Old 05-19-2014, 07:36 AM   #29
VuDism
NASIOC: AzNSTiImpreza
VuDism's Avatar
Drives: 2013 Whiteout Scion FRS
Got my fuel pump replaced at the dealer last week... 500 miles later crickets are back
VuDism is offline   Reply With Quote
Old 05-19-2014, 11:13 AM   #30
mike the snake
Many people have reported that a tiny amount of 2 stroke oil helps get rid of the crickets.
Do a search here, there's a couple threads about this.
Old 05-19-2014, 05:14 PM   #31
madboom
madboom's Avatar
Drives: '13 FR-S Argento
I had the pump replaced under warranty at my 15k service, and the chirps went away, but they returned after about 2000 miles. I'll have to learn to live with it or get a louder exhaust .
Originally Posted by JonAvalon View Post
They will come back...........eventually.
Mine was replaced two months ago and after 2500 miles it returned, went away and then came back completely. Dealer said the same thing about it being different but thanks to the cricket thread i knew they would come back. It was nice while it lasted :P
Stig tested. Clarkson approved.
madboom is offline   Reply With Quote
Old 05-19-2014, 05:19 PM   #32
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Or get a supercharger and pretend it's related to it
JonAvalon is offline   Reply With Quote
Old 07-24-2014, 11:23 PM   #33
TB9
Drives: 2014 Subaru BRZ Limited CBS
Originally Posted by GotBRZ1691 View Post
I have a 2014 BRZ limited that I have owned for less than a month(1.7k miles) and It has crickets.
Sounds like a terrible disease or a STD... but for your car
I call it "The Cherpes". At what point should I harass my dealer for a new pump?
TB9 is offline   Reply With Quote
Old 07-24-2014, 11:42 PM   #34
VuDism
VuDism's Avatar
It's not gonna fix anything. . my crickets came back writing 1000 miles of replacing
Old 07-25-2014, 08:54 AM   #35
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Well Mine has actually stopped now, which is weird. I am not doing anything different, just have put another 6k miles on the car is all.
Has anyone else noticed that their crickets went away after driving the car for longer?
GotBRZ1691 is offline   Reply With Quote
Old 07-25-2014, 08:59 AM   #36
extrashaky
Drives: 2014 BRZ Limited
The gas blend being dispensed by the gas station you use has probably changed. Once summer is over and they change their blend again, they'll probably come back.
Old 07-25-2014, 09:06 AM   #37
Malt
Drives: 2015 WRX
I thought it was pretty much proven that ethanol has absolutely nothing to do with the crickets. Given the fact that people have no crickets running E85 and some still have them running pure gas pretty much confirms the fact that its something else other than gas formulation.
Malt is offline   Reply With Quote
Old 07-25-2014, 09:16 AM   #38
GotBRZ1691
GotBRZ1691's Avatar
I live in california though, the weather does not change much between summer and winter, and I bought my car in May, give or take a month.
Old 07-25-2014, 04:12 PM   #39
extrashaky
It's not the ethanol that's causing the problem. There are other things in your fuel besides gasoline and ethanol. For example, during winter months in cooler locations, most blends include butane, which is a cheap filler that still keeps the octane rating up. They can't put butane in the gas in the summer, though, because it evaporates out in warmer temps.
They also put additives in the gas that are alleged to clean and protect your engine and fuel system. I'm convinced it's those additives that are contributing to the chirping problem. More than likely most of the E85 gas doesn't have those chemicals, which is why some people see their crickets disappear when they go over to E85.
Likewise, E0 is not top tier gas in the US, because to qualify as top tier gas it must have ethanol. So when you get ethanol-free gas, you're getting lower tier gas that also may not have all those fancy additives alleged to protect your engine. Without those additives, many people lose the crickets and think the lack of ethanol did it.
It would be great if we could isolate exactly what is being put into the gas that's causing the chirp, then find a way to counteract it. But there are about 2 dozen basic gas blends in use in the United States, not including all the variations in concentrations introduced at different refineries and different distribution centers around the country. The supply chain adjusts to demand and individual refinery output, so that a single station can't guarantee that the gas you buy this week is the same formulation as what you bought there last week. Whenever I see someone post that his crickets went away, I have to suspect that something changed in his regular station's supply chain to remove whatever was making the crickets happy.
Old 03-28-2015, 12:30 AM   #40
ChasingHP
Drives: 2014 FRS Monogram Whiteout
I had the crickets last September when purchased. At around 2,000 miles, I did a few mods with a CAI, headers, cat back and ECU-Tek/tune. Haven't heard a cricket since. Runs like a swiss watch with satisfying power.
ChasingHP is offline   Reply With Quote
CRICKET FIX! alex_86 Issues | Warranty | Recalls / TSB 142 12-04-2013 11:29 AM
Took my car to the dealership concerning the cricket noise. Ludacrits Issues | Warranty | Recalls / TSB 6 10-14-2013 03:18 AM
Chirping/Cricket Fix Out? deeranged Issues | Warranty | Recalls / TSB 15 10-02-2013 05:43 PM
Cricket TSB [deleted] Southern California 25 06-05-2013 06:01 PM
New trans, window, and cricket fix! foney_email Issues | Warranty | Recalls / TSB 11 03-14-2013 05:35 PM
