Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
06-09-2014, 09:25 PM | #29 |
Drives: white premium brz M/T
Try checking the cam cover
06-12-2014, 11:29 PM | #30 |
Drives: Scion FR-S
Due to the oil leak being on the front passenger side of the motor I am finally getting it into another dealership on saturday. I got my car on a lift and it doesn't seem to be leaking from the cam plate... yet. It actually looks like the head gasket is leaking (I know it's a subaru) so the dealership has a set in stock just encase that is the issue.
Sent from my Q10 |
06-13-2014, 09:17 AM | #31 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
There is a reason the new 2015 sti wrx has a different motor
Mine leaks same spot
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi Last edited by kiichiro; 06-13-2014 at 09:36 AM. |
06-17-2014, 07:57 AM | #32 |
Drives: frs
any updates, has anyone got it fixed?
has anyone who's FI tried going to the dealer and see if it can be fixed under warranty? also, has anyone tried using stop leak? Last edited by vgi; 06-17-2014 at 09:58 AM. |
06-17-2014, 06:38 PM | #33 |
Reverse Burnouts
Drives: 2013 Argento FRS
mine must have been over-time, very slow leak. since the oil change i have not seen any new leaks.
i did however find a leak in my rear dif today when i changed the fluid. :/
2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
06-17-2014, 07:54 PM | #34 |
Turbo 86
Drives: GT86
can this be a recall?
10 - 1 = 0
real math |
09-17-2014, 11:46 AM | #35 |
Drives: Toyota Gt86 MT
have the same leak at the driver's side. i check the cam plate- its dry and cam plate is on the passenger's side. sitting in toyota dealership now and waiting for something..
i had a massive leak . also had a smoke |
09-17-2014, 01:57 PM | #36 |
I fixed mine but I think my setup is a little different from stock 86s. I have a t-fitting oil line running on top of the cam cover and that's where the oil was leaking. All I had to do was retape with teflon tape
09-28-2015, 12:41 AM | #37 |
Drives: None
09-28-2015, 09:43 AM | #38 |
Drives: 86
09-28-2015, 09:45 AM | #39 |
Drives: None
09-28-2015, 09:46 AM | #40 |
Drives: None
09-28-2015, 10:43 AM | #41 | |
Drives: 86
4 cam sensor o ring
4 avsc controller o ring sealant leaked area after spot it and it is same with all 86 Quote:
10-02-2015, 11:51 PM | #42 |
Drives: None
Any ideas on where it might be leaking from? My friend says it's the valve cover, I say it's either the timing belt cover or the block behind the valve cover', where the valves and valve springs meet.. Sent from my iPad using Tapatalk |
Similar Threads | ||||
Water Leak inside passenger side floorboard | AtlasMick | Issues | Warranty | Recalls / TSB | 30 | 03-28-2019 04:43 PM |
New Body Parts from WORKS | WORKS | Exterior Parts - The Rest | 2 | 06-13-2014 06:58 PM |
Tranny fluid or engine oil leak? | G.I.Choe | Issues | Warranty | Recalls / TSB | 1 | 05-28-2014 06:53 AM |
Small Oil Leak under center of engine? | brillo | Issues | Warranty | Recalls / TSB | 6 | 11-09-2013 09:52 PM |
Wanted: drivers side front fender | Yruyur | Miscellaneous | 0 | 11-26-2012 09:30 PM |
