#29 |
Drives: '13 Firestorm Scion FR-S
I made a video for the viper remote start I have on my FRS.
[ame="https://www.youtube.com/watch?v=GwyGxtswQlo"]Viper 5706v - Alarm/Remote Start - YouTube[/ame]
Project Red - '13 Firestorm FR-S |
#30 |
Drives: Ultramarine FR-S
Our cars have a neutral safety switch that is a ground when the car is in neutral, and not when it's in gear. If your remote start has a ground while running wire, hook that up to wire for the neutral safety switch (I forget which one it is but I'll look it up if someone is interested) and when the car is in gear, the remote start will not start the car.
I have the AdvancedKeys system set up this way and if I put it in any gear, the car won't start. In neutral, and it remote starts. |
#31 |
Can you post a link to your system
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#32 | |
Only users lose drugs.
Drives: All the time
Does your gear indicator still work after bypassing the neutral safety switch? |
#33 |
I think you misunderstand, you don't bypass it. It effectively is a ground when your car is in neutral. You connect it to your ground while running wire (or similar) on your remote starter. When you attempt to initiate the remote start, your remote starter turns on the ignition, checks to see if the ground while running wire is grounded. If your car is in neutral, the neutral safety switch grounds the ground while running wire and when the remote start sees that, it will start the car. If the car is in gear, the remote start will not see the ground and will not start the car. Of course, you need a remote start that has this function but I think most do. If not, you could always setup a relay that disconnects the remote starter from your starter wire when not receiving a ground from the neutral safety switch.
| The Following User Says Thank You to jonzhuxD For This Useful Post: | venturaII (06-26-2015) |
#35 | |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
If you're looking to warm the car, no point......if you're looking to warm the cabin for yourself, well
#36 | |
Ahh - gotcha. Thanks for the explanation. |
| Warm air from vents | blunova | Issues | Warranty | Recalls / TSB | 131 | 10-06-2020 01:27 PM |
| Warm Up? | gt865 | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 09-17-2014 11:28 AM |
| When do you consider the oil warm | sluflyer06 | Engine, Exhaust, Transmission | 14 | 06-26-2014 02:21 PM |
| Ignition for Cat warm up | Toyota John | Software Tuning | 8 | 04-16-2014 12:14 PM |
| Warm up time | white_knight | Scion FR-S / Toyota 86 GT86 General Forum | 47 | 03-14-2013 03:55 PM |
