Old 02-22-2015, 07:41 PM   #29
No1der
No1der
No1der's Avatar
Drives: BRZ Limited Satin White
Originally Posted by aznatama View Post
The 4 small wires are near the tail end of the harness, and the instructions detail that they are for 180 rotate and the lines.
The ACC PWR wire on the back of the stock radio unit on MY BRZ is red/pink, as circled in the center of the yellow circle in pic above.
[CAMERA]----[4wires]---------------------------------------------------[RCA/pwer splice]
Where did you pluged Red - Camera power, Black - Camera ground to?
No1der is offline   Reply With Quote
Old 02-23-2015, 09:05 AM   #30
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
I tapped the ACC power, but you can replace the power pinout on the harness, just look up the correct pin to replace. Ground it anywhere.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 02-23-2015, 09:34 AM   #31
adamg
Drives: brz
this is an awesome subtle mod
adamg is offline   Reply With Quote
Old 03-31-2015, 09:48 PM   #32
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
I just finished my install and it was super easy. Thanks for the write up. Everything is plug and play except the power, that needs to be tapped.
Bones36 is offline   Reply With Quote
Old 04-01-2015, 01:24 PM   #33
No1der
No1der
No1der's Avatar
It has been little over a month since I finished my install. No issues so far works perfectly. Just wanted to say Thank you!
Old 04-03-2015, 03:47 PM   #34
Vroomin86
Drives: 2015 Fire
THANK YOU one of the first mods for me
Vroomin86 is offline   Reply With Quote
Old 04-04-2015, 04:05 PM   #35
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I have been using the below linked cam for over a year and it works perfectly. Same install location which is in the key hole for the trunk. This requires the harness from svxdc to connect to the factory radio and a relay for power since its a 12vdc cam. Total cost is under $30-$40 IIRC.
The below cam is $15, I found them being sold for $2 shipped at one point and bought about 5 of them just in case one went bad on me. If you search around you can probably find them cheaper.
http://pages.ebay.com/link/?nav=item...027240&alt=web
Old 04-08-2015, 11:31 PM   #36
2k15BRZ
Drives: 2015 BRZ Limited;
This is the route I went. Haven't installed it yet, but it's plug & play out of the box. http://www.emeraldintegrations.com/c...ra-system.html
2k15BRZ is offline   Reply With Quote
Old 05-08-2015, 09:33 PM   #37
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
The factories making these cameras are constantly changing the guts. So I always recommend that you test your camera powered from 6 Volts to see if it will work, since many do -- even when the vendor's specs say "12 V".
Use batteries or a 6V AC adapter and connect to a TV or monitor. Then compare the picture when powered from 12V, to make sure it's not getting dimmer or noisier when powered from 6V. Some cameras do need just a little more to work properly (7 or 9V).
For a camera that works from 6V, its easier to power it from the HU's 6V camera power pin.
Also, before you start drilling holes, cutting/splicing wires, etc., test-fit the camera in your car connected to your HU. You want to make sure that where you plan to mount the camera will result in an image that is right side up and angled such that it provides the view you need (not looking up or down too far).
See my Subaru/Toyota rear camera info page for details and additional tips.
SVXdc is offline   Reply With Quote
Old 05-08-2015, 09:34 PM   #38
SVXdc
SVXdc's Avatar
I'd be interested to see good pictures of their harness. I'm curious where they're getting power for the camera.
The harness they're currently showing on that page can't be the actual one for BRZ. The harness shown (link) has 10-pin connectors, and nothing that connects to a camera. The BRZ HU's camera sockets have 16 and 4 pins. Their harness looks like something for other Toyota models. And the picture at the bottom of the page just shows the camera and its long video cable. No car-specific harness.
Old 06-16-2015, 07:18 AM   #39
Papi
Drives: Crystal White Silica BRZ Limited
I have a BRZ that has a trunk release touch pad in the center. Not sure I saw a recess on the opposite side of the keyhole. When the camera is mounted on the side is the picture offset?
Papi is offline   Reply With Quote
Old 06-16-2015, 09:14 AM   #40
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
The "recess" is a very very hard to see square on the opposite side from the keyhole. It's only barely visible.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 06-16-2015, 09:21 AM   #41
Papi
Yeah I found it, so if the camera is mounted off center is the display on the screen off? Or does it somehow compensate for its position
Old 06-16-2015, 09:58 AM   #42
aznatama
aznatama's Avatar
When you remove the plastic panel, you'll be able to see the indent when you hold it up to the light. Yes, it's slightly offset, but it's not simmering that will make a difference. Also, the lines are so you can line up your car straight and know how close you are to the rear. They're useless as guides for the width of your car.
Sent from my D6503 using Tapatalk
'14 BRZ LTD MT DGM
Stock Rear View Camera for Fujitsu Ten? Foobar Electronics | Audio | NAV | Infotainment 151 08-19-2021 11:24 AM
stock brz jdm rear view camera SuperDave Electronics | Audio | NAV | Infotainment 0 04-03-2014 09:53 AM
Rear-view camera/reverse cam. What do you have? joergasm Audio/Visual, Electronics, Infotainment, NAV 0 05-24-2013 12:25 PM
be spoke with rear view camera harness fs xpicer Audio/Visual, Electronics, Infotainment, NAV 1 11-25-2012 02:35 PM
be spoke w rear view camera xpicer Electronics | Audio | NAV | Infotainment 17 10-14-2012 09:26 AM
