CANADA Canada
Old 03-12-2014, 03:02 PM   #29
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Originally Posted by f0rge View Post
Hey sorry I'm late to the thread, but I'd like to suggest you DON'T do this, and just get coilovers to start with.
I have sportlines on my car, on stock struts, and I gotta say I'm not really that happy with anything other than the drop.
The ride is pretty terrible and you can tell the stock struts are not up to the task of damping the relatively short and stiff sportlines. My old car had coilovers with stiffer springs and good quality dampers, and it was way more "controlled" than my FRS is now.
After that car I vowed I'd never just do springs again, but for some reason I did, and just like I thought I'm regretting it.
If it's a money thing, just save longer or wait on the rims.
Don't forget you're also going to need LCA's no matter what path you choose.
Lower control arms needed with STI pink springs ?
Sent from my SGH-I337M using Tapatalk
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 03-12-2014, 03:05 PM   #30
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
Not 100% sure but probably, 1.4inch drop gave me over 2.5 degrees negative camber on both rear wheels.
You may have less, but there's no stock camber adjustment, so be warned.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 03-12-2014, 03:06 PM   #31
Simon99
Simon99's Avatar
They give about half an inch drop, thats why im asking
Old 03-12-2014, 04:56 PM   #32
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
0.6" to be exact. For Mcpherson Strut design you don't need LCAs to correct the geometry unless you are slamming like 2 inches lol. STI catalog have trailing and lateral links for the rear double wishbone suspension but they are same as stock parts just with pillowball instead of rubber bushings to increase contact pressure for more grip and improve steering turn-in. Saying this just in case someone mistaken them for LCAs.
krayzie is offline   Reply With Quote
Old 03-13-2014, 10:04 AM   #33
f0rge
You're going to want to do an alignment after you install the springs anyway, so check the rear camber numbers and if they're not where you want them to be you can get the LCAs after.
Old 03-13-2014, 12:19 PM   #34
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Personally I am going for Eibach Sportlines, Eibach Sway Bars, Bilstein Sport Series Shocks, Camber Bolts and Rear LCAs. May upgrade to Camber Plates for the front down the road too, if I can't get close to -2.0 degrees on the front. And my wheel setup is 16X7 Volk TE37s with 225/50/16 Hankook RS-3s. I geared my setup to STX Auto X more than looks.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 03-13-2014, 01:16 PM   #35
wparsons
wparsons's Avatar
If it's for auto x, why the sportlines? There are much better spring rate options out there. The RCE Tarmac springs would be a much better performing spring I would think.
flickr
Old 03-13-2014, 01:28 PM   #36
BRZZZZZZZZZZ
Car Nut
I got the springs for free, can't complain about that.
Old 03-13-2014, 01:35 PM   #37
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so just because something is free, you'll slap it on and put yourself in a class that requires so much more out of your prep?
take a few things off that list and you'll have a better time in stock (esp here in Ontario)
The Following User Says Thank You to 7thgear For This Useful Post:
krayzie (03-13-2014)
Old 03-13-2014, 01:59 PM   #38
BRZZZZZZZZZZ
Car Nut
My wheel and tire setup already takes me out of stock, so it doesn't really matter anyway. Most events here I have been to I have been in the top 5-10 in terms of raw time, STX is only because I planned to lower the car and ended up throwing a few more fun items in.
I don't have the time or money to compete in every event nor travel, my setup will be perfect for what I use my car for.
Old 03-13-2014, 02:10 PM   #39
krayzie
Drive From Home
krayzie's Avatar
Is it because the car will be harder to rotate with sportlines? I think the Eibach catalog even said they are just made for looks.
Old 03-13-2014, 02:12 PM   #40
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you can do +/- 1" diamater, your 16x7 wheels are fine
unless you went crazy on the offset
Old 03-13-2014, 02:32 PM   #41
BRZZZZZZZZZZ
Car Nut
Offset is more than 10mm difference that's why its out of stock.
To put it kindly, if I was serious about competing I would have spent 1/4 of the price on a NA or NB Miata that's not only cheaper to buy, but cheaper to modify.
Old 03-13-2014, 03:30 PM   #42
wparsons
wparsons's Avatar
Not enough bump travel left, and the spring rates aren't ideal for auto x.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Coilovers or Springs? Ymerej Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-10-2014 12:26 PM
OEM shocks with Eibach springs AB Canada Lawnik Brakes, Suspension, Chassis 3 05-03-2013 09:44 PM
Springs or coilovers. Itssrayyxd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 04-26-2013 08:32 AM
Coilovers and Springs available at OptionJDM in Canada OptionJDM Brakes, Suspension, Chassis 27 09-05-2012 10:41 AM
Coilovers vs Springs – What are coilovers and what’s better? phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-30-2012 12:24 AM
