Old 04-27-2018, 11:13 AM   #29
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
So - just to resurrect this thread - On the Innovative Temp/Pressure gauge - starting in the 60-70 range is normal, and idle at around 20 is also ok? Sensor is located in a sandwhich plate under the filter above the oil cooler plate.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 04-27-2018, 11:31 AM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That startup reading low. I get over 100 on cold start and it usually stays there for a while. 70's cruising the freeway with oil at operating temp. Idle around 13psi at temp. Same gauge, I replaced my OEM pressure sending unit with the innovate one on the front of the timing cover driver side.
Old 04-27-2018, 03:07 PM   #31
Gopherboy6956
Thanks for the feedback. I'll have to play around with it. Brand new engine build right now, haven't taken it out of the garage - all cold idling so far.
Hopefully this weekend.
Old 04-27-2018, 04:07 PM   #32
reeves
60-70 psi seems too low for a cold start.
With 0W-20 oil + sensor in the sandwich plate, I'm around 110 psi on a cold start idle. It does go down to 90psi after a few minutes though if I continue to let the car idle.
reeves is offline   Reply With Quote
Old 04-27-2018, 04:56 PM   #33
Gopherboy6956
I guess now that I look at the video, the car was slightly warm from my previous start / idle tests.
Tire Pressure Sensors Question NoFlush Mid-Atlantic 5 02-07-2014 06:03 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Question: TPMS Tire-pressure monitoring system installed on aftermarket wheels Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-05-2013 12:54 PM
Oil Pressure Sender Unit Fitment Question Captain Snooze Engine, Exhaust, Transmission 2 07-06-2013 12:41 AM
new rim/tire. question about bolts pressure? and etc WATCHMEHEAL Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-25-2013 05:59 PM
