Old 07-04-2015, 04:45 PM   #29
zeal86
zeal86's Avatar
Drives:
Unfortunately I experienced some rubbing in the rear (more on the passenger side) after my alignment.
Here is the thing though, driving home from my alignment I had no issues...today I had a 6'5" 240lb friend and two gym bags and a case of water so @280 lbs of extra weight... Tomorrow I'll have to drive it again without the extra weight.
Either way I want to make some adjustments...
projekt zeal86 build
zeal86 is offline   Reply With Quote
Old 07-11-2015, 12:10 AM   #30
zeal86
zeal86's Avatar
Drives:
Figured out my rubbing issue... the brace that protects the emergency brake cable was contacting the inside of my wheels. Bent the brace away from the wheel and the grinding went away... going to test out the suspension this weekend.
before
after
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
Clipdat (09-17-2015), Koj (09-06-2016)
Old 07-23-2015, 09:26 PM   #31
zeal86
zeal86's Avatar
Drives:
Got a chance last weekend to put some more miles on my 86 post alignment.
Although I didn't drive it like I stole it I did notice some positive things during my spirited drive...
- shifting felt really solid, clean or crisp if you will... there was very little slop anywhere...
- the 86 handled like it was on rails... the ride is definitely stiffer but IMO totally in a positive way. If I had to drive it every day I could. I loved accelerating into and out of turns...
- didn't really have any transient noises that I did not know the cause of. I drove with my music off in order to verify this.
Overall I felt very connected to the road which is a great feeling when driving spiritedly... I have installed multiple suspension parts simultaneously so it is difficult to give more credit to one mod over another... However I can say that the Beatrush suspension parts make up the majority of my set up... so I must give credit where credit is due... Beatrush makes some outstanding parts especially when compared to the pricing of competing brands on equivalent products... Beatrush takes the cake IMO because of that.
Btw, I purchased my Beatrush parts from Josh over at Kamispeed... Great guy, great service...couldn't be happier with their customer service.
The Following 5 Users Say Thank You to zeal86 For This Useful Post:
8R6 (09-17-2015), Clipdat (09-17-2015), Kami Speed (07-24-2015), Koj (09-06-2016), new2subaru (01-29-2016)
Old 07-23-2015, 11:08 PM   #32
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Track day bro?
Old 09-14-2015, 08:56 PM   #33
zeal86
zeal86's Avatar
Drives:
__________________________________________
Old 09-17-2015, 05:49 PM   #34
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
those decal placements are
Kami Speed is offline   Reply With Quote
Old 01-29-2016, 07:54 PM   #35
zeal86
zeal86's Avatar
Drives:
I have received some more Beatrush suspension goodies... they are as follows : transmission mount bushing spacer, differential mount support bar, front and rear sway bars.
I will try to have product, installation, and finished pics soon.... as well as my thoughts about the parts.
Below are links to my new parts...
- Beatrush differential mount support bar
- Beatrush transmission mount bushing spacer
- Beatrush 19mm swaybar (Fr.)
- Beatrush 15mm swaybar (R)
The Following 3 Users Say Thank You to zeal86 For This Useful Post:
Kami Speed (01-29-2016), Koj (09-06-2016), new2subaru (01-29-2016)
Old 01-29-2016, 07:58 PM   #36
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Let me know how the sways feel
Old 01-29-2016, 07:59 PM   #37
zeal86
zeal86's Avatar
Drives:
Will do!
The Following User Says Thank You to zeal86 For This Useful Post:
go_a_way1 (01-29-2016)
Old 01-29-2016, 08:02 PM   #38
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Will do!
I am gona read your whole thread when I get home. I am also a huge fan of Beatrush hahaha. I only have their strut braces's for now but will be looking to see what needs improvement after the big suspension install in spring
Old 01-29-2016, 08:09 PM   #39
zeal86
zeal86's Avatar
Drives:
Awesome! Needless to say, I've been very impressed with Beatrush! Take a look at my build thread as well... I think I might have more info about my suspension installs there that is not included in this thread.
Do you have a build thread?
Old 01-29-2016, 08:56 PM   #40
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Alright I will take a look haha. My build thread is coming this spring @MisterSheep has been bugging to get one going hahaha!
Old 01-30-2016, 09:55 PM   #41
zeal86
zeal86's Avatar
Drives:
New Beatrush Suspension Goodies
Differential Mount Support Bar
Front Sway Bar
Rear Sway Bar
Transmission Mount Bushing Spacer
chaoskaze (02-26-2016), Koj (09-06-2016), Mr.Impreza (02-03-2016)
Old 02-01-2016, 12:40 AM   #42
zeal86
zeal86's Avatar
Drives:
Got around to completing two of four installs today...Still have to torque the bolts on the differential mount support bar though. I needed a crows foot but l left my set at work. Pretty straight forward installs.
Hex bolts supplied with the Beatrush Differential Mount Support Bar are 12mm with a thread pitch of 1.25 and a rating of 10.9. I will torque them to 80 ft/lbs even though the bolt specs can handle more. The OEM bolts are torqued to 46 ft/lbs.
Torques for the Rear Sway Bar bolts are:
Rear Stabilizer Bracket - 22 ft/lbs
Stabilizer (End) Link - 28 ft/lbs
8R6 (02-03-2016), Koj (09-06-2016), Mr.Impreza (02-03-2016)
Ohlins Road & Track for FRS/BRZ suspension install/review thread mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 628 01-30-2024 06:16 AM
OEM armrest unboxing/review supramkivtt2jz Cosmetic Modification (Interior/Exterior/Lighting) 508 11-22-2017 07:27 AM
The Ultimate LED Switchbacks VLED V3 Tritons Unboxing Install Review & Coupon Yruyur Cosmetic Modification (Interior/Exterior/Lighting) 12 01-10-2014 06:59 PM
Sonar (Spyder) Tail Light Unboxing and Review Yruyur Cosmetic Modification (Interior/Exterior/Lighting) 28 10-20-2013 04:42 PM
DIY Unboxing and Install of JDM CLEAR SIDE MARKER LENS! MrGamer DIY (Do-It-Yourself) Guides 11 07-07-2013 11:19 PM
