarios you keep getting P0202, then the problem lies in the connector or upstream. There are other things you could do to test but it requires a multimeter and/or a 12V pwr supply to test or trigger the injector manually.
#30 |
not playing cards
For reference, these are the codes that indicate a coil pack/igniter.
#31 | |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#32 |
not playing cards
No, then it gets more complicated. Forget about the coil pack. I wasn't paying any attention to your codes when I first replied. Sorry about that.
#33 |
Just the tip
Hopefully it's just the injector then. I'm guessing I'm doing the direct injector first to see if it's switching codes and the port injector or only direct?
#34 |
not playing cards
Not the DI. Just port injector. Swap #2 and #4 port injectors and see if the trouble code follows the injector. If the injector is bad, you will see a P0204 code instead of P0202.
#35 |
Just the tip
The direct injectors are the ones on top with the metal cover correct and port are on the bottom some where?
#36 |
not playing cards
The port injectors, the ones you're interested in, fit into the intake manifold. It's pretty easy to get to them. The direct injectors fit right into the head.
#37 |
Just the tip
I'm glad it's not the DI injectors as I'm watching this video currently and I'd have to take my supercharger off to get to them! [ame="https://www.youtube.com/watch?v=sdeO4rBwuQ4"]Scion FR-S BRZ Direct Injector Seal Replacement | Problems and Issues - YouTube[/ame]
#38 | |
not playing cards
#39 |
Just the tip
I'm going to swap the port injectors right now so hopefully all goes well and I don't break anything else.
#40 |
not playing cards
Don't forget to bleed off the fuel pressure or catch it with a rag when you disconnect the fuel line from the rail. Easiest one to disconnect is the crossfeed line between the rails. That's the one with the blue clip.
#41 | |
Just the tip
I checked all the fuses again even remotely related to the o2 heater fuse and they all looked ok. Tomorrow morning I need to call the Subaru dealer to see if they have an injector or injector washer by riding my bicycle down there. Hopefully I can get the damn thing working! I think I'm f'ed with the bolt hole.
#42 | |
Turning is for Nerds
Drives: 35 characters is not enough
| unichip p0172 engine code | bvelna | Software Tuning | 16 | 08-13-2016 08:45 AM |
| P219A ENGINE CODE | Albaro08 | Issues | Warranty | Recalls / TSB | 6 | 12-29-2015 05:15 PM |
| P0328 Engine Code | Lil Abner | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 10-23-2014 12:10 PM |
| Engine Code: P0172 P117B | *KID* | Engine, Exhaust, Transmission | 2 | 01-25-2013 04:23 PM |
| check engine/CEL/DTC/MIL code list | arghx7 | Engine, Exhaust, Transmission | 3 | 07-04-2012 10:37 PM |
