Old 12-03-2014, 04:31 PM   #15
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by Koa View Post
by far, the best spacers out there. For value and quality. You cannot beat $100 for a set.
http://www.corner3garage.com/V3-Spac...WRX_p_482.html
This is what I have as well.
Old 12-03-2014, 04:45 PM   #16
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Yeah I'm running like 25mm of spacers up front on extended wheel studs. Steering feels a bit lighter.
I'm going to be getting RacerX FLCAs to widen the front track and when I do, I'll remove some of those spacers
Old 12-03-2014, 04:45 PM   #17
lamune
Drives: 14 WRB BRZ Limited MT
Those (the 20mm's) may not clear blue.series wheels that the OP has.
Someone on the forum actually PM-ed me saying his wheels didn't clear the 20mm v3 spacers and suggested grabbing low profile lugs
I put H&Rs about a week ago, here's how 20 in the front looks:
Build:
"AWW YEA" < RIP
lamune is offline   Reply With Quote
Old 12-03-2014, 04:48 PM   #18
Koa
Thanks for the heads up! Using my incredibly terrible internet e-measurement goggles, those look to be the same length stud to me. Maybe @Corner3garage could chime in with a length?
Old 12-03-2014, 08:03 PM   #19
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
Are the stock wheels and Series.Blue wheels not the same spec? It seems like a lot of people are running the H&R Spacers 20/25 without issue...
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Old 12-03-2014, 08:52 PM   #20
lamune
Yes they are the same size, but it's this gap that is different:
blue.series
stock
Build:
"AWW YEA" < RIP
Old 12-03-2014, 08:53 PM   #21
iLaw
iLaw's Avatar
Sorry. Forgive my noob-ness. But what am I looking for?
iLaw
Old 12-03-2014, 09:33 PM   #22
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
On the stock wheels the whole hub sits flush against the wheel except for the areas where the wheel is hollowed out (doesn't make a difference in how the hub sits on the wheel) but on the blue series there are protrusions on the wheel between the main body of the wheel and the hub which you can see in the first picture. The protrusions push the wheel away from the hub/spacer and apparently make the wheel hub thicker than oem which may reduce the size of stud you're left with once the wheel is mounted.
Canehda is offline   Reply With Quote
Old 12-04-2014, 10:28 AM   #23
iLaw
iLaw's Avatar
Ah. Alright. Thanks for the explanation. Makes sense now.
So a solution would be extended studs or low-profile lugs? Anyone have recommendations?
iLaw
Old 12-04-2014, 10:57 AM   #24
santir
Drives: Subaru BRZ Edition Blue
Originally Posted by Pkush View Post
I had the same question in mind...and I drive a Series.Blue too. I want to keep the wheels, but they're so not flush it hurts my eyes.
i have a series.blue also... i used 25mm front 30mm rear. it makes the sti wheels looks better! but still doesnt help the skinny tire issue!! haha
santir is offline   Reply With Quote
Old 12-04-2014, 11:08 AM   #25
iLaw
iLaw's Avatar
Looks awesome. What spacers did you use? Did you have to modify your studs?
iLaw
Old 12-04-2014, 12:46 PM   #26
lamune
what I'm saying is I'm not sure the v3 20mm spacers clear the fronts. I have H&R's and they are fine without anything extra.
Build:
"AWW YEA" < RIP
Old 12-04-2014, 01:37 PM   #27
iLaw
iLaw's Avatar
Ah. Awesome. Thanks for clarifying. Makes my purchasing a lot simpler.
iLaw
Old 12-04-2014, 06:58 PM   #28
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
Corner3 front 20mm do not clear as I've found out today. The 25mm clear it fine so now I'm debating finding another 25mm or getting 30mm for the rear. It'll be sitting on the eibach pro kit for the time being
cameronjones239 is offline   Reply With Quote
what bushing should i get for better handling nearvincent Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-15-2014 04:26 PM
Guys, would you say our FRS's handling is same or better than BMW's? 2082FRS FR-S / BRZ vs.... 125 06-05-2014 11:30 PM
Best handling car? gt8613 FR-S / BRZ vs.... 154 10-07-2013 09:57 PM
Best handling IS ever ! All real footages Whitigir Other Vehicles & General Automotive Discussions 0 06-17-2013 08:12 AM
A Testimony To The FR-S's Handling skoodge Scion FR-S / Toyota 86 GT86 General Forum 25 06-08-2012 06:36 AM
