Old 06-18-2012, 10:57 AM   #29
GremlinGSP
I had infinity kappa's in my last car and these don't hold a candle to them.
I don't think I'm going to be able to use infinity Kappas again. Most of them have a fairly deep mounting depth and most of these mounts are pretty shallow.
GremlinGSP is offline   Reply With Quote
Old 06-18-2012, 11:04 AM   #30
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
Originally Posted by GremlinGSP View Post
The Rear are 3.5 as well but the depth is more than enough.
Hard to tell from the pic but it would be nice to fit some 8" subs in place of the rear speakers. From seeing it first hand what do you think?
sure74 is offline   Reply With Quote
Old 06-18-2012, 11:07 AM   #31
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I agree. Would you go IB or sealed? I'd consider trying IB it's just so much more effort :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-18-2012, 11:08 AM   #32
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You sure on the door depth? I need to take mine apart soon to measure..
Is there any room for spacers?
I might have some newer Kappas laying around assuming I didn't throw them in the trash, I wasn't impressed at all sadly
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-18-2012, 11:12 AM   #33
bimmerboy
Drives: 2009 135i
damn those are not bad speakers for a stock <30k car!
bimmerboy is offline   Reply With Quote
Old 06-18-2012, 11:22 AM   #34
GremlinGSP
Here's a pic with the speaker removed on the door. If you can get your speakers to miss the window you'd be okay. You could probably raise them up a bit but You'd have to start trimming the door panel to get it to fit.
Uploaded with ImageShack.us
Old 06-18-2012, 12:40 PM   #35
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Hmm I have a couple random drivers sitting around so I'll have to do some test fitting
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-18-2012, 03:13 PM   #36
Shizuma
Shizuma's Avatar
Drives: 2015 Dodge Challenger SXT
Damn, I hope the actual mounting depth for the 6.5's in the doors are more than only 2", I have 2 pairs of Infinity Kappa component speakers I pulled out of my Magnum before I traded it in and I was planning on putting a set of them into the BRZ since they are really good speakers, not to mention expensive, but they have I believe about a 2 1/2" mounting depth.
Shizuma is offline   Reply With Quote
Old 06-18-2012, 03:40 PM   #37
GremlinGSP
That's what I want to put in the doors as well. I'm going to check again tonight. I think with the bracket and maybe a shim they will fit okay.
Old 06-18-2012, 03:42 PM   #38
sure74
sure74's Avatar
Should definitely cut a new baffle out of MDF, no need to reuse the plastic bracket thing.
Old 06-18-2012, 05:41 PM   #39
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Use a hard wood instead, or paint the MDF really well.. the doors get wet. I've seen more spacers/baffles made of out MDF swell in door than I care to see
I use oak usually for mine. Harder to deal with, but a much better solution.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
kmbkk (06-18-2012), Scooby (06-19-2012)
Old 06-18-2012, 10:29 PM   #40
GremlinGSP
You could probably fit some subs were the rears are but you would have to make a from scratch bracing to hold it up. It would depends on how deep they where too.
I'm just going to run a single 10 in the trunk for now.
I got some more meansurements for the doors as well. The Infinity Kappa components are going to pit no problem. I was measuring from the door metal opening to the window. From there I'd say you have 2.25" of depth. Might be able to get some more but I wouldn't.
The factory speakers are heald up into the door panel by their bracket so that gives another inch.
I thinking about trying
http://www.crutchfield.com/p_142SAT6...er-reviews-tab
and
http://www.crutchfield.com/p_003SG60...ng.html?tp=919
to build the mounting bracket.
I do love how easily the panels can be taken apart. None of the speakers are very hard to get to.
Old 06-18-2012, 10:47 PM   #41
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I looked at mine through the door panel, there's a TON of space between the speaker and door panel.. so a 1" spacer (compared to whatever the stock one is) shouldn't post any problems on all but high xmax drivers. So if the stock spacer is 1" as noted above, then a 2" spacer should fit..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-09-2012, 12:13 PM   #42
phenryiv1
Drives: 2011 WRX
Can anyone measure the distance between the 3 OEM mounting holes inthe dood skin? I have a suspicion that they are the same as in most Subaru vehicles, +/- a mm or so.
phenryiv1 is offline   Reply With Quote
New Wheel Sizes/Photos from Rays / Volks BPAuto Wheels and Tires 68 12-12-2013 05:14 PM
Stock FRS Headunit/Speaker preformance jflogerzi Electronics | Audio | NAV | Infotainment 8 06-03-2012 01:03 AM
8 Speaker stereo specs? Rstalter77 BRZ First-Gen (2012+) — General Topics 56 04-24-2012 04:43 AM
Thoughts on ease of speaker replacement? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 36 11-29-2011 11:16 AM
