Old 08-29-2014, 01:16 AM   #15
It's absolutely not normal.
Have them fix it immediately; it's just a SINGLE adjustment, that should take 2 tries at most with an experienced tech. Quick adjustment, test drive, final adjustment, test drive, done. Under 10 minutes total.
abraxis (08-29-2014), wparsons (08-29-2014)
Old 08-29-2014, 01:44 AM   #16
abraxis
Drives: many
Yup, actually pretty common mistep with techs that aren't seasoned with suspension work. Shadetree mechanics can find themselves doing the same thing working at home on their suspension with a jack.
abraxis is offline   Reply With Quote
Old 08-29-2014, 03:15 AM   #17
Maverickgear
Drives: World Rally Blue BRZ
Thanks for the input guys. Will try my best to get a refund on this. Something just ain't right.
On the bright side, I have decided to switch to a quality route within my budget and have gotten myself a set of Konis and now am deciding between Swifts or RCEs. Hopefully this will perform better than this set of cheap-ish coils
Maverickgear is offline   Reply With Quote
Old 08-29-2014, 03:43 AM   #18
Knshro13
Drives: 10 series FRS
Did they check tire pressures before starting the work? Believe it or not, inconsistent tire pressures can pull your car to one side.
Knshro13 is offline   Reply With Quote
Old 08-29-2014, 03:45 AM   #19
Maverickgear
Yeah, I did check the pressures myself before the job was done.
DIY Alignment FRSFirestorm DIY (Do-It-Yourself) Guides 41 01-31-2020 07:06 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Alignment in GTA? f0rge CANADA 13 09-06-2013 12:17 PM
where to get alignment? FML Hawaii 2 08-08-2012 01:36 AM
