Old 04-11-2014, 01:24 PM   #29
nelsmar
This. I had the same exact issues with my tune when I sold the car, and I am not affraid to say that it was an FA20Club tune. I knew that the BOV was not causing the issue because I had already eliminated it as a possible cause. I informed Toni of the issue multiple times since my first drive home from being "tuned" meaning 10 flashes on the dyno and zero time tuning on the street.
I had the same problem on my own car if it was below 70F out. If i blipped the throttle it would shut off. And it was on the same injectors as the OP, and his logs show a lot of similar properties of my own car back then. I would max out fuel trims and the car would just shut off. It also did it while on the highway at about 65MPH at certain load values. (as in while driving).
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Sportsguy83 (04-12-2014)
Old 04-11-2014, 01:28 PM   #30
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yep. I actually taught myself to make sure I engine braked to as low an RPM as I could to not allow the RPM very much room to drop when I stuck the clutch in. Sometimes it would still stall out when I stuck the clutch in and hopefully I was going fast enough to just put it in second and pop the clutch to refire the car so I didn't have to embarass myself restarting my car while sitting at a stop light. Stop and go traffic with higher temps was when it was the worst for me.
The Following User Says Thank You to King Tut For This Useful Post:
ftc~brz (04-18-2014)
Old 04-11-2014, 01:41 PM   #31
jamesm
This is all textbook stuff guys. I literally fix this for someone at least once a week. I can tell people what their problems are before they even tell me at this point when they call lol.
Just get a new tune.
The Following 6 Users Say Thank You to jamesm For This Useful Post:
ftc~brz (04-18-2014), Ironsquid (04-11-2014), King Tut (04-11-2014), nelsmar (04-11-2014), SmsAlSuwaidi (04-11-2014), Sportsguy83 (04-12-2014)
Old 04-11-2014, 03:24 PM   #32
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
The car will be getting a new tune as soon as I can find someone willing to tune it. Until than it'll just sit parked . I appreciate all the feedback from everyone.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 04-12-2014, 08:20 AM   #33
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
This is my take on all of this:
I have had my car with open at idle BOV (my kit is routed like JDL's) and didn't pay much attention to it. It had an 8psi spring.
I've had a hard time tuning the idle for the past month. Looked for fuel leaks, vacuum hoses popping off, etc. Nothing was wrong. Yesterday I decided to try closing BOV and it is a different car.
Car is way more responsive, it's building boost sooner and more importantly, the idle improve significantly. Now Just need to fine tune for it and it will be within 2% of fueling error. I used the Tial chart and selected the 11 psi spring which is the correct one for my car that vacuums -20.
On the tune side, I used to have an FA20club tune that had these issues:
Idle dip... bad (never fixed)
14 AFR part throttle all the way to 16 psi (WOT would force open loop and proper AFR) (never fixed)
Too rich AFR when going to open loop, creating a misfire CEL when going WOT sometimes (fixed after multiple times asking for it and fixed only because instead of asking about the CEL and being told it was a bad coilpack, I actually diagnosed the issue myself and simply asked for an open loop AFR leaner than high 9's
Car would not start normally, needed to start cranking then WOT to remove fuel and make it start. (Fixed after spending money on FA20club recommended injectors sworn to have those ones nailed down perfectly, still having the issue for a couple more tune revisions SMDH... but then fixed for good).
And the weirdest of them all, sometimes completely random the car would make no power even at 16 psi. It was like ALL timing was removed from the tune. A little time later or stopping starting the car later would fix it. Other times it would not make power up to 10 psi and then would make normal power from 10-16 psi.... Never ever got this resolved and know other people with FA20club tune that have hd this happen too.
Heck, less than a week ago I reviewed logs from one FA20club turbo car dyno tuned with FA20C turbo and one dyno tuned by FA20C but with P&L turbo and both of them knocked while cruising to -5......
All of this issues are non existent with @jamesm tune.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
jamesm (04-13-2014), King Tut (04-12-2014)
Old 04-12-2014, 01:38 PM   #34
xwd
I've read lots of things in the past on various cars about idle issues and whatnot with BOVs open at idle, even when then BOV is before the MAF. Most people put stiffer springs in them like Sportsguy83 or shim them to keep them closed at idle and it fixes the problem. It usually has little affect on the BOV at boost either, you probably won't see much more compressor surge.
The Following 2 Users Say Thank You to xwd For This Useful Post:
King Tut (04-12-2014), Sportsguy83 (04-12-2014)
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
Super/ Turbo charged system issues/ fixes Newguy Forced Induction 2 02-04-2014 01:42 PM
Turbo kit issues 1slowbrz Forced Induction 18 08-15-2013 12:43 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
