Old 04-21-2015, 08:25 PM   #29
Originally Posted by Shutter View Post
has anyone looked at or installed one of the Diesel Conversion kits?
Thinking about doing it this weekend, but its kinda pricey.
You're supposed to pick up a decent amount of torque though, so I'm really leaning towards it.
I should know better, but I honestly don't know if you're serious or not.
I see a new engine swap thread in our future!
continuecrushing (04-22-2015)
Old 04-21-2015, 09:55 PM   #30
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
The owner's manual reccomends 93. I only pump 94. 91 if I'm in a crunch.
hmong337 is offline   Reply With Quote
The Following User Says Thank You to hmong337 For This Useful Post:
D_Thissen (04-21-2015)
Old 04-21-2015, 10:03 PM   #31
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by kch View Post
Man you don't need a kit to run diesel. The FA20 is high-enough compression already that you can just disconnect the spark plugs entirely and run diesel as-is. You shouldn't rev over 3k, though, as your ECU will start to pull timing.
No no no... Timing doesn't matter because the plugs have been disconnected. Duh.
The 3K limit is because of the VVT and a huge torque bump that will grenade the internals. If you have OFT you're lucky because I heard @Shiv@Openflash is working on a tune to flatten it.
kch (04-21-2015)
Old 04-21-2015, 10:07 PM   #32
D_Thissen
D_Thissen's Avatar
This. That being said, I ran 91 in the car for a year and about 10,000 km up in Thunderbay because that's all they had. The car seems to like 94 a bit better though. Well minus those crickets. Where's my fly swatter?
Old 04-21-2015, 10:13 PM   #33
Cole
Not a troll
Cole's Avatar
I'm on a 91 tune, so I go out of my way for shell 91.
However, I'm thinking of going back to a 93 tune, so long as running 91 every now and then in a pinch isn't going to make my motor esplode. It's extra temping since I have a petro-can with 94 about 1.5km from my house. I'm lazy and I like convenience.
Old 04-21-2015, 10:19 PM   #34
D_Thissen
D_Thissen's Avatar
A friend of mine has a 350z tuned for 94. His tuner said he can run 91, just don't beat on it too much (tracking, wot for extended periods, red line shifts ect.). Which tuning software are you using?
Old 04-21-2015, 11:24 PM   #35
kch
Senior Misanthrope
kch's Avatar
oh right. duh. my bad.
The Following User Says Thank You to kch For This Useful Post:
Ultramaroon (04-21-2015)
Old 04-22-2015, 05:20 AM   #36
Cole
Not a troll
Cole's Avatar
OFT
Old 04-22-2015, 10:06 AM   #37
5thGenOwner
5thGenOwner's Avatar
Drives: '10 SS & '15 FR-S
You can only get 91 here in Cali. That's what I'm usin' in the SS, so I figure I might as well stick it with it in the FRS. It's kept that L99 engine knock free and purring for 5+ years, gotta be good for the Boxer. I think it was $3.59/gal last fill up.
5thGenOwner is offline   Reply With Quote
Old 04-22-2015, 12:02 PM   #38
The owners manual recommends 93 but requires a minimum of 91.
*: If unleaded gasoline with an octane rating of 93 AKI (98 RON) is not available,
unleaded gasoline with an octane rating of 91 AKI (95 RON) may be
used with no detriment to engine durability or driveability.
Ultramaroon (04-22-2015)
Old 04-22-2015, 12:48 PM   #39
hmong337
Emperor JDM
hmong337's Avatar
Yes. I only use the best for my fleet of cars. Fwiw, I can definitely feel a difference in power between 91 and 94 with my buttdyno. Again, you can use 91. But is it optimal? Not really.
I recall a dyno sheet showing both fuels tested. The 91 oct only put down some 140whp where the 93 put down around 160whp.
The Following 2 Users Say Thank You to hmong337 For This Useful Post:
Tcoat (04-22-2015), Ultramaroon (04-22-2015)
Old 04-22-2015, 01:01 PM   #40
Ultramaroon
not playing cards
Gotta pull that timing with the fast-burning stuff. Isn't the DI also retarded for the same reason? (DI novice)
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 03:39 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
