#29 | |
SLO NO MO
Sent from my Nexus 5 using Tapatalk |
#30 |
Drives: 14 WRB BRZ Limited MT
![]() ![]() see the difference? the v3 spacers (only the 20mm I believe) comes with bigger lugs, so it pokes out more, causing the rims to not clear
#31 | |
Drives: FR-S & BRZ
You will need 25mm all around to fit the V3 spacers on blue series wheels. We have a couple recent confirmations. We Have not had reported issues till now! Sorry about the inconvenience. The stock wheels seem to have a deeper and wider recess in between the stud holes which allow them to run the 20mm fronts. Thanks, Mike |
#32 |
Drives: FR-S & BRZ
Its not that the 20 or 25mm have longer studs, but as you can tell, the 20mm has less aluminum spacer portion, which means that the stud protrudes a bit with the lug nut as you bolt it on the hub.
| The Following User Says Thank You to Corner3garage For This Useful Post: | Foobar (12-04-2014) |
#33 |
#34 | |
Drives: Subaru BRZ Edition Blue
on facebook their name is Aspec Industries https://www.facebook.com/AspectIndustries |
#35 | |
Drives: 2015 BRZ, Aozora Edition
25/30 is a bit wider than I'd like to go, but if that is what I'd need to have my Aozora/S.B rims to work, then i might just do it... or do 25mm all around. Thoughts?
iLaw
2020 Subaru Crosstrek Sport 2015 Subaru BRZ Aozora Edition (Sold) |
#36 |
poverty cause racecar
Drives: Subaru BRZ JRSC'd
With 20mm spacers your wheels will be inset about 10mm more than my track setup that I had on my car with the GTF2s @iLaw ,so if you still remember what mine looked like at the cruise then just base it on that :P
#37 |
Sorry to resurrect this, but @lamune has pictured here 20mm (top) and 25mm (bottom) spacers from H&R
My final question is will H&R 20mm spacers clear the Series.Blue rims? or is 25mm the thinnest spacer I can go with?
iLaw
2020 Subaru Crosstrek Sport 2015 Subaru BRZ Aozora Edition (Sold) Last edited by iLaw; 01-05-2015 at 10:47 PM. |
#38 | |
#39 |
Sorry, Yes the 20mm spacer will fit? Or Yes 25mm is the thinnest spacer I can use?
iLaw
2020 Subaru Crosstrek Sport 2015 Subaru BRZ Aozora Edition (Sold) Last edited by iLaw; 01-06-2015 at 12:59 PM. |
#40 |
The H&R 20mm spacer will clear blue.series STI wheels.
| The Following User Says Thank You to lamune For This Useful Post: | iLaw (01-06-2015) |
#41 |
Thank you!
iLaw
#42 |
Drives: '13 BRZ Ltd WRB
My last set of wheels had stud pockets similar to the series.blue wheels pictured, and with them powdercoated (adds some thickness) I had to run 22mm to clear stock studs. I was using PSM adjustable spacers. I never bothered to use the spacers with stock wheels. Mostly because Discount Tire won't even touch the car if it has spacers on...so annoying.
As for performance, the wider scrub can make steering a bit more sloppy, but I don't think it's enough to lose sleep over. For tracking, best to just have a dedicated spare set of wheels that are appropriately sized and tires you don't want to commute with.
| what bushing should i get for better handling | nearvincent | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 10-15-2014 05:26 PM |
| Guys, would you say our FRS's handling is same or better than BMW's? | 2082FRS | FR-S / BRZ vs.... | 125 | 06-06-2014 12:30 AM |
| Best handling car? | gt8613 | FR-S / BRZ vs.... | 154 | 10-07-2013 10:57 PM |
| Best handling IS ever ! All real footages | Whitigir | Other Vehicles & General Automotive Discussions | 0 | 06-17-2013 09:12 AM |
| A Testimony To The FR-S's Handling | skoodge | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 06-08-2012 07:36 AM |
