Old 04-23-2014, 02:56 PM   #29
Vides990
Drives: 13 BRZ (sold) 20 BRZ TS (sold)
Originally Posted by immaculate View Post
You buy an automatic if you have to ask a question like this.
http://www.ft86club.com/forums/showthread.php?t=56113
There's an entire thread about this that's been going on since the start of the forum, still first page even.....I just don't get it.
Vides990 is offline   Reply With Quote
Old 04-23-2014, 03:06 PM   #30
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
To be clear, I don't think either method is wrong. Sorta like where to put your hands on the steering wheel - it's whatever works best for you. That said, personally, I like to work with the car and not against it. The shifter in the BRZ is stiff - but has a solid feel. Other cars are rubbery and there's no feel for the gears. Bolt action vs stirring soft butter. With the bolt action feel, I like to feel the gears engaging. I never have to force it. With rev matching, each gear change goes in effortlessly.
ashtray is offline   Reply With Quote
Old 04-23-2014, 03:17 PM   #31
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by 1Cor10:23 View Post
the problem is that 5th is slightly 'out there' ....
Not with a short shifter and springs it isn't
^GT5 Replay Photo Mode^
Old 04-23-2014, 06:01 PM   #32
Akari
Drives: 2013 DGM BRZ
Method 2 would definitely wear out your shifter bushings quicker in theory...
This just made me realize I have no idea what the shift linkage in the BRZ looks like. Must research!
Akari is offline   Reply With Quote
Old 04-26-2014, 02:31 AM   #33
RacerX
Drives: Subaru BRZ
Post a link when you find some good info. I'm interested too.
I just push it diagonally in the direction of 5th gear. Same with 3rd->2nd down shifts, pull it diagonally. It will zig zag on its own. When I was learning stick I got 3rd instead of 5th once. That was a surprise.
RacerX is offline   Reply With Quote
Old 04-26-2014, 06:32 PM   #34
meWant
Drives: '16 BRZ Limited
My cousin said to do method 1 when I had learned to drive stick so I plan to stick to that whenever I get a twin
meWant is offline   Reply With Quote
Old 05-01-2014, 07:20 PM   #35
radroach
Drives: car
Every time I've tried shifting trying to draw the H pattern 2nd-3rd I've mis shifted. 5th gear you can do it much easier obviously, but it's quicker to just push it in the direction. Quickness is key because the revs sometimes fall very fast when doing a 4th-5th gear change. I just nudge or flick the shifter through the gates when upshifting 2-3, 4-5 and the shifter guides itself very easily through.
Old 05-01-2014, 07:34 PM   #36
SirBrass
SirBrass's Avatar
The shifter linkage is rod and joint connected to the shifter lever. It rotates and pivots.
Old 05-01-2014, 08:10 PM   #37
kberkel
kberkel's Avatar
Saw this thread, then payed attention to how I do it the other day.
It's probably like this in real life
2nd to 3rd.. I just push forward from the back (I don't "grip" the shifter). Benefit of the centering spring.
kberkel is offline   Reply With Quote
Shift resistance amaciose Engine, Exhaust, Transmission 2 12-06-2013 08:53 PM
HUD shift up and shift down display question JS86JS Electronics | Audio | NAV | Infotainment 6 05-17-2013 02:54 AM
Shift Knob Zoomryder Issues | Warranty | Recalls / TSB 5 04-09-2013 08:39 PM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 01:11 PM
Shift Knob yomchi1989 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-07-2012 09:19 PM
