#29 | |
Drives: 450 awhp twin turbo vr4
hydrolock |
#30 | |
Drives: FR-S 6MT
You seem to be referring to motorcycle engines.. Two stroke maybe with a sealed crankcase.. Fluid in the intake will hydro lock under cyl compression.. But from the underside? Thru the rings? When crankcase pressure have paths out... I'm not buying it.. |
#31 | |
Drives: 2013 GBS BRZ Limited
Boxer engines are notorious for doing this after sitting long periods. I have no idea how much you would have to over-fill the FA20 to have this problem, but race engines with accusumps can have this issue if you forget to close the valve before shutting off the engine. Not science fiction.... |
| The Following User Says Thank You to stugray For This Useful Post: | Whitigir (12-01-2013) |
#32 |
Drives: 2013 scion firestorm frs
#33 |
#34 |
Drives: Subaru BRZ Sport Tech Satin White
What do you want me to research?
A windage tray is a piece of, usually, sheet metal installed, usually, just above the max level of the oil. It is designed to slow the movement of oil under g force. It cannot stop the movement of oil, obviously. If the sump is overfilled the oil level will be above any windage tray. In most engines excess oil level leads to crank thrash and consequent foaming. On flat engines if the oil level is much too high it can actually hinder the piston movement with disastrous consequences. Too much oil is far worse than running an engine at the MIN mark. |
| The Following User Says Thank You to Suberman For This Useful Post: | Whitigir (12-01-2013) |
#35 |
Agreed.
Not sure what alex 86 meant by his comment. |
#36 | |
Drives: 2013 red FR-S, OFT. 2000 Miata SE
Sucking water through the intake can hydro lock both 2 and 4 cycle engines, as well as a bad head gasket where water from the water jacket gets into the cylinder. John |
#37 | |
Intake is carefully located for this reason. Some aftermarket cold sir intakes for some cars fail to do this and engines have been ruined. If you have an offroader and intend to ford anything deep or at speed you must use an intake snorkel. Do NOT run your engine with too much oil in the sump. Any engine but particularly a boxer. |
#38 |
Thank you suberman for further professional inputs about this.
#39 | |
I used to race 1/8 scale offroad radio controlled cars, that used 2-stroke nitro powered engines.
These would easily hydrolock when over primed. We'd use a little pressure to get fuel into the engines to prime them, but if too much fuel got into the engine they'd hydrolock when we tried to start them. When I ran large scale RC boats, they'd hydrolock when they flipped and got water in the engines if we didn't remove the plugs and get the water out of the engines. I would say though that the chance of a 4-stroke engine hydrolocking from being overfilled is fairly remote. Yes, oil can get in through bad rings, or valveguides, or water from a blown head gasket, but normally, overfilling the engine with motor oil causes it's own bunch of problems, like whipped oil and blown seals. Quote:
#40 | |
EVERY time you start a boxer you are dealing with the extra oil that leaks past the rings..... |
#41 |
Good to know.
Needless to say, I won't ever allow my engine to be overfilled again. I'll be doing my own changes from now on. |
#42 |
| Engine swap JDM EJ25 STI engine | FRSToyota86 | Engine Swaps | 25 | 11-20-2013 02:56 AM |
| FINALLY engine is broken in...engine/tranny smell? | denverizzles | Engine, Exhaust, Transmission | 18 | 09-15-2013 09:12 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 07:50 AM |
| dealership 4 hours away, bad for engine break in? | Mykflo | BRZ First-Gen (2012+) — General Topics | 27 | 05-23-2012 08:57 PM |
| got the last one at mt dealership! | Mtc46jw | CANADA | 2 | 05-12-2012 10:26 PM |
