Old 06-02-2015, 10:18 AM   #29
GT86_PRAGUE
Drives: GT86
Or you could... I don't know.... read the manual maybe?
I was referring to a fact that this indicator is not only on AT.
I have it on and I like it (even if I dont need it).
GT86_PRAGUE is offline   Reply With Quote
The Following User Says Thank You to GT86_PRAGUE For This Useful Post:
Tcoat (06-02-2015)
Old 06-02-2015, 10:20 AM   #30
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by serialk11r View Post
My car did 38mpg at 65mph in cruise control coming back from the dealer...
You weren't supposed to use the cruise control for the first 1000 miles. That's the only truly critical part of the break-in instructions.
Now the engine will explode. Sorry.
The Following User Says Thank You to extrashaky For This Useful Post:
Ultramaroon (06-02-2015)
Old 06-02-2015, 10:23 AM   #31
I do to. I was just poking you about having to use YT when how to turn it on is right in the manual.
MaudDib (06-03-2015), Ultramaroon (06-02-2015)
Old 06-02-2015, 10:44 AM   #32
NOHOME
Drives: RAVEN
I find that the fun/mile ratio is inverse to the miles/gallon ratio. There might be a squared factor in there also.
NOHOME is offline   Reply With Quote
The Following 2 Users Say Thank You to NOHOME For This Useful Post:
Tcoat (06-02-2015), Ultramaroon (06-02-2015)
Old 06-02-2015, 11:04 AM   #33
extrashaky
But the manual doesn't have videos in it.
Old 06-02-2015, 11:08 AM   #34
Best I've done is a little over 36MPG over about 350 miles but that was with an average speed over 70MPH.
Old 06-02-2015, 11:18 AM   #35
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
I agree, I get around 25-26 in the BRZ and I could barely get 35 mpg out of a Golf TDI. I have fun as often as I can.
Scenic Driver is offline   Reply With Quote
Old 06-02-2015, 11:39 AM   #36
Fishbed77
Fishbed77's Avatar
Drives: 2013 FR-S 6MT Whiteout
So you bought a sports car to get good gas mileage?
I did and I do.
My previously daily driver was a Nissan Xterra 4X4 (which I still own and is an excellent vehicle). MPG for that vehicle averages 14-17 MPG. By comparison, the MPG of my 6MT FR-S is averaging 32 MPG, and I do a lot of short-distance commuting.
So I'm pretty happy about decision to buy a sports car for the good gas mileage.
Of course, that's just one of the reasons I bought it, but still a major one.
Fishbed77 is offline   Reply With Quote
The Following 3 Users Say Thank You to Fishbed77 For This Useful Post:
Dadhawk (06-02-2015), Tcoat (06-02-2015), Ultramaroon (06-02-2015)
Old 06-02-2015, 11:47 AM   #37
GT86_PRAGUE
Drives: GT86
I am able to read only digits 1-6 and R.
I am not even sure I own something like car manual...
Tcoat (06-02-2015)
Old 06-02-2015, 12:43 PM   #38
Ultramaroon
not playing cards
Ultramaroon's Avatar
My car did 38mpg at 65mph in cruise control coming back from the dealer, I got more because I press the clutch in when the road is downhill.
☑ rekt ☐ not rekt
Old 06-02-2015, 01:10 PM   #39
extrashaky
IMy car did 38mpg at 65mph in cruise control coming back from the dealer, I got more because I press the clutch in when the road is downhill.
You actually got worse gas mileage by doing that. When you let the engine brake the car, the computer cuts off the fuel flow because no fuel is needed to turn the engine. The momentum of the car turns it. When you push in the clutch, the engine goes to idle, which burns fuel to keep the engine turning. Leaving it in gear going downhill therefore uses less fuel.
If you were driving an older car with a carburetor, it would have been the other way around.
Tcoat (06-02-2015)
Old 06-02-2015, 03:34 PM   #40
serialk11r
Drives: '06 AM V8V Coupe
☑ rekt ☐ not rekt
lol you guys are funny, I bought a used car with 28k on it -_-
Also, if you calculate fuel burn per unit energy saved by not engine braking, you'll find that coasting downhill is more fuel efficient if you are not slowing down afterward. DCTs these days have an auto-coast function that does that to save fuel. That's why it's called engine braking. Nice try though.
Old 06-02-2015, 04:24 PM   #41
UMMMMM... no.
You are not using fuel when engine braking you are using compression. Extra already explained it perfectly.
Old 06-02-2015, 04:29 PM   #42
serialk11r
UMMMMM... no.
It uses the car's kinetic energy to power the engine. That energy is not free. Coasting down a hill saves it, at the expense of burning a little fuel to idle (hardcore hypermilers shut their engine off when they coast to save this fuel).
Imagine if you were travelling down a slight hill, steep enough to maintain whatever target speed. If you were engine braking, the car would slow down, and you'd have to keep on applying gas over and over to recover speed. If you coast down the hill, you only burn what fuel it takes to idle. If you barely feed it enough throttle to maintain speed, you're essentially idling the engine at a higher rpm, since it's not doing work, which takes more fuel. Apply gas -> engine brake -> apply gas -> engine brake is generally even less efficient.
Nevermind theory, you can try this pretty easily. Reset the average mpg meter on a flat road and turn on the cruise control, note the number. Then reset it, accelerate slowly then clutch in, rinse and repeat, maintaining the same average speed with a bit of fluctuation. The mpg meter will read a little higher if you do it right. The fuel wasted idling is offset by the drag saved by not spinning the engine as quickly and operating the engine at higher efficiency when accelerating.
The Following User Says Thank You to serialk11r For This Useful Post:
Cal3000 (09-26-2015)
efficiency, gas, mpg
