Old 08-13-2013, 12:31 AM   #1
1slowbrz
1slowbrz's Avatar
Drives: 2017 WRB BRZ PP
Turbo kit issues
Hey, I'm having an issue getting everything running right on my fa20club turbo kit and am wondering if anyone has encountered a similar situation
We originally set it up to run on the stock fuel system, and 60 trim turbo.
On the base map it ran well, but as soon as it got to 0.00 vaccum/boost it died and stopped accelerating. I feel like I've checked everything a thousand times but don't know what the issue could have been
My only idea was that it could have been the fuel system, so I installed the fuel pump and 550cc injectors. Toni sent me a map for the new fuel system, and now it doesn't start at all.
Neither of us have any idea what the source of the problem could be, and its 100% isolated to me. I'm running out of ideas and paitence.
Thanks.
1slowbrz is offline   Reply With Quote
Old 08-13-2013, 01:57 AM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
considering you just installed a new FP, I'd check that out
Old 08-13-2013, 08:31 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks.
Check for boost leaks
Did you upgrade the MAP sensor?
(Please say yest o this one...) Do you have an AFR gauge? When it was dying and stopping acceleration, what did your AFR look like?
Where you logging with ECUtek? you can get an idea on AFR from the Log
How did you install the FP? See this thread http://www.ft86club.com/forums/showthread.php?t=33993
Old 08-13-2013, 09:01 AM   #4
Ross
Drives: 85 corolla gts
I would recommend doing a boost leak test. What pump and injectors did you install? What wideband are you using? Is the maf some how installed wrong? How did yo do your vacuum distribution?
Ross is offline   Reply With Quote
Old 08-13-2013, 09:39 AM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
If you installed a FP and it fails to start now, then I would almost surely say something went wrong with the FP install. Pull the fuel lines off where the quick disconnect fitting is and see if any fuel comes out when you prime the system. If fuel comes out and it still won't start then try holding the throttle wide open while starting and see if that does the trick. There is no way the OEM injectors and pump were the original cause of your issue.
Old 08-13-2013, 09:53 AM   #6
mad_sb
Drives: 2013 Asphalt FR-S
^ I agree with @King Tut,
I suspect either a bad boost leak causing the initial issue at 0psi or it was overly rich or lean on the base map.
Entirely possible you missed something during the install of the kit since that is when the first issue appeared.
Old 08-13-2013, 10:35 AM   #7
Andy@FA20Club
Drives: FA20Club.com
spoke with him today already.
Andy@FA20Club is offline   Reply With Quote
Old 08-13-2013, 10:42 PM   #8
1slowbrz
1slowbrz's Avatar
Thankfully the solution has been found! The problem was the fuel pump the whole time. A few things that aren't really mentioned in the instructions and are apparently VERY important. First off when the fuel pump is installed in the housing there are three pieces to be installed on the top of the fuel pump, the white plastic ring from the oem pump, and 2 Orings on top of it. Not using that white plastic ring causes a significant lack in fuel pressure. Sencondly, in the DW instructions it shows in the picture, but doesn't actually mention it in the instructions from what i've seen, the piece that clips to the bottom of the pump and housing (oem fuel filter attached to it) needs to be cut and the half that isn't under the pump needs to be clipped in to hold that metal piece in.
Thanks a ton to everyone at FA20Club for bearing with me and helping me figure out what the hell was going on!
Old 08-13-2013, 11:15 PM   #9
Andy@FA20Club
we are here for you :happy0180:
Old 08-13-2013, 11:24 PM   #10
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Good deal, FA20clubs service and support is easily the reason I'll be choosing them. IMO it is very rare to see a company help so many and get involved in the builds. Especially when it seems most companies go quite after they get the check in the mail. Before then they won't shut up.
Glad to hear you got it working.
Old 08-13-2013, 11:34 PM   #11
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Thumbs up for these guys
Ny Brz is offline   Reply With Quote
Old 08-14-2013, 07:47 AM   #12
Sportsguy83
Drives: Limited BRZ
The thread I posted in my reply has all the dirty details on FP install
Old 08-14-2013, 08:34 AM   #13
Ny Brz
Hella Flush
Ny Brz's Avatar
Oh crap thumbs up to this guy too...he always has something intuitive and helpful to say. When I come down from NY I would to meet the local FL guys along with stopping by FA20 to hook up with Toni and Andy.
Old 08-14-2013, 08:37 AM   #14
Sportsguy83
Drives: Limited BRZ
Let me know when and we'll make it happen :happy0180:
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 11:50 AM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
Turbo Tuesday 12/4/2012 (Dynamic Turbo Miami) F3dzo Southeast 46 12-06-2012 01:49 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
