Old 07-12-2014, 07:05 PM   #29
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
Originally Posted by feldy View Post
The coils are going bad due to heat. I was able to replicate my coil issue with the stock tune as well as my tune tune. Get the engine nice and hot and it will do it for you.
I ignored the code for a long while and now I'm not getting any CEL's but the car is mis-firing (no backfire or firecrackers or popping just that stuttering) and a lot of hesitation as if im not accelerating and there is no power to the engine, could this still be an ignition coil issue?
Yamajee is offline   Reply With Quote
Old 07-17-2014, 10:48 PM   #30
Pabloc
Drives: BRZ Ltd WRB, MT6; '91 M5; '89 911
Had a couple episodes of CEL P0351. Took the car to the dealer. Dealer says that it isn't likely the coil, but they want to drive the car and test it to see if a "pin" in the harness is causing the problem.
Anyone know what they are talking' about?
Does this make sense?
Dealer claims they called the Subaru national hotline, or whatever it is.
Thanks
Pabloc is offline   Reply With Quote
Old 07-18-2014, 09:59 PM   #31
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Are there proven aftermarket coils yet? Or have the new factory coils been improved on from 2012 build dates?
Gords_zenith is offline   Reply With Quote
Old 07-18-2014, 10:15 PM   #32
steve99
dont know how proven they are but freakin expensive
http://www.brz-parts.com/pd4004901r.html
http://www.maperformance.com/cusco-d...cion-fr-s.html
If it heat you reckon is killing them might be worth investigating ceramic coating/wrapping headers or extra ventilation
Old 07-18-2014, 10:40 PM   #33
Gords_zenith
Wow, that is pricy!
I was thinking if I increased ventilation that should be sufficient, but hard to say if it would solve it completely as I'm still stock.
Thanks though. Maybe the stock ones have an improved insulation.
Old 08-16-2014, 04:44 PM   #34
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
I have this issue today at the track, it's 97 degrees outside and I am running an E85 tune. Popped up (0351) in session 3 but there was no other symptoms other than the cel. I shut the car down, cleared the code then 2 hours later it came back in session 4. again I cut the session short and decided I would check here to see if this is a common problem.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 11-10-2014, 12:44 PM   #35
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
This is the second time since i got the car that i have gotten this code.
i have 30,000 KM on the car.
Hopefully they change the coils
AZOOZ_95 is offline   Reply With Quote
Old 11-10-2014, 10:07 PM   #36
jk86freek
jk86freek's Avatar
Drives: fr-s
Originally Posted by Bahraini86 View Post
So, this is how it went:
Drove the car on stock tune for a while to make sure the "injector seal" is fine and the fire cracking sound is gone. Car was smooth.
I still haven't confirmed whether the P0351 code is solved or not, so I flashed the car back to stg 2 and went to reproduce the code under the conditions mentioned earlier in the post and as I suspected, the CEL came back on with the same code.
To make sure whether it was a tune related issue or a mechanical, I flashed back to STG 1 and took her for a test. The CEL came back on to confirm that it was a mechanical issue.
Took the car to the dealer and they confirmed it was a faulty coil. They had it replaced and the code became history. They replaced Cylinder 1 coil. Tried to reproduce the code and thankfully I failed. I guess the car is fixed now and the issue been solved.
hi Bahraini86
I'm using Open flash Tablet tune my fr-s, stg1, i have the same problem with P0351, what do you suggest i must do??? change coil and change the di seals??? do both?? or just flash it back to original ?
Please give me your advice.
Thank you!1
jk86freek is offline   Reply With Quote
Old 12-27-2014, 03:48 PM   #37
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Reviving an old thread but I have P0351 P0301 and P0172 codes im boosted and already had coil pack one replaced. Gonna take apart the motor to see what the issue is.
Darryljr11 is offline   Reply With Quote
Old 12-29-2014, 11:44 AM   #38
mx5 2nr
Drives: FRS/NA1/'12 Mustang/'97 4Runner
Got the 0351 code a few times, but it seems to go away on it's own within a day or so. It always seems to happen when I'm accelerating hard and in the far upper range on the tach.
For those that have replaced coil #1, has the fix held up? I'd like to take it to the dealer, but the CEL seems to disappear every time I plan to go.
'90 Miata - weekends
'13 FRS - weekdays
'97 4-Runner - grunt work
'12 Mustang - wife's
mx5 2nr is offline   Reply With Quote
Old 12-29-2014, 12:39 PM   #39
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Even if the CEL has gone off the code and when it occurred will be in the memory and accessible by my the dealer.
My CEL came and went a few times with this code and dealer replaced under warranty after checking the diagnostics.
nzer is offline   Reply With Quote
Old 01-02-2015, 04:05 PM   #40
mx5 2nr
Thanks for reaffirming exactly what I thought to be true. I've moved from where I originally purchased/serviced my car & the new dealer's service rep said that "if the CEL is not on, I won't know what it's for".
'13 FRS - weekdays
Old 01-02-2015, 04:31 PM   #41
stevemp5
Drives: scion fr-s
[IMG][/IMG]
thermal tape help me! no code yet
stevemp5 is offline   Reply With Quote
Old 05-27-2015, 02:36 PM   #42
sickmint79
Drives: bmw
cylinder 1, i got this part done but not sure how to undo all them wiring harness guys and get to the old one. this step only required my core skills, sticker application.
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 04:05 PM
U0115 OBD trouble code vtmike Issues | Warranty | Recalls / TSB 4 08-31-2013 01:24 PM
First Time Out Shooting Forgetful FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 07-23-2013 11:12 AM
86 shooting brake Freeman Scion FR-S / Toyota 86 GT86 General Forum 44 12-07-2012 08:27 PM
trouble shooting tim saylor Other Vehicles & General Automotive Discussions 0 07-01-2012 01:04 PM
