Old 12-04-2014, 07:04 PM   #29
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by cameronjones239 View Post
Corner3 front 20mm do not clear as I've found out today. The 25mm clear it fine so now I'm debating finding another 25mm or getting 30mm for the rear. It'll be sitting on the eibach pro kit for the time being
What doesn't clear? Going by canehda's explanation above, I don't understand why the 25 would work but the 20 wouldn't. Does the 25 have longer studs?
Old 12-04-2014, 07:29 PM   #30
lamune
Drives: 14 WRB BRZ Limited MT
see the difference? the v3 spacers (only the 20mm I believe) comes with bigger lugs, so it pokes out more, causing the rims to not clear
Build:
"AWW YEA" < RIP
lamune is offline   Reply With Quote
The Following 3 Users Say Thank You to lamune For This Useful Post:
8R6 (08-24-2015), Foobar (12-04-2014), Koa (12-04-2014)
Old 12-04-2014, 07:58 PM   #31
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
Originally Posted by Koa View Post
Thanks for the heads up! Using my incredibly terrible internet e-measurement goggles, those look to be the same length stud to me. Maybe @Corner3garage could chime in with a length?
Studs are just about an inch long, measured from the spacer.
You will need 25mm all around to fit the V3 spacers on blue series wheels.
We have a couple recent confirmations.
We Have not had reported issues till now!
Sorry about the inconvenience.
The stock wheels seem to have a deeper and wider recess in between the stud holes which allow them to run the 20mm fronts.
Thanks,
Mike
Corner3garage is offline   Reply With Quote
Old 12-04-2014, 08:00 PM   #32
Corner3garage
Drives: FR-S & BRZ
Its not that the 20 or 25mm have longer studs, but as you can tell, the 20mm has less aluminum spacer portion, which means that the stud protrudes a bit with the lug nut as you bolt it on the hub.
The Following User Says Thank You to Corner3garage For This Useful Post:
Foobar (12-04-2014)
Old 12-04-2014, 10:15 PM   #33
Koa
crystal, ty! Was looking at the wrong studs, ha
Old 12-04-2014, 11:41 PM   #34
santir
Drives: Subaru BRZ Edition Blue
Originally Posted by iLaw View Post
Looks awesome. What spacers did you use? Did you have to modify your studs?
no modification of studs, been on for 4k miles with no problem! and no idea of the brand! box is somewhere! haha. a local shop ordered them for me!
on facebook their name is Aspec Industries https://www.facebook.com/AspectIndustries
santir is offline   Reply With Quote
Old 12-05-2014, 08:00 PM   #35
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
Originally Posted by santir View Post
i have a series.blue also... i used 25mm front 30mm rear. it makes the sti wheels looks better! but still doesnt help the skinny tire issue!! haha
Any chance you could take a picture from the back of the car, looking down the side?
25/30 is a bit wider than I'd like to go, but if that is what I'd need to have my Aozora/S.B rims to work, then i might just do it... or do 25mm all around.
Thoughts?
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Old 12-05-2014, 08:37 PM   #36
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
With 20mm spacers your wheels will be inset about 10mm more than my track setup that I had on my car with the GTF2s @iLaw ,so if you still remember what mine looked like at the cruise then just base it on that :P
Canehda is offline   Reply With Quote
Old 01-05-2015, 09:29 PM   #37
iLaw
iLaw's Avatar
Sorry to resurrect this, but @lamune has pictured here 20mm (top) and 25mm (bottom) spacers from H&R
My final question is will H&R 20mm spacers clear the Series.Blue rims? or is 25mm the thinnest spacer I can go with?
iLaw
Old 01-06-2015, 01:16 AM   #38
lamune
Yes.
Build:
"AWW YEA" < RIP
Old 01-06-2015, 02:07 AM   #39
iLaw
iLaw's Avatar
Yes.
Sorry, Yes the 20mm spacer will fit? Or Yes 25mm is the thinnest spacer I can use?
iLaw
Old 01-06-2015, 11:56 AM   #40
lamune
The H&R 20mm spacer will clear blue.series STI wheels.
Build:
"AWW YEA" < RIP
The Following User Says Thank You to lamune For This Useful Post:
iLaw (01-06-2015)
Old 01-06-2015, 12:00 PM   #41
iLaw
iLaw's Avatar
Thank you!
iLaw
Old 01-06-2015, 12:56 PM   #42
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
My last set of wheels had stud pockets similar to the series.blue wheels pictured, and with them powdercoated (adds some thickness) I had to run 22mm to clear stock studs. I was using PSM adjustable spacers. I never bothered to use the spacers with stock wheels. Mostly because Discount Tire won't even touch the car if it has spacers on...so annoying.
As for performance, the wider scrub can make steering a bit more sloppy, but I don't think it's enough to lose sleep over. For tracking, best to just have a dedicated spare set of wheels that are appropriately sized and tires you don't want to commute with.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
what bushing should i get for better handling nearvincent Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-15-2014 04:26 PM
Guys, would you say our FRS's handling is same or better than BMW's? 2082FRS FR-S / BRZ vs.... 125 06-05-2014 11:30 PM
Best handling car? gt8613 FR-S / BRZ vs.... 154 10-07-2013 09:57 PM
Best handling IS ever ! All real footages Whitigir Other Vehicles & General Automotive Discussions 0 06-17-2013 08:12 AM
A Testimony To The FR-S's Handling skoodge Scion FR-S / Toyota 86 GT86 General Forum 25 06-08-2012 06:36 AM
