#29 |
Drives: 2014 Whiteout TRD FR-S 6MT
#30 | |
Drives: 2005 Toyota Camry
2) if you are spinning completely around (left turn drift, car rotates completely around), you are on the throttle too much and/or have understeer going in transitioning into snap oversteer. Learn to modulate throttle. 3) if you are spinning while transitioning left to right (and vice versa), but are otherwise okay with a single direction drift, you're on the gas way too early in a transition before the weight transfer is done. Work on weight transfer. Keep in mind that this car is a Torsen LSD... and as such, it's very much like a Viscous LSD in that it won't allow you to slide continuously without some effort (and skill) from the driver. -alex |
#31 |
Señor Member
Yes, I just learned last week that the car will not let you press the gas and brake simultaneously with out doing the pedal dance. It just cuts power to the engine
#32 | |
Left foot braking would be beneficial in this sense to figure out at what point the car's weight rotates over to start a drift. I always used this to do tight figure 8's in gymkhana and practice events, as a way of learning how little/much throttle to give the car to induce/maintain a slide. -alex |
#33 |
I think the general consensus is I need practice. Looks like ill be parking lot hunting tomorrow
#34 |
Drives: car
Speed, throttle control, timing, angle and weight shift. Be in a high gear (3rd-4) if you want to drift smoothly, lower gear (2nd) if you want to drift aggressively.
Enter the corner, turn away from the corner smoothly and briefly (also consider braking), apply throttle and turn into the corner and let the weight shift carry the back around and begin a slide with the throttle, lift when you're done sliding. |
#35 | |
WUB WUB
Drives: 2013 Firestorm
Sent from my VS840 4G using Tapatalk
#36 |
Lol Shelby cops SEEM to be more inclined to help out broke down people then hand out tickets. Cars only half legal right now, hence why I havent made it to a C&C lately, so we'll see. I might just garage it and work on stuff till next year. I just have a lotta time off coming up so im ancy to do something
#37 | |
WUB WUB
#38 | |
This is something I need to work on. BTW!!!! I appreciate all the positive reinforcement ive gotten. Kinda not used to that from other forum experience. Nice to be around a good group of people, no homo |
#39 |
The main thing you need to work on is CONSISTENCY. You can't figure out what you are doing wrong because you aren't able to do things consistently, and figure out why the car is over-rotating.
If you are having trouble with throttle modulation, you need to do one of two things: 1) enter with a higher speed, use less angle. Or, 2) learn to do smaller donuts/figure 8s with left foot braking. The left foot braking is NOT needed, however it's obvious you're not using throttle and weight transfer to your advantage. I honestly think you need to find a good safe area, set up two cones, and learn figure 8s around them. Something like this: [ame="https://www.youtube.com/watch?v=9Q7YKGz839Q"]Drift Practice S13 Figure 8 (7m distance) - YouTube[/ame] -alex |
#40 | |
#41 | |
Severed Member
Drives: Argento 2013 Scion FR-S Manual
87 Volvo 760 Turbo <3
02 WRX THE QUEEN IS DEAD, LONG LIVE THE QUEEN! 06 Xfire Bite me I liked it 13 FRS doriftoooo! DON'T PANIC |
#42 |
Drives: Subaru BRZ Sport Tech Satin White
Paradoxically, the engine has too little torque to drift this car easily.
The chassis is set up to drift easily, comparatively speaking. On snow or ice this is an evil set up. If you get any snow or ice, or perhaps even very cold wet pavement you will find it much easier to practice this skill. Initiating the drift isn't very difficult, as you have discovered. Maintaining the drift is trickier than it looks on TV. You can't really learn this from a description, any more than you can learn to ride a bike from a book. The only way to learn this technique is to practice in a safe area. A lot. I mean practice a lot, on a lot. Parking lot. Do not practice this anywhere you might slide into a curb or depression in the road. You don't want to flip the car or bend the suspension. Try to practice when it is cold out, less grip makes it easier to sustain the slide. Wet and cold is better as long as you don't have too many puddles. Hit a puddle during a slide and you may need clean underwear. Snow or ice are ideal as long as you have at least all season tires. Summer tires are too slippery in the cold. The learning curve on ice or snow is very steep, prepare to spin out a lot. Have plenty of room for uncontrolled slides before you reach anything solid. |
