Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 |
Drives: '13 BRZ Ltd WRB
17x9 is just fine. These fenders are wide, I'd only worry about the spring perch in front. I'm on 17x8 +48 w/ 225s (MPSS) and the tires have just a few mm clearance on the inside with about a degree of camber (bolt on bottom for the most possible clearance). I can't fit even my pinky finger between the tire and spring perch.
On stock springs, I had 17x9 +28 w/235s (Federals...so more like a 245 in other brands). The front was a bit pokey, but I didn't have the camber bolts back then. That would have made them look better. I think +35 in that same size would be ideal. Many list a +42 as proper offset for 9" on stock suspension, but looking at my car, there's no way that's going to work. Maybe if I went back to 0 camber...HA! I keep looking at the Rota Titan, myself. 17x9 +42 and I'll use a 3-5mm spacer if needed. Pretty light for a cheap wheel and you can get a set for $7xx from WheelDude.
#30 | |
Drives: FRS
not 1200. wrong bolt pattern. way too aggressive offset. not even close. ![]()
#31 |
Slower than Fast
Drives: BRZ Limited 6MT
Just curious....are you wanting the option of running 225s and or 245s for a performance application or just for looks?
What are your goals for wheel/tire combo?
#32 | |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
http://www.s2ki.com/s2000/topic/8003...t__p__22541700 That post shows you all the sizes available for the wheels. They made them in 17x8 and 17x7 in 5x100. You should be able to fit the 5x114.3 with an adapter depending on the offset and width with a little math. The 5x100 sets can be had for cheap because of the application possibilites. |
The Following User Says Thank You to slicktop For This Useful Post: | 8R6 (06-06-2014) |
Affordable vacuum? | swift996 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 21 | 04-02-2014 06:21 PM |
An alternate to OEM Audio + that's actually affordable | BMHumanic | Electronics | Audio | NAV | Infotainment | 24 | 02-28-2014 06:28 PM |
Affordable Gt Spoiler for FRS? | Kanye | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 09-17-2013 01:11 PM |
S7F Wheels Replica affordable | NoFear99 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 04-27-2013 08:58 PM |
XXR 527 17x8.25 +35(front) 17x8.25 +25(rear) and 1 inch drop | AGM6789 | AUSTRALIA | 17 | 11-10-2012 05:10 AM |
