Old 03-16-2014, 10:20 PM   #29
retrosmiths
Drives: Scion FR-S Whiteout
Relay harness with a 10-amp fuse.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 03-16-2014, 11:15 PM   #30
dssence
Drives: Toyota FT/MT 86
You're sure I need a relay harness for the led strip using the parking lights? I don't mean the low beams. I mean the lights wihch light up when you switch the backlights of the gauges.
dssence is offline   Reply With Quote
Old 03-17-2014, 01:14 AM   #31
retrosmiths
Well, I didn't use one on mine and as I mentioned the strips were not lighting up evenly probably due to differences in wire distance from the battery.
Also, safer that way, with a harness so you won't overload the stock wires, kinda like HIDs.
2013 Scion FR-S
Old 03-17-2014, 02:40 AM   #32
retrosmiths
Wait, hold on, I only saw that picture today, that one in the first post of this thread, why do you have that bulb there OP? Or is it always like that in your country?
2013 Scion FR-S
Old 03-17-2014, 03:34 AM   #33
dssence
Well that bulb it's always there. That's the bulb I was talking about. That bulb turns on whenever you turn on the backlight of the gauges where there's the rpm and everything.
I don't know if that's the parking light I think it is. next to it you have the high beams and then on the projector the low beams.
---Autolismo.com, Vancouver Canada--- Trunk LED Bulb and Strip autolismo Interior Parts (Incl. Lighting) 314 11-14-2017 01:02 PM
BRZ LED Strip in Headlights (bulb) R0ME0 Cosmetic Modification (Interior/Exterior/Lighting) 15 05-27-2014 12:57 AM
DIY Trunk light mod with L.E.D. strip chrisbfrs Cosmetic Modification (Interior/Exterior/Lighting) 5 01-16-2014 12:34 PM
Fuse for parking/fog lights Bg8780 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-27-2013 09:17 PM
Fuse # to the Fog light's 914_WHITE_FRS Issues | Warranty | Recalls / TSB 3 08-06-2013 04:40 PM
