Old 07-13-2015, 12:00 PM   #29
fika84
fika84's Avatar
Originally Posted by rhood168 View Post
I have the same radio and I bought for the same reason. It just doesn't want to work. I've tried everything and have done it all from the bypass the the mhl adapter/hdmi to switching phones and all. Damn thing just doesn't want to work. Messed with it for 3 months until I gave up. Only thing i didn't do was mess with the settings on the nex itself(how the smartphone connects and HDMI/Bluetooth settings , if ts a ipod or not blah blah) to a point but that shouldn't matter but i almost threw it into the street so i stopped lol. It does recognize the phone but doesn't mirror it and trust me I've tried it ALL...if it wasn't connected to my OEM audio + , I would of ditched it awhile ago..still a great radio though. I wanted to mirror torque from my phone but the app itself just didn't want to work.
You need to tell the radio how you are connecting, or else it won't work. Also make sure your phone supports MirrorLink.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
rhood168 (07-16-2015)
Old 07-13-2015, 02:03 PM   #30
toast
Drives: 14 BSP Edelbrock BRZ
^. This part is not optional, the head unit is not smart enough to figure out what is talking to it.
Is your phone rooted? If so, ditch Android Auto and Mirrorlink, they are both half-baked solutions. Get AppRadio Unchained Reloaded. Full screen mirroring for any app, not just the ones modified to work on AA and Mirrorlink. I had Tasker set up to launch a custom home screen and launcher as soon as the MHL connection was made to make up for the poor resolution (compared to your phone) of the head unit screen.
toast is offline   Reply With Quote
Old 07-15-2015, 11:37 AM   #31
kthxbai
kthxbai's Avatar
Drives: '13 Whiteout FR-S M/T
Originally Posted by DieselDog View Post
Ive got a AVH4000NEX and used the TR7 PAC and a relay to change the signal polarity.
works for me.
Is your TR7 programmed properly and are you using a relay to reverse polarity as it needs to see a ground pulse and the TR7 puts out a power pulse.
Purchased a relay yesterday and will attempt programing the PAC TR7 for my 4100nex tonight. Wiring is not my forte and I'm trying to understand the instructions.
"When it states with start only with power and ground", does that mean only hook up the black ground wire and red 12 volt wire to the relay?
"Then pulse brown wire to ground 17 times." Does this mean take the brown unhooked wire and tap the black ground wire 17 times?
Please accept my gratitude ahead of time for your help!
kthxbai is offline   Reply With Quote
Old 07-16-2015, 02:08 AM   #32
DieselDog
Shift it or lose it
DieselDog's Avatar
Drives: 2014 FRS, 2003 Celica GT
you start with the power and ground hooked up to your car.
you can tap the brown wire to any ground in the car or the ground you just hooked up.
DieselDog is offline   Reply With Quote
The Following User Says Thank You to DieselDog For This Useful Post:
kthxbai (07-16-2015)
Old 07-16-2015, 03:44 PM   #33
kthxbai
kthxbai's Avatar
It worked like you said, thank you again!!!
Old 07-16-2015, 10:45 PM   #34
rhood168
rhood168's Avatar
Drives: Black Subaru Brz Limited
I tried the app radio unchained using an mhl adapter and hdmi cable and the radio could not mirror my phone and yes the phone was rooted. The radio couldn't figure out the app and connect to it. Didn't matter what setting it was . I could not get it to work
rhood168 is offline   Reply With Quote
Old 07-17-2015, 06:20 AM   #35
Chimera
Drives: FRS
Maybe your phone has slimport?
Old 09-12-2015, 09:23 AM   #36
Davesta619
Drives: Brz
Originally Posted by kthxbai View Post
@bigdawg86 In the market for the same HU, Pioneer 4100nex. I've researched the additional parts needed to complete this install based on the two DIY directory articles. However neither DIY addressed this specific HU. Do I need any additional parts other than the following:
1. Beatsonic BH1 mounting kit & wiring harness
2. Male/Female Bullet connectors 14-16 gauge
3. Scosche LSAAB Lexus Antenna Adapter
4. Axxess AX-TOYUSB
5. PAC TR7
Im curious to know why would we need Scosche LSAAB Lexus Antenna Adapter?
Davesta619 is offline   Reply With Quote
Old 09-14-2015, 11:05 AM   #37
kthxbai
kthxbai's Avatar
The OEM HU wires from the car will not attach to the aftermarket 4100nex HU. If you want to continue to use your antennae to listen to local stations, the Scosche LSAAB Lexus Antenna adapter is needed to connect your FRS/BRZ antenna receptor into your aftermarket HU.
I'm nearly 3 months into ownership of 4100nex and could not be happier!
Sent from my SAMSUNG-SM-G850A using Tapatalk
Old 09-15-2015, 09:54 AM   #38
toast
What phone are you using? Samsung phones need the real samsung MHL adapter, there are a ton of fakes floating around on ebay AND Amazon.
For the smartphone connection in setup you have chosen 'Other', correct? Did the phone establish a bluetooth connection? Give me more info and we can get this to work.
Old 09-16-2015, 08:46 PM   #39
rhood168
rhood168's Avatar
I was using a Samsung galaxy s4 with a legit Samsung MHL adapter( i made sure it was not a fake). I dont believe i had it set to other but i recall trying the setting as this was over a year ago when the nex first came out. Now i have a lg G4 which means i need to get a new adapter for it to work.
Old 09-17-2015, 02:15 PM   #40
toast
I had a GS4 with a samsung MHL adapter running full screen mirroring on an AVH-8500BT, the predecessor to the NEX series and it all worked fine using AppRadio Unchained when it was still in beta. Let me know when you get the adapter and we will get this set up.
FS: Pioneer AppRadio 2 tonypalomo Audio/Visual, Electronics, Infotainment, NAV 1 03-24-2015 04:15 PM
Pioneer AppRadio 3 with MirrorLink Alabang BRZ Electronics | Audio | NAV | Infotainment 53 06-01-2014 10:22 PM
Pioneer Appradio 3 Krikekim13 Electronics | Audio | NAV | Infotainment 13 04-10-2014 11:33 AM
DashCommand, PLX Kiwi 2 WiFi & Pioneer AppRadio Alfalasy Electronics | Audio | NAV | Infotainment 7 09-12-2013 01:50 AM
Pioneer AppRadio quik1987 Electronics | Audio | NAV | Infotainment 33 01-23-2012 05:55 PM
