#29 |
I had infinity kappa's in my last car and these don't hold a candle to them.
I don't think I'm going to be able to use infinity Kappas again. Most of them have a fairly deep mounting depth and most of these mounts are pretty shallow. |
#30 |
Drives: 2016 Toyota 4Runner Trail Premium
#31 |
Site Moderator
Drives: Stuff
I agree. Would you go IB or sealed? I'd consider trying IB it's just so much more effort :P
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#32 | |
Site Moderator
Drives: Stuff
Is there any room for spacers? I might have some newer Kappas laying around assuming I didn't throw them in the trash, I wasn't impressed at all sadly
-Dave
#33 |
Drives: 2009 135i
damn those are not bad speakers for a stock <30k car!
#34 |
Here's a pic with the speaker removed on the door. If you can get your speakers to miss the window you'd be okay. You could probably raise them up a bit but You'd have to start trimming the door panel to get it to fit.
![]() Uploaded with ImageShack.us |
#35 |
Site Moderator
Drives: Stuff
Hmm I have a couple random drivers sitting around so I'll have to do some test fitting
-Dave
#36 |
Drives: 2015 Dodge Challenger SXT
Damn, I hope the actual mounting depth for the 6.5's in the doors are more than only 2", I have 2 pairs of Infinity Kappa component speakers I pulled out of my Magnum before I traded it in and I was planning on putting a set of them into the BRZ since they are really good speakers, not to mention expensive, but they have I believe about a 2 1/2" mounting depth.
#37 |
That's what I want to put in the doors as well. I'm going to check again tonight. I think with the bracket and maybe a shim they will fit okay.
#38 |
#39 | |
Site Moderator
Drives: Stuff
![]() I use oak usually for mine. Harder to deal with, but a much better solution.
-Dave
#40 |
You could probably fit some subs were the rears are but you would have to make a from scratch bracing to hold it up. It would depends on how deep they where too.
I'm just going to run a single 10 in the trunk for now. I got some more meansurements for the doors as well. The Infinity Kappa components are going to pit no problem. I was measuring from the door metal opening to the window. From there I'd say you have 2.25" of depth. Might be able to get some more but I wouldn't. The factory speakers are heald up into the door panel by their bracket so that gives another inch. I thinking about trying http://www.crutchfield.com/p_142SAT6...er-reviews-tab and http://www.crutchfield.com/p_003SG60...ng.html?tp=919 to build the mounting bracket. I do love how easily the panels can be taken apart. None of the speakers are very hard to get to. |
#41 |
Site Moderator
Drives: Stuff
I looked at mine through the door panel, there's a TON of space between the speaker and door panel.. so a 1" spacer (compared to whatever the stock one is) shouldn't post any problems on all but high xmax drivers. So if the stock spacer is 1" as noted above, then a 2" spacer should fit..
-Dave
#42 |
Drives: 2011 WRX
![]() Can anyone measure the distance between the 3 OEM mounting holes inthe dood skin? I have a suspicion that they are the same as in most Subaru vehicles, +/- a mm or so. |
| New Wheel Sizes/Photos from Rays / Volks | BPAuto | Wheels and Tires | 68 | 12-12-2013 06:14 PM |
| Stock FRS Headunit/Speaker preformance | jflogerzi | Electronics | Audio | NAV | Infotainment | 8 | 06-03-2012 02:03 AM |
| 8 Speaker stereo specs? | Rstalter77 | BRZ First-Gen (2012+) — General Topics | 56 | 04-24-2012 05:43 AM |
| Thoughts on ease of speaker replacement? | ahausheer | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 11-29-2011 12:16 PM |
