Old 05-10-2014, 11:56 AM   #1
Cross
It's the Mad Cow
Cross's Avatar
AEM Fail Safe using Rear O2, Anyone done this?
I found some information showing people were running the AEM directly to the PCM as there may or may not be an open port. But I had a different question, how about just using the Rear O2 Connector?
I am looking for a pin out now but it should have a signal, ground and power going to it correct? Granted it is on the front of the motor but it would make a plug and play setup.
I kept going back an forth on where to post this but felt most FI guy's would be the best to ask.
So have any of you done this before? I am not seeing anything on this method of trying to do it.
Thanks!
Old 05-10-2014, 12:14 PM   #2
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
http://www.ft86club.com/forums/showthread.php?p=1517748
... my build thread: maxjedi's turbo "daily drifter" GT86 ...
maxjedi is offline   Reply With Quote
The Following User Says Thank You to maxjedi For This Useful Post:
Cross (05-10-2014)
Old 05-10-2014, 12:28 PM   #3
Cross
It's the Mad Cow
Cross's Avatar
Originally Posted by maxjedi View Post
Thanks, of course I would miss a whole thread Forum and Google Search brought me to other installs not using that point so it's good to know someone else is already doing it. That was exactly what I needed to know.
Now to go put it in.
The Following User Says Thank You to Cross For This Useful Post:
Sportsguy83 (05-13-2014)
Old 05-10-2014, 12:30 PM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
i'm using it, works great.
You only need one wire on the O2 sensor harness (blue if i recall). I've got another connector here that i'm thinking about using and wiring in for a cleaner more plug and play install. However it is my understanding that the other wires in that harness must remain connected to the stock rear o2 or it will throw a code about something with the o2 heater circuit. I'm not sure whether or not those specific codes can be disabled, but if they can I would be happy to make my harness and take pics for those of you that are interested.
The Following User Says Thank You to xjohnx For This Useful Post:
Cross (05-10-2014)
Old 05-10-2014, 12:51 PM   #5
Cross
It's the Mad Cow
Cross's Avatar
My impression from Moto-Mike was that you could just completely remove the Rear O2 and use it's harness. That is what I planned on doing since I have a Rear O2 that was stripped out from another local member.
I was hoping I could just plug in power an ground to the factory Rear O2 Harness and go from there without any CEL's so unless I misunderstood @moto-mike I believe that is exactly what you can do.
I should know shortly, I am working on installing it now.
Old 05-10-2014, 04:51 PM   #6
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
if you tap into the wire at the pcm you can run the ground over there too. I found a good solid ground behind the kick panel next to it.
On another note im not sure if it can be turned off with ecutek but if you unplug the rear o2 sensor it will throw a code for the o2 heater circuit no longer being connected.
Old 05-10-2014, 05:26 PM   #7
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
No need for the other wires to be connected, those cels have to be disabled anyway.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Old 05-13-2014, 08:20 AM   #8
BRZGM3
BRZGM3's Avatar
Drives: CBS brz limited
So I just ordered the AEM fail safe A/F and I'm curious where some of the other members have mounted them in their interior?? I already have the p3cars gauge in my vent so that option won't work. Any help, maybe even pictures would be great. Thanks guys
BRZGM3 is offline   Reply With Quote
Old 05-13-2014, 09:13 AM   #9
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
Check out this thread, especially pages 11 and 14
Old 05-13-2014, 09:32 AM   #10
xjohnx
Grip>Slip
xjohnx's Avatar
Here's mine (on the small defrost vent to the left of the gauge cluster). Sorry for the crappy pic.
Old 05-13-2014, 11:00 AM   #11
Cross
It's the Mad Cow
Cross's Avatar
I mounted mine in the factory gauge cluster between the radio and fuel/temp gauges.
On another note so the wide band is reading but whatever EcuTek is getting it's way off and now the car is really pissed off. It tries to die on initial throttle input from a stop, runs 13.8 - 14.3 while cruising and hesitates all the time now. I have been staying out of it but here I sit in a parking lot trying to contact the rubber because this was supposed to be fixed...it's like the wideband is effecting the fuel terms when my understanding is all it was supposed to do is log.
The gauge it self at idle says 14.6-7 EcuTek says 20-21.
Sent from Spaceball 1
Old 05-13-2014, 11:17 AM   #12
Cross
It's the Mad Cow
Cross's Avatar
Disconnected the wideband car runs great now... Wonderful
Old 05-13-2014, 11:35 AM   #13
Cross
It's the Mad Cow
Cross's Avatar
Alright reconnected it with the signal wire cut and it's doing fine so far. Going to do further testing now.
Old 05-13-2014, 12:00 PM   #14
welllam
Drives: STi
Make sure you connect the aem output ground as well to get the correct reading.
And how I mount it
welllam is offline   Reply With Quote
The Following User Says Thank You to welllam For This Useful Post:
Cross (05-13-2014)
How much spacer is safe on stock rear studs? wparsons Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 12-27-2014 01:49 AM
Safe to jack car from rear diff (while potentially touching the cover)? bloomy116 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 05-29-2014 11:18 PM
fail BRZPDX Northwest 24 11-21-2013 07:24 PM
TRD Rear Spoiler Fail TRD-X Cosmetic Modification (Interior/Exterior/Lighting) 11 04-27-2013 06:05 PM
