Old 08-05-2014, 08:09 PM   #29
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Originally Posted by FRSpappa View Post
Tractor noise happened again coming to a stop. Not as loud now as the resonator has been removed feeding engine noise into the interior...
It's been a while since I've posted but it's definitely happened to me like 8 or 9 times total. And no loss of power or signs of this about to explode. It did it again today on the highway and I threw it in second and took it to 7.5k to see what would happen while it was making the noises. If the engine is gonna blow up I want it to happen already!! I need to know!
Kronos is offline   Reply With Quote
Old 08-05-2014, 08:13 PM   #30
FRSpappa
FRSpappa's Avatar
Drives: 2014 FR-S Whiteout
I think it's something with the DI switching over or something. Goes away and car runs fine...
FRSpappa is offline   Reply With Quote
The Following User Says Thank You to FRSpappa For This Useful Post:
Kronos (08-05-2014)
Old 08-05-2014, 08:52 PM   #31
Kronos
Kronos's Avatar
Unknown Engine Rattling (Video)
Interesting. Haven't heard that theory yet. Im really hoping it's a non detrimental sound: I'm dying to run e85 but I'm afraid of noise! That Effin noise. I'm gonna have nightmares about it. Once I get the OFH installed im tempted to go e85 with the oft and say Eff it
Old 08-06-2014, 08:29 AM   #32
aagun
Drives: 86
one of ur direct port injectors not work fine and u have to change it .
http://www.ft86club.com/forums/showthread.php?t=66620
aagun is offline   Reply With Quote
The Following User Says Thank You to aagun For This Useful Post:
Kronos (08-06-2014)
Old 08-06-2014, 02:05 PM   #33
Kronos
Kronos's Avatar
I listened to your videos and read through your post. You sound very confident that is the problem. How are you sure?
Old 08-06-2014, 02:20 PM   #34
aagun
Drives: 86
it happened to me twice . after 5k RPM ur car will back to normal condition, flying fast >< .
Subaru recommended change set of direct injectors + the delivery pipes after the fuel regulator . coz of high pressure
Old 08-06-2014, 02:27 PM   #35
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
sound like an injector seal failure.
As for why its only doing it sometimes and seemingly randomly, that could be due to temps, differing fuels, different loads. any number of things.
But, in your first video it almost sounded like a spun bearing. Most likely just poor sound quality.
I would tell your dealer to replace all your injectors, seals and check all lines/rails.
Kuros is offline   Reply With Quote
Old 08-06-2014, 02:38 PM   #36
aagun
Drives: 86
yoyo direct injector seal failure coz lost of pressure in the cylinder that make CEL about cylinder pressure and can not rev up to 7400 RPM .
brz frs gt86 and 86s firsts income 2012 had bad ignition table that cause DI failures . it fixed by update the ECU
Old 08-13-2014, 05:23 PM   #37
J-Money
J-Money's Avatar
Drives: GT-86
Mine sounds familiar.. Threw on an intake and i was fine after i got a ft86 tune i started hearing the noise. but im still getting my tune Confederated so ill bring it up
J-Money is offline   Reply With Quote
Old 08-13-2014, 06:03 PM   #38
Dezoris
Dezoris's Avatar
Have you flashed back to stock tuning to see if the noise persists?
Old 08-13-2014, 09:23 PM   #39
Kronos
Kronos's Avatar
I have not, and I probably should. Thats a good idea. Ill flash back for week or something and see if it happens.
I moved to Boulder Colorado from St. Louis about three months ago and that's when it started happening. I was running the e85 open flash tablet tune in St. Louis for several months before I moved and I never got that sound.
Since the move I went back to the stage 1 tune and have been on 91 oct out here.
Old 08-20-2014, 01:25 PM   #40
Kronos
Kronos's Avatar
So long story short. The dealership can't seem to reproduce the clanking and now want to get Toyota involved.
I flashback to stock but should I be worried about the flash counter on the ECU. I wouldn't normally worry about it but since they're getting actual Toyota technicians to come look more deeply at the problems I want to be a bit more cautious.
Old 08-20-2014, 02:02 PM   #41
Kuros
Shouldnt be worried about that.
They would have to prove that anything you did directly caused the failure of a part in question, otherwise they cannot deny you anything based on a mod.
Old 09-03-2014, 08:57 AM   #42
C4RBON
C4RBON's Avatar
Drives: '15 BRZ, '19 GTI
I have experienced the exact same sound. It happened 3 times, and I just bought the car on Saturday. I've got about 500 miles on it. I am in Colorado at the moment. I live in Iowa, so I will see if it still happens at lower altitudes and on 93 octane gas. I have read a few threads describing similar sounds, and all of the posters mention being at high altitude.
C4RBON is offline   Reply With Quote
Engine rattling/vibration happening between 3k - 3.3k Boofneenee Issues | Warranty | Recalls / TSB 4 05-18-2014 02:34 PM
Rattling from front of car when you shut the engine off djdrugga24 Issues | Warranty | Recalls / TSB 8 04-01-2014 12:03 AM
Rattling Engine Noise (Video with sound) mystic Southern California 21 12-28-2013 04:11 AM
Rattling noise under the hood during engine braking at low RPM Sigh-on-Rice Engine, Exhaust, Transmission 60 07-28-2013 07:48 AM
BRZ Rattling w/ video lavisxice Issues | Warranty | Recalls / TSB 11 11-06-2012 10:07 AM
