Old 09-26-2015, 06:23 PM   #29
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by JB86'd View Post
@solidONE Check out the temp compensation table
This is my Base Timing and compensation tables for STG1 CA91 vs STG1 OFT93 for your reference.
Intent > Content
Old 10-30-2015, 05:35 PM   #30
JB86'd
JB86'd's Avatar
Drives: JAWS
First post updated, now running Wayno's smoothed Base Timing B and custom IAT Compensation
Old 10-30-2015, 11:49 PM   #31
cookiesowns
Drives: WRB BRZ Series.Blue
Nice! Can you post a screenshot? Is this with Wayno's helpful tip of a flat KC Advance table with corresponding changes on timing?
cookiesowns is offline   Reply With Quote
Old 10-31-2015, 12:38 AM   #32
JB86'd
JB86'd's Avatar
Drives: JAWS
The screenshot is updated in the original post. Yeah, I just copied Wayno's Base Timing B over to my tune, no need to mess with the KC advance table afaik.
Old 10-31-2015, 01:59 AM   #33
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
The released tunes don't have flat KCA, only the files used for 3d mapping the timing does.
The Following User Says Thank You to Wayno For This Useful Post:
JB86'd (10-31-2015)
Old 11-01-2015, 12:32 AM   #34
cookiesowns
So I should not run a flat KCA table for daily usage?
Old 11-01-2015, 01:30 AM   #35
steve99
Their is no real advantage in doing so unless you want to see knock easily using the KCS value. ie if its flat any deviation is knock. But be have FBKC and FLKC parameters to see knock much easier.
although that KCA table looks like a random array of numbers I suspect the subaru engineers designed it that way to allow more knock correction to take place in knock prone areas when IAM drops. and/or drop the timing larger amount in certain areas as IAM correction acts on KCA values only.
Old 11-01-2015, 03:50 AM   #36
Kodename47
Kodename47's Avatar
Drives: UK GT86
This is very true. You don't really want the IAM to reduce timing at lower load, just let FBKC take care of that. If you want a flatter advance table so that the base timing is easier to read then I would suggest keeping the values in each load column the same and increase them as the load increases. Mine goes from 0 to 5/6 degrees, use the stock table as a guide
You can use my timing adjust tool to play around.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
solidONE (11-01-2015)
Old 11-01-2015, 09:47 AM   #37
solidONE
solidONE's Avatar
You guys are some of the most helpful mofo's on here that's not trying to sell something. lol High fives all around!
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Strife26 (01-09-2018)
Old 11-01-2015, 08:52 PM   #38
thambu19
Drives: Scion FRS
@steve99 Are you saying the Stock cal is more knock limited that the Stage1 cal running the same fuel? I find it difficult to believe because both cals have similar spark timing until close to WOT or 95% VE and Stage 1 cal has less Exhaust phasing by about 25deg at places although Stage 1 cal uses a tad more intake phasing at the same places overall it should make the engine knock a bit more than stock
thambu19 is offline   Reply With Quote
Old 11-01-2015, 08:53 PM   #39
thambu19
Drives: Scion FRS
Usually when the cam overlap is dialed out the flame speed increases making it knock earlier for same spark timing
Old 11-01-2015, 09:19 PM   #40
steve99
If your talking about post above, then all the guys are doing is shifting timing from base a\b to the knock correction max A table, same overall timing. some tune is same just kca (knock coorection max a) table flattened so you could more easily see knock. Same tune no other changes.
Wayno (11-01-2015)
Old 11-01-2015, 09:29 PM   #41
Wayno
Wayno's Avatar
Yeah I don't know why it's a discussion.
But then, I said 6 months ago pulling chunks of timing compared to smoothing it out is detuning the car, and it only took 6 months to catch on, so this whole KCA concept will blow over in 6 months time.
Old 09-29-2022, 11:56 AM   #42
dave66k
I was hoping to view the video from this old thread, but it shows as private now. Any way to still see iti?
dave66k is offline   Reply With Quote
Modify your snorkel (pics) Yruyur Engine, Exhaust, Transmission 81 02-12-2017 11:07 AM
Do you modify your car just to be different? #87 Off-Topic Lounge [WARNING: NO POLITICS] 31 02-08-2013 11:14 PM
modify when locking car. DriftEightSix AUSTRALIA 2 09-30-2012 09:30 PM
How are you going to modify your FRS? Asterisked Accolade Scion FR-S / Toyota 86 GT86 General Forum 55 07-12-2012 01:00 PM
Does anyone intend to NOT modify their BRZ? R8 BRZ First-Gen (2012+) — General Topics 40 06-08-2012 01:24 AM
