View Poll Results: What is your preferred gasoline brand?
Shell 85 49.71%
Chevron / Texaco 30 17.54%
Exxon 4 2.34%
Mobil 6 3.51%
Valero 2 1.17%
Phillips 66 1 0.58%
Marathon 1 0.58%
BP 7 4.09%
Costco 6 3.51%
Hess 2 1.17%
Sunoco 9 5.26%
Other 18 10.53%
Voters: 171. You may not vote on this poll
Old 02-20-2014, 09:30 PM   #29
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Voted other. I get my gas from Speedway, don't know if they're owned by someone else on that list or not. I mostly go there because my dad has always had their rewards points card and started me on it basically since I've been driving. I know other places have rewards cards, but I'm too lazy to switch. Shell would be tempting if they weren't in places where gas is typically more expensive, plus their premium is .30 more than regular, while everywhere else is .20 more.
Nevermore is offline   Reply With Quote
Old 02-20-2014, 09:31 PM   #30
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by marcosowns View Post
No preference, all gasoline comes from the same place, excluding those mom and pop shops. Those can be questionable.
It might all come from the same place but what's important is how the brand treats it from there and the additives they use in it. Those factors can make a very big difference. I've seen multiple tests on cars where Shell V-Power gave the car several extra horsepower. The difference was more pronounced on turbocharged cars with smarter ECU's programmed to take advantage of better fuel. It also keeps the valves and everything cleaner which will extend the performance of the car. And in the case of cars with gasoline direct injection, it can extend the life of your catalytic converter.
So no, they are not all the same despite originating from the same source in many cases.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 02-21-2014, 08:42 AM   #31
marcosowns
marcosowns's Avatar
Drives: 2014 Lexus IS350
Well I never did same they were all the same, I merely said the same source...
marcosowns is offline   Reply With Quote
Old 02-21-2014, 09:20 AM   #32
hur1ey02
hur1ey02's Avatar
I use Valero almost exclusively, not because of preference but because that's where my fuel card is and they are plentiful in my area. I have an up hill, mountain drive to and from work (90+ miles rd trip). I'm averaging 32.5 to 33 MPG. (93 Octane rating)
That's enough for me The icing on the cake is that I do not have crickets.
Amanda - 2013 Scion FRS (Raven)
hur1ey02 is offline   Reply With Quote
Old 02-21-2014, 09:23 AM   #33
Turbowned
Turbowned's Avatar
I don't use anything other than Shell 93 unless it's an emergency.
Old 02-21-2014, 09:28 AM   #34
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
I voted other, since I get my gas at Kroger (supermarket). We almost always have 20-30 cents off a gallon so it's a nice incentive. From what I can tell it's actually Shell.
Their ethanol content must change however, because with some tanks I get bad crickets and some I have none...
GTHachiRoku is offline   Reply With Quote
Old 02-21-2014, 08:26 PM   #35
SilentAngel
Guest
Posts: n/a
I voted For shell since its what I'm using right now,but basically I'll use either shell or chevron.
Old 02-24-2014, 12:38 AM   #36
Fortis
Fortis's Avatar
Drives: 2014 FR-S AT Asphalt
I used to only put Shell or 76 in my cars but the last few tanks I've been getting Valero and my mpg seems to have gone up a tad.
Fortis is offline   Reply With Quote
Old 02-24-2014, 12:39 AM   #37
TOTO_86
TOTO_86's Avatar
Drives: Scion FR-S
I just pee in the gas tank...jk...lol. I use Chevron, but when I am on a budget I use Arco.
TOTO_86 is offline   Reply With Quote
Old 02-24-2014, 01:56 AM   #38
BanzaiZee
Street Ninja
BanzaiZee's Avatar
Drives: 2013 Whiteout FR-S
Originally Posted by Chen View Post
I wanna use shell. But money talks. So I use Costco.
I used to go to Costco all the time because it was cheap, then started using Shell because I SWEAR I felt like it drove smoother. But I also shop at QFC a ton, so I get "fuel points!" Saved $0.40/gal one day! : )
BanzaiZee is offline   Reply With Quote
Old 02-24-2014, 02:47 AM   #39
SP86
2S Crew
SP86's Avatar
Drives: a 2013 FR-S
I'm a part of the shell bunch as well. .
Good poll by the way. I thought about doing the same, much better then people asking over and over again what fuel to use. . this is the one place to check.
My 2013 FR-S
SP86 is offline   Reply With Quote
Old 02-24-2014, 04:04 PM   #40
Getagrip
Getagrip's Avatar
Drives: SWP BRZ
I go out of my way for a Shell station.
SWP BRZ
Getagrip is offline   Reply With Quote
Old 02-27-2014, 12:54 AM   #41
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
Shell 91 CA -__-
el-92 is offline   Reply With Quote
Best/Preferred gauges for monitoring. gdrider77 Forced Induction 84 11-24-2015 04:35 AM
Gasoline Brand Choice Poll brillo Scion FR-S / Toyota 86 GT86 General Forum 1 02-20-2014 10:58 AM
Gasoline Choices Lunatic Scion FR-S / Toyota 86 GT86 General Forum 22 02-04-2014 09:32 AM
Gasoline Direct Injection... DoogenBurns Engine, Exhaust, Transmission 5 05-21-2012 02:05 PM
