Old 11-30-2014, 01:09 AM   #29
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Cool
I run 94 octane. Would the best tune for 94 octane be Stage 1 93 ?
Will there be a 94 tune?
Just about to pull the trigger...Black Friday $40 discount.
Chad86 is offline   Reply With Quote
Old 11-30-2014, 01:19 AM   #30
Chad86
Chad86's Avatar
Drives: Toyota GT86
Cool
Trigger pulled
The Following 2 Users Say Thank You to Chad86 For This Useful Post:
Arcadien Angel (12-14-2014), D_Thissen (12-24-2014)
Old 12-14-2014, 02:49 PM   #31
Arcadien Angel
I may be an idiot
Arcadien Angel's Avatar
Drives: Winona - White 2014 Scion FR-S
I've got my own OFT on the way, should get it in a week or so. And I was just wondering something.
I'm currently running 93 gas, Injen CAI, P&L Overpipe and catless Frontpipe, Greedy... I mean GReddy Supreme SP catback, and a whole slew of lightweight pulleys. All of which have their own merits, and I'm happy with them. But will the ST1 tune work with these parts for an even better overall setup? And is the ST1 tune the best choice here?
I'm assuming so since I don't have an aftermarket header or E85.
Sent from my DROID3 using Tapatalk 2
Winona, My Wingless Angel
Edelbrock SC w/ Flex Fuel - 18x9.5 Titan 7 wheels w/ 265/35x18 Michelin PS4S - Radium Dual Catch Cans - Verus Aero - OEM Brembos - Prototype HVT 6100e Dynamic Dampening Coilovers - JDL 4-2-1 EL / OP / Dual Catted FP w/ Greddy SP Supreme Catback
Arcadien Angel is offline   Reply With Quote
Old 12-14-2014, 03:00 PM   #32
Foobar
SLO NO MO
Foobar's Avatar
Yup. Stage 1 93 octane is what you want.
Old 12-14-2014, 03:10 PM   #33
mid_life_crisis
Drives: FR-S 10 #103 AT
Don't forget that you can datalog. With a cat out of the system, you might try stage2 and stage1 and see which feels better and yields the cleanest logs.
Old 12-14-2014, 04:49 PM   #34
steve99
The injen intake may upset the maf scaling can be fixed by rescaling maf.
on petrol the safest tune for yu will be the stage1 tune then correct you maf scaling if your long term fuel trims are high.
you can run E85 fuel tune on car with stock header you use Stage 2 EL E85 tune
see links below
Old 12-16-2014, 07:14 PM   #35
Arcadien Angel
I may be an idiot
Thanks for the advice. Although I'm having trouble finding the downloads for the OTS Maps. I've found several different locations with several different versions, but some don't download, some links are broken, others download corrupted. I've been trying for a couple days now with no luck. Maybe I'm just being dumb here, but can I get a link to a single trusted source provided, perhaps, by Vishnu or Shiv themselves?
Thank you,
Angel
Old 12-16-2014, 08:22 PM   #36
steve99
Thank you,
Angel
downloads here
its on openflashtablet.com select automotive tab then frs\brz\86 in dropdown menu then downloads in next dropdown
http://openflashtablet.com/Automotiv...ads/index.html
read the oft tips link below and maybe the maf scaling as you may need to scale maf with the injen intake but if its not causing dramas on stock tune will probably be acceptable on tuned rom, but couls be better if rescaled.
Chad86 (12-16-2014)
Old 12-16-2014, 10:18 PM   #37
Arcadien Angel
I may be an idiot
downloads here
Hot diggity! Thanks for the link.
So far I've had no issues with the Injen CAI, but I'll definitely look into the MAF scaling to see what I can do with it.
EDIT: I downloaded the 2.06 Maps and they say that they are for Manual, would they not also work for auto? Or should I not even try?
-Angel
Old 12-17-2014, 02:20 PM   #38
Chad86
Chad86's Avatar
Drives: Toyota GT86
Trigger pulled
Has anyone purchased from modbargains? Apparently they cancelled my order as they will not accept a CAD credit card. They want a wire transfer...sounds pretty sketchy. I guess I will be ordering through ft86speedfactory or direct from the openflash site. Any recommendations of where to purchase from?
Old 12-17-2014, 04:45 PM   #39
steve99
direct from openflash
Shiv@Openflash (12-17-2014)
Old 01-28-2015, 01:03 PM   #40
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Does this tune add 2-step? While I am not moving the rev limit is at 5100 rpm since this re-flash.
Answer is yes. The v2.0 tunes automatically adds 2-step.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 01-28-2015, 03:24 PM   #41
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
BRZworld (GTA) and I belive Slick Automotive Solutions (Ottawa) sell OFT here in CND
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 01-29-2015, 07:07 PM   #42
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by nunonuna View Post
But mine gets better mpg~ before tune 24 mpg only local, now its 27 mpg.
because you drive too slow your supposed to use the go pedal more after upgrade than you did before
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
WTB: Innovate Motorsports Stage 1 W/O Tune jjkerr626 Want-To-Buy Requests 0 01-01-2014 02:32 PM
Ecutek stage 2 tune on stock brz 01s0uljah Software Tuning 15 10-15-2013 03:52 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 07:30 AM
Perrin Stage 1 Tune brz007 Northwest 5 10-03-2012 06:59 PM
