Old 02-02-2015, 11:40 AM   #29
HotLavaChick
HotLavaChick's Avatar
Drives: '15 Hot Lava FRS
Originally Posted by cjd View Post
Agree. They seem very sensitive to shorts and other unexpected electrical issues (not sure if surge would also do it, probably though.)
I had a battery short out internally on a previous car, dealer insisted on trying to jump it. All the internal electronics were on the fritz, flashing like crazy and they wanted me to just go home! I refused, pointed out the issue, so they said "oh, well, let's check the battery." It was bad... Two weeks later my horn decided to start randomly honking. Right in the middle of Chicago rush-hour traffic (i.e. no one was moving.) BCM had to be replaced.
thank you normal people that replied with a possible problem versus some **** comment lol.
It's at RPB Toyota and they are still running tests-- nothing yet and they also are going to reflash ECU since I have been getting terribly rough idle fluctuations since I went over 100 miles -- it's a new car month old.
the main tech even said that a led blinker wouldn't have caused something this serious. I was getting random alarm chimes (ie- no seatbelt sound) recently while driving.
Electrical gremlins.
HotLavaChick is offline   Reply With Quote
Old 02-02-2015, 11:45 AM   #30
HotLavaChick
Originally Posted by PBlack09 View Post
Sounds like a blown fuse. Probably nothing major, but you should contact your local dealership. I had a similar situation happen to me where the high beams stayed on, beeping in car as if I left my lights on, automatic shifting wouldn't work (had to lift the manual override thing, not sure what it's called), and I think that was all. Turned out to be like $50 or so to fix. Dropped it off at night and got it back early next morning.
yours sounds exactly like mine -- what did it turn out to be and what caused it?
Old 02-02-2015, 11:46 AM   #31
Do you charge you cell and sit it on the passenger seat?
The sensors are electronic not mechanical switches and the alarms will sound when a cell is plugged in and on the seat.
Scared the crap outta me the first time it did it!
Old 02-02-2015, 11:49 AM   #32
HotLavaChick
lol no. I Would be driving and the chime would come on but yet no lights or signals would pop up.
I have done no electrical mods -- just HID's when i first got it and put in that LED blinker i purchased from popular frs/brz car accessory place everyone uses on here.
weird weird weird.
Old 02-02-2015, 12:18 PM   #33
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
Have you checked the Ballasts in the HID kit? Sometimes a bad ballast can cause this issue. It did with my vehicle, but i drive a stick shift.
Old 02-02-2015, 12:25 PM   #34
stugray
Drives: 2013 GBS BRZ Limited
Leds could potentially blow ECU or BSI on 86?
http://www.ft86club.com/forums/showthread.php?p=1612550
LED interior light upgrade causes computer failure
http://www.ft86club.com/forums/showthread.php?p=1761758
Diode Dynamic LED blow $400 fuse...
http://www.ft86club.com/forums/showthread.php?t=60355
Solid State Relay to avoid blowing ECU on our cars? anything led
http://www.ft86club.com/forums/showthread.php?p=1626739
Old 02-02-2015, 12:37 PM   #35
tyrantcf
Drives: '16 WRX, CBR1000RR
was battery disconnected when you were putting in the LEDs?
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 02-02-2015, 05:41 PM   #36
Tromatic
Originally Posted by HeadBanger View Post
And scat is a type of music
Over his head.
OP, I suspect RFI/EMI due to your bling.
Tromatic is offline   Reply With Quote
Old 02-02-2015, 05:47 PM   #37
PBlack09
PBlack09's Avatar
Drives: 2015 Scion FR-S Firestorm
Had a blown fuse. Thankfully it prevented the damage from reaching the computer. I think they said it was a safety fuse for that sort of situation. I put new headlights in w/ turn signals and disconnected the lower turn signals (stock ones) as told by manufacturer, but hyper blinking started. Reconnected and... Well, uh oh.
PBlack09 is offline   Reply With Quote
Old 02-03-2015, 12:53 AM   #38
HotLavaChick
yes.
it was when i put the second one in and reconnected everything and started the car when this all occurred.
Old 02-03-2015, 02:42 AM   #39
Tromatic
Know anyone with an OBDII dongle and Carista?
Old 02-03-2015, 12:42 PM   #40
HotLavaChick
update from dealer -- they replaced the car's computers, and they now cannot get the immobilizer to still work. they may replace that as well -- now.
le sigh.
Old 02-03-2015, 01:41 PM   #41
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
I think this thread has dissuaded me from ever putting LEDs in my car.
Thanks, and good luck with yours. I hope they won't make you pay for everything.
Old 02-03-2015, 05:08 PM   #42
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
I really have no opinion about what caused the OP's problem, but...
people need to keep in mind that incandescent bulbs are really resistors, whereas LEDs are conductors. Replacing a bulb with an LED will generally cause increased current flow (amperage) and can overload circuits and overheat conductors.
Damage from replacing bulbs with LEDs is pretty common, but avoidable with a little planning and research.
http://www.instructables.com/id/Choo...Use-With-LEDs/
billwot is offline   Reply With Quote
Turn signal lights whip Cosmetic Modification (Interior/Exterior/Lighting) 13 02-26-2015 10:45 PM
Is there another way to keep the turn signal lights on? DeadStar7 Scion FR-S / Toyota 86 GT86 General Forum 10 06-29-2014 10:43 PM
OEM fog lights to turn on with parking lights subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 7 02-27-2014 06:41 AM
WTB FR-S Turn Signal Lights retrosmiths Want-To-Buy Requests 2 01-08-2014 02:13 PM
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
