Old 05-14-2014, 10:00 PM   #29
xwd
So you are saying even without specific maps in Ecutek to take advantage of it, the car is learning based off the wideband rear O2? Or is the ECU setup to use the signal? I'm going to try and get my failsafe installed this weekend.
Old 05-15-2014, 01:28 AM   #30
Cross
It's the Mad Cow
Cross's Avatar
Found the problem, either I overlooked this reading how everyone else did it or my car just had to be different.
I noticed while testing my new 700cc Injectors to ensure they sealed that my throttle body sounded like it was moving. There was an audible noise like it was going back and forth between slightly opened and closed.
I decided to disconnect the Wideband and it went away, plugged it back in and it came back... cut the signal wire for the Wideband and it kept doing it.. cut the power wire and it stopped....
I have now completely rewired the AEM and only connected the singal wire to the Rear O2 harness. No more noises from the Throttle Body and everything appears to be working.
I have the injectors in but after all that my back hates me so I am going to wait until tomorrow to install the new fuel pump and take it for a spin.
But this goes to show do not power and ground the AEM through the rear O2. Or if you do don't ground it here maybe that is the issue... I didn't test that.
Do the following and it will for sure not effect the TB;
1) AEM White Wire to Rear O2 Blue Wire (Signal)
2) AEM Brown Wire to Rear O2 White Wire (Ground for Signal Ref)
Put the Red and Black AEM wires to a different power and ground or test your luck with using the Black 12v power in the Rear O2 and grounding the AEM Black wire to the chassis, it might work.
Old 05-15-2014, 10:35 AM   #31
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I connected white wire to Blue in Rear O2 harness.
Brown wire same ground as everything else (bolt that holds fuse box inside cabin). Ecutek log AFR is spot on with AEM gauge readings.
Old 02-26-2015, 01:11 PM   #32
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Edited my post as I just realized I asked what you just answered in the previous post lol. So where is the ECU ground, is it a specific wire in the ecu connectors or another location around it? Thanks
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-26-2015, 01:54 PM   #33
Koa
would love to do something similar for OFT.. anyone have experience w/ this kit in particular and OFT? @steve99 , @Kodename47
Old 02-27-2015, 01:18 AM   #34
steve99
Option A
http://www.ft86club.com/forums/showt...t=57902&page=7
Option B
Just rescale the front sensor , not rearly needed for NA cars though.
http://www.ft86club.com/forums/showthread.php?t=82875
on an OFT Front 02 sensor is "AFR"
REAR 02 sensor is "Wideband AFR" shiv was going to put out a plug and play wideband kit but it died off for some reason.
Koa (02-27-2015)
Old 02-27-2015, 10:59 AM   #35
Koa
Option A
Option B
died off officially due to OFT300 development taking priority- my guess is they just saw not enough demand for the effort needed
Old 02-27-2015, 11:31 AM   #36
yomny
yomny's Avatar
There are tons of people out there using OFT so maybe get a thing going and he'll push it through.
Old 02-27-2015, 11:45 AM   #37
Koa
Option A that steve furnished seems to be a great route, going for that one
Old 08-30-2016, 06:32 PM   #38
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
For me it is causing serious drive-ability issues. Mine is also about .8 off and Mike has not made any changes to that yet.
Mine also like to try and die now at stop lights when you first hit the gas, rpm's go down to 400 or less then come back up.
Then while cruising timing is jumping all over as is afr, just cruising at say 40mph. 11-16afr just putting along. It's annoy and frustrating because it does it the more you drive. Mike thought it was LTFT and shut that off, it did nothing to fix it. For me driving it has become an exercise in hitting the gas before the light turns green to handle the dip and dealing with my car basically feeling like it is fighting me.
But all of this goes away if I disconnect the signal wire to the Ecu.... screams to me that no matter what the Ecu is making adjustments based off that signal and considering mine is not matching the factory front O2 the Ecu just seems to be fighting with itself and making me not want to drive my car.
Im having the same issues except i took the rear o2 out and used the aem o2 and harness
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 08-30-2016, 07:23 PM   #39
Kodename47
Kodename47's Avatar
Drives: UK GT86
There are settings that need to be zeroed out if you repurpose the rear sensor input or remove it completely. I would expect that would clear the issue as the secondary sensor does impact fueling.
.: Stealth 86 :.
Kodename 47 DJ:
How much spacer is safe on stock rear studs? wparsons Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 12-27-2014 02:49 AM
Safe to jack car from rear diff (while potentially touching the cover)? bloomy116 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 05-30-2014 12:18 AM
fail BRZPDX Northwest 24 11-21-2013 08:24 PM
TRD Rear Spoiler Fail TRD-X Cosmetic Modification (Interior/Exterior/Lighting) 11 04-27-2013 07:05 PM
