Old 09-16-2014, 03:14 PM   #29
stonenewt
Drives: BMW 120d
Originally Posted by chrisl View Post
I try to set up any car pretty much as described in this video:
Almost there in my 1er. Steering wheel a little too far away, about 15-20mm from perfect but it doesn't feel quite right. However when it's in the right spot I can't see the 40, 60 & 80mph ticks on the speedo
stonenewt is offline   Reply With Quote
Old 09-16-2014, 08:01 PM   #30
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Originally Posted by aznatama View Post
I wouldn't call it more hunched over, and a sports car is nowhere near "laid back" if you're seated properly. It really all depends on how you personally want to sit and adjust the seat to some extent. The steering wheel angle is taken into account depending on the style of car, but it's usually nothing that can't be adjusted for. Afterall, even semi-trucks are raced, with their huge almost horizontal steering wheels...
Originally Posted by krayzie View Post
You'll be surprised how close the driving position is between a Boxster and a Golf GTI once everything is adjusted properly.
NSX, supra, 240sx, mr2, 3000gt, rx7, 350z, Corvette...
Sit in a sports car, you'll instantly recognize it to be driver centric. Sit in your golf, well... you can always put a Recaro in your golf if you really want ahah.
But a good interior design is always when your hand instantly falls onto the shifter symbiotically. I still feel the FRS cockpit falls short to that of the mk4 Supra and even my sw20. The FRS seats are obviously tons better, but I prefer a "wrapped" feeling interior with the center console up high so your arm can lay flat to shift extremely comfortably. S2000 is another prime example of a wrapped type cockpit with the center console high for to relax your shifter arm on.
Econoboxes have econobox seating. /The end
hmong337 is offline   Reply With Quote
Old 04-08-2017, 03:21 PM   #31
HamburgerSushi
Drives: 2017 Subaru BRZ 6MT, Perf Pack
Hi guys - I'm 6'1", 34" inch inseam
I'm wondering if there is a fix to raise the lower part of the seat to support my thighs better when driving. Right now I have some space between the seat and my thighs, which can be fatiguing.
I was thinking about finding some bolts with the same thread as the BRZ rails but longer, with a spacer between the floor's bolt-in position and the rails. I don't like that the rails would be floating though.
Any ideas?
HamburgerSushi is offline   Reply With Quote
Old 04-08-2017, 04:08 PM   #32
~el~jefe~
Drives: 2019 MX-5 RF
2' 8", seat all the way down, upright, standing with helmet.
eeeeeeeee!!!!!!!!!!!!!!!!!
~el~jefe~ is offline   Reply With Quote
Old 04-08-2017, 04:10 PM   #33
brz11b
Drives: United States
6'1''
seat all the way back, slight recline and sterling wheel as fat towards the seat as possible and i believe its tilted all the way up.
brz11b is offline   Reply With Quote
Old 04-08-2017, 04:10 PM   #34
~el~jefe~
I am 5' 7" with a 15" inseam. My junk hangs so low, pants have to be cut that way.
Drive man-spread with one leg in passenger seat to give room for groin. Slight seat tilt.
Old 04-08-2017, 04:28 PM   #35
Ultramaroon
not playing cards
Ultramaroon's Avatar
Old 04-08-2017, 07:07 PM   #36
g e
5' 11" 32/34 inseam depending on the pants. 34" shirt sleeves
Steering close to vertical , mid point extension. Seat two pumps up from bottom and maybe 2" ahead of all back position.
Windows open.
g e is offline   Reply With Quote
Old 04-08-2017, 08:00 PM   #37
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I didn't read all the posts but the preferred position when your shoulders are planted in the seat is to have your wrists on top of the wheel. Most people sit too far back.
Old 04-08-2017, 08:20 PM   #38
Ultramaroon
not playing cards
I'm in favor of it.
Old 04-08-2017, 09:06 PM   #39
spike021
spike021's Avatar
Yeah, my positioning works out similarly to that. When my dad taught me to drive he basically said there should be enough arm length to the wheel that the arms are never completely flat/straight when holding the wheel comfortably. That just about means wrists on top of the wheel or maybe an inch or so further.
spike021 is offline   Reply With Quote
Old 04-09-2017, 11:56 AM   #40
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Fill the footwells with packing peanuts then pile them wherever needed.
Brush them back on the floor before getting out?
Old 04-09-2017, 02:18 PM   #41
subiebui
Drives: 2017 STi WRB
5'7 with 29 inseam. Track driving I had the seat full down and pretty seat forward enough to depress the clutch completely with a slight bend in the knee, steering wheel full down and as far towards the dash as possible. Seat back pretty much vertical. I close enough to where my wrists were over the wheel while my back and shoulders were flat against the seat. Normal driving I was a couple inches back with a slight recline in the seat, steering wheel was a close to the thumbs when reaching out. Was comfortable when driving four hour trips to nj
subiebui is offline   Reply With Quote
Old 04-09-2017, 02:33 PM   #42
Shinchu
Shinchu's Avatar
Drives: 2016 FR-S Asphault MT
5'11, 34x34 jeans. Im a bit leggy (catcall)
My seat is a couple clicks forward from full rear.
A couple clicks of recline.
Max low.
Steering wheel is halfway down, fully extended.
I can depress clutch with a comfortable bent, but not so much that i get tangled in the wheel while doing heel toe stuff. It gets a little tight though. I find the closer i sit (slide in toward wheel) the more room i have for my giraffe legs. Its weird but it works. Car is super comfy and feels great cruising or spirited.
I was going to upgrade the seats, but i dont see a reason, unless i need lateral g support when i finally slide this thing at its first drift event. Still need to do that!
TEAM HINGA | Shift-Lock.net | Club4AG
http://www.poweredbymax.net/
Shinchu is offline   Reply With Quote
HID headlight position setting radroach BRZ First-Gen (2012+) — General Topics 28 01-31-2014 04:21 PM
Whats with the chicks and bro's driving... Pacific Auto Scion FR-S / Toyota 86 GT86 General Forum 65 01-12-2014 03:03 PM
Satnav antenna position notout86 Electronics | Audio | NAV | Infotainment 1 06-14-2013 03:01 AM
Headrest position Sigh-on-Rice Scion FR-S / Toyota 86 GT86 General Forum 2 06-15-2012 01:28 PM
whats the best driving sim? Kazama Off-Topic Lounge [WARNING: NO POLITICS] 9 12-24-2011 07:04 PM
