Old 12-04-2014, 02:57 PM   #29
JozhGoober
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
I don't think you want to do that, since the OFT wants to know when the ignition is off during a flash cycle. You'd dump the whole flash process.
JozhGoober is offline   Reply With Quote
Old 12-04-2014, 03:33 PM   #30
Foobar
SLO NO MO
Foobar's Avatar
Yep, other OBD2 devices also need to be plugged in while you perform an off/on sequence. Suppose you could put in a triple switch or something, off, ignition, and battery, then you can choose which mode you want, but that's starting to get carried away. Maybe just Battery/Ignition to keep it simple.
Old 12-04-2014, 07:57 PM   #31
troek
troek's Avatar
Drives: 2012 Toyota 86
this ^^^
Old 12-04-2014, 09:28 PM   #32
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I was planning on adding a switch to the extension for leaving it on all the time but just unplugging the extension and using the original OFT cable for flashing just to prevent any issues.
Old 12-04-2014, 09:41 PM   #33
steve99
I flash with 1 meter extension in with oft and with tactrix that writes 7 times speed of oft no issues
Old 12-04-2014, 09:47 PM   #34
Andrew025
Andrew025's Avatar
I meant preventing any possible connection issues that would arise from having the switch soldered in.
The Following User Says Thank You to Andrew025 For This Useful Post:
steve99 (12-04-2014)
Old 12-05-2014, 05:19 PM   #35
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Noob OFT question...does the OFT NEED to be plugged in all the time? More specifically, if i were to buy a OFT, connect it and flash it...does it need to stay connected/plugged in?
Soo noob, I know...
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 12-05-2014, 05:58 PM   #36
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Soo noob, I know...
Nope. It only needs to be plugged in when flashing the ECU, datalogging or when using the realtime data displays/alerts.
Cheers,
shiv
Old 12-06-2014, 08:01 PM   #37
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
I keep my car garaged as well. After the recent update I no longer leave it plugged in due to thinking it was causing battery drain. I noticed that it seems to not exit the real time data display mode automatically anymore. I thought it was great at first until I went to start my car after it sat for about 24-36hours. May or may not have been the OFT, but either way I no longer leave it plugged in. No battery problems since then and car has been parked for 3+ days.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 12-08-2014, 08:14 PM   #38
Tenchi
Tenchi's Avatar
Drives: Silver Ignition 6MT 10 series FR-S
OFT - Left it plugged in (3wks) and now car wont start
Same thing happened to me. I Unplug it at night and it no longer happens. I freaked out when it first happened.
Tenchi is offline   Reply With Quote
Old 12-08-2014, 09:46 PM   #39
themajesticone
themajesticone's Avatar
Drives: '13 UM86
lollllllllllllllllllll
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 12-09-2014, 06:53 PM   #40
ssyed
ssyed's Avatar
Drives: 2013 Frs
UPDATE:
This week, I've had it unplugged and never had any issues with starting the car after parking for a few days.
Well, I am glad to know, I wasn't the only one with this issue. Simply because its reassuring that it couldn't have been anything other than OFT. Last week when my car wouldn't start, I am sure nothing else could have been consuming power other than the OFT. Anyway, just for precaution, I keep jumper cables in my car now.
ssyed is offline   Reply With Quote
The Following 2 Users Say Thank You to ssyed For This Useful Post:
Shiv@Openflash (12-09-2014), Tenchi (12-09-2014)
Old 12-11-2014, 12:17 PM   #41
connorlug
Drives: #1553 10 Series FRS
Somebody with an OFT just needs to check parasitic draw with it plugged in. Take your multimeter, put one end on the negative battery post and one on the negative battery terminal and lift the terminal off, keeping the 2 meter ends on their respective spots. Obviously make sure the car is locked and has been so for more than a few minutes. The draw should be less than 40-50mA.
connorlug is offline   Reply With Quote
Old 12-11-2014, 12:33 PM   #42
s2d4
s2d4's Avatar
That would just be the total draw.
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 09:35 PM
filled up w e85 now car wont start..id1000s dw65s jdl kit kingkai23 Forced Induction 8 07-24-2014 10:56 AM
car wont start, winjet to blame?? 7M-King Cosmetic Modification (Interior/Exterior/Lighting) 21 12-29-2013 03:34 PM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 01:01 AM
URGENT : CAR WONT START DarkCard Engine, Exhaust, Transmission 9 08-01-2013 08:57 PM
