Old 07-14-2012, 02:07 AM   #29
Ebay
Toyota Employee
Drives: 1991 Q45 & 2013 FR-S
No problem starting, did stall it once at stop light, car doesn't like slow take off at low rpm. Front left speaker seems to rattle, not sure why? Doesn't appear to be anything visibly wrong with it.
Ebay is offline   Reply With Quote
Old 07-14-2012, 02:16 AM   #30
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by YukiHachiRoku View Post
The front left speaker on the dash, the plastic part of the speaker holes will pop out of alignment from the dash, it's really annoying. I press it back down, but it keeps popping back out, any suggestions? Anyone else having this problem?
I realized I never made a thread to mention this when I should have, this problem is due to the speakers wiring harness pushing the grill up. Stuff the harness deep in there and you'll be fine. The dealer/SOA figured out this fix for me, 3 weeks now and it's been fine.
Edit: I originally had my speaker grill replaced because they thought it was warped. The grill/clips are NOT the root cause.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
YukiHachiRoku (07-14-2012)
Old 07-14-2012, 05:53 AM   #31
450hp/tonne
Drives: 2011 Corolla Ascent Sport
Glad to hear of a dealer who found the actual cause! I'm sure there will be an official instruction to dealers soon (if not already).
Adheadive and tape will not fix the cause of the problem, either would replacing the entire dash (expect more problems from that than what you have now). Keep in touch with your dealer and keep asking if there is an official fix.
450hp/tonne is offline   Reply With Quote
Old 07-26-2012, 06:47 PM   #32
andy19804
Drives: 6MT Asphalt FR-S
My passenger side dash grill popped up. After 2nd visit to dealer they ordered new one that was installed last night. So far so good.
andy19804 is offline   Reply With Quote
Old 07-26-2012, 07:28 PM   #33
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
If you're wondering, yes my speaker grill is fine still. The grill is NOT defective. It's simply the gubbins under the grill.
Old 08-17-2012, 12:56 AM   #34
2013BRZ
2013BRZ's Avatar
Drives: 2013, Galaxy Blue Silica, Limited
Not true
Originally Posted by sierra View Post
The GTS version here has push button start and the fuel pump primes before it starts, you have no choice.
That suggests that letting it prime for a couple of secs is a good thing.
Not true. On the Limited model equipped with push button start, you can turn on accessories and theoretically prime the pump by pushing the button once ore twice before actually depressing the clutch to start it. Psh, "GTS version"...
2013BRZ is offline   Reply With Quote
The Following User Says Thank You to 2013BRZ For This Useful Post:
Chad86 (12-07-2016)
Old 08-19-2012, 09:15 AM   #35
proficience
proficience's Avatar
Drives: Velocity Orange 86 GTS M/T
I had 1 long turnover (5secs) once when I had about 300kms on the clock. Never since! Im on 1,000km now. Seemed like a once off
proficience is offline   Reply With Quote
Old 04-25-2013, 03:43 PM   #36
louis
Drives: BRZ Limited - Silver
Any idea what is causing it?
louis is offline   Reply With Quote
Old 04-25-2013, 05:24 PM   #37
strat61caster
strat61caster's Avatar
What's it? The speaker "rasp" or "rattle" is parts not fitting together well enough and vibrating, happens in every car.
The "hard start" is likely this:
http://www.ft86club.com/forums/showp...7&postcount=11
ineedyourdiddly
Old 04-28-2013, 12:24 PM   #38
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Well, The rasp is more of a static noise than a vibration noise. It's almost impossible for me to replicate other than the fact it only happens when I have a device plugged into the USB port, and it only occurs when i drive. I'm guessing it's a bad wire that's causing feedback somewhere.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 04-30-2013, 06:13 PM   #39
Fenrir
Drives: Mazdaspeed 3
Look up ground loop isolators. That should solve your problem. They're cheap and easy to install.
Link here for example. Don't get one from there, though, those are pretty overpriced. Should give you an idea what to look for though with a good explanation of who/what/why. I'd recommend one for any car audio application.
Fenrir is offline   Reply With Quote
Old 04-30-2013, 06:47 PM   #40
Hawaiian
That guy
Hawaiian's Avatar
Thanks, although that should be a warranty thing since it's the factory audio.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 05-01-2013, 01:56 PM   #41
Fenrir
Let me know if you take it in. From experience, audio issues like that are caused by some insignificant power line run too close to a speaker wire, something that fell out of a clip and is rubbing, or a cable that got caught under a bolt during installation. Very, very difficult to track down and diagnose. Definitely not worth the effort, IMO, but I'm curious what the dealer will say. I know my stock radio doesn't make that noise, but I have a BRZ which is a different sound system.
Old 06-08-2013, 03:29 PM   #42
Huggsen
Drives: 2013 Scion FR-S Raven
It is a warranty thing, I have been chasing this one down for a few months. I have had all the speakers on the drivers side replaced and the noise which to me sounds like (someone crunching up a plastic sack over a cell phone) is still there.
I dont think it is a ground loop as i experience no power pops, surges, or alt whine. could be the cheap quality of the OEM speakers. Not sure at this point.
Huggsen is offline   Reply With Quote
Speaker Sizes Thefuzz Electronics | Audio | NAV | Infotainment 68 05-28-2021 06:18 PM
Popped up dashboard speaker grill Laika BRZ First-Gen (2012+) — General Topics 8 06-20-2012 11:35 PM
Rattle in door speaker panels Lefty Electronics | Audio | NAV | Infotainment 2 06-18-2012 06:41 PM
8 Speaker stereo specs? Rstalter77 BRZ First-Gen (2012+) — General Topics 56 04-24-2012 04:43 AM
Thoughts on ease of speaker replacement? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 36 11-29-2011 11:16 AM
