Old 03-26-2014, 07:01 AM   #29
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
Originally Posted by mrk1 View Post
An inline sensor manifold is another option, mount this on the hot side going to the cooler. Preferably as close to the motor as possible.
Im trying to reduce the amount of Tee's and adapters needed since every connection is a possible leak.
Thanks for showing this. $60 isn't much to pay to reduce the amount of potential leak points.
Cheeseballs is offline   Reply With Quote
Old 03-31-2014, 12:02 PM   #30
evan
Drives: fr-s
Originally Posted by mike the snake View Post
I'm not sure why the PLX gauge isn't used more. It can operate off your OBD port, and/or uses it's own sensor modules, and can display every parameter needed.
I'm getting oil temp, oil pressure, boost, coolant temp, and can add AFR, EGT, fuel pressure, and read all of these by simply pushing one button and scrolling through.
The only disadvantage to multiple gauges is it only displays one thing at a time.
I plan to leave it on boost or oil temp, and check the other values periodically.
I'm getting the 200 model with OBD2 and it can show 4 param at a time. Slick! Better than the p3cars gauge.
evan is offline   Reply With Quote
Old 12-02-2014, 12:26 PM   #31
ofuts
Drives: 2013 Toyota 86 MT
hey
i will be installing a turbo kit soon, but i dont have any experience. I dont know these AFR, EGT, wideband, failsafe terms, how they are measured etc.
can someone explain or post a link where i can read and learn about these please.
i will need to watch my oil temp and pressure for sure, i only know that. oil temp should be under 100C, how about oil pressure? and do i need any measurement devices and drilling at oil pan? I will get oil cooler for sure, so i guess they work like radiators so it will have a pt100 anyway i guess so no need to buy i guess.
need info, thx
ofuts is offline   Reply With Quote
Just Another (Turbo) Build rb6freak Member's Car Journals 184 03-22-2017 09:25 AM
Do Boy's Turbo FR-S build!!! Do Boy Member's Car Journals 417 11-29-2015 02:17 AM
Turbo Kit & Shop Car Build Carolina Dyno Forced Induction 11 01-22-2014 03:59 PM
pick-a-turbo for beginners! subatoy Forced Induction 20 07-25-2013 07:09 PM
Gauges for Turbo, boost controller options? gdrider77 Forced Induction 27 05-13-2013 06:57 PM
