Old 04-30-2014, 10:30 PM   #29
qijian
Drives: FRS
this just makes me wanna demand a new tranny even though i don't have the problem... or maybe not just "yet"
qijian is offline   Reply With Quote
Old 04-30-2014, 10:54 PM   #30
nyfries
Drives: 14 FRS Whiteout
Originally Posted by WNDSRFR View Post
No
DEMAND a new transmission. The car is under warranty and I had the same problem with 5th gear. Oil is not going to do it.
I had mine replaced and I think they upgraded it somewhere along the line because the new one has no issues at all.
My original trans clunked into 1st gear always (they say that's normal) it isn't.
So go to the dealer and DEMAND a new transmission.
so the new trans doesn't clunk under any circumstance? i think i need a new tranny than, mine clunk in 1st 99% of the time too
funny.. when i bought it in to the dealership for first service it didn't clunk…
nyfries is offline   Reply With Quote
Old 05-02-2014, 03:28 AM   #31
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Originally Posted by iStanley View Post
They also told me that it's very rare for them to replace an entire transmission and that they will most likely replace a part or just the synchros.
as far as i know they have no transmission serviceability, it just gets replaced.
jbailey8748 is offline   Reply With Quote
Old 05-08-2014, 02:37 PM   #32
iStanley
They call me Stan
iStanley's Avatar
Drives: Firestorm FR-S
UPDATE: the dealership said they are putting a new transmission into my car and should be out to drive in 1-2 days!
iStanley is offline   Reply With Quote
Old 05-12-2014, 09:59 PM   #33
satinwhitebrz14
Drives: 2014 satin white pearl brz premium
Ive got 2600 miles on my brz. Just noticed today it grinds into 4th @6000rpm or higher. I tested it on my way home from work and grinded everytime. Took it up to 5k and shifted normal...shit
satinwhitebrz14 is offline   Reply With Quote
Old 05-12-2014, 10:02 PM   #34
iStanley
They call me Stan
iStanley's Avatar
I just got mine replaced. I'm guessing you have warranty so the service manager will probably talk you out of it if he is an asshole like mine was. Just go up and demand it. Reproduce for them and let them try. They will change your fluids and check it out. They will find that it's doing nothing and will give you a new tranny instead of replacing parts in it most likely.
Old 05-13-2014, 07:47 AM   #35
iStanley
They call me Stan
iStanley's Avatar
Update. They gave me a new transmission and there is no grind now but it is still clunky when shifting?
Old 05-15-2014, 10:49 PM   #36
nyfries
Think the clunking is normal with our cars
Old 05-15-2014, 10:50 PM   #37
iStanley
They call me Stan
iStanley's Avatar
Can anyone else confirm this?
Old 05-15-2014, 11:00 PM   #38
nyfries
Lots of complaint of clunking at least from what i can tell in the forum. Mine clunks too. some say changing the oil help some say it doesn't. i would like to know if this is normal too. I feel like it shouldn't happen on a new car.
my first gear clunk 90% of the time. 2-3 clunks 30% of the time.
sometimes the shift is buttery smooth, sometimes it clunks like its broken… the most frustrating part it when i took it in for service it was fine...
Old 05-16-2014, 07:15 AM   #39
iStanley
They call me Stan
iStanley's Avatar
I know right? I have a new transmission put in so I will wait 500 miles before I complain again if it still has issues lol
Old 05-16-2014, 08:53 AM   #40
DarkSunrise
DarkSunrise's Avatar
Originally Posted by shattered_memory View Post
Also, when I had faulty tranny, it grinded into 4th gear at around 6,000 rpm. Make sure that the dealer tests the car when shifting at a higher rpm. They will not be able to feel the problem if they shift at a lower rpm.
Really odd. When my transmission grinds (usually into 3rd), it's at lower/mid RPMs. When I shift at redline, no issues.
I've noticed this too. My theory on this is there's a lot of movement in the drivetrain (differential, transmission mounts are soft), so depending on how the transmission is loaded at the time of shift, it creates a different feeling on the shift. There's also a bit of rev-hang at lower RPMs (which disappears at high RPMs), which further complicates the issue.
I've found with my issue (grind into 3rd at mid/low RPMs), if I make an effort to lift completely off the gas between shifts and wait for the RPMs to fall (as mentioned, there's a bit of rev hang), the 2-3 shift is smooth 95% of the time.
2022 BRZ Build
2013 FR-S Build
Old 05-16-2014, 10:18 AM   #41
iStanley
They call me Stan
iStanley's Avatar
My shift into third is usually 80% bad. It feels like a spring launches it into 3rd and feels like it hits something on way there. Also, 4th gear feels the best, after they replaced my transmission of course.
Old 05-16-2014, 10:20 AM   #42
iStanley
They call me Stan
iStanley's Avatar
How would you shift from 4 to 5? qqzj BRZ First-Gen (2012+) — General Topics 37 05-01-2014 08:10 PM
You know what really grinds my gears...... z3ro Off-Topic Lounge [WARNING: NO POLITICS] 7 10-10-2013 01:55 PM
HUD shift up and shift down display question JS86JS Electronics | Audio | NAV | Infotainment 6 05-17-2013 02:54 AM
What really grinds my gears! CircuitJerk Off-Topic Lounge [WARNING: NO POLITICS] 124 04-01-2013 08:45 PM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 01:11 PM
