Old 04-07-2012, 11:48 AM   #29
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I'm not so sure. Hopefully a reviewer will dredge up a stock S2K to put against the BRZ. I think they'll be very close.
Old 04-07-2012, 12:00 PM   #30
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
What makes you think it'll be close? So far Zdan is 100% correct.
SUB-FT86 is offline   Reply With Quote
Old 04-07-2012, 12:05 PM   #31
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by ZDan View Post
I don't know what the S2000 c.g. height is, but I doubt it's much (if any) higher.
S2k's CoG is estimated around 18.8~19.8. FRS/BRZ claims 460mm (18.1"?), so about inch or 2 higher for S2k.
Old 04-07-2012, 12:11 PM   #32
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
No clue which would be faster. You can't really compare them stock for stock. The ap1 has even worse stock tires and is heavier.
blu_ is offline   Reply With Quote
Old 04-07-2012, 12:13 PM   #33
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
i'm very interested to see how it compares to my MR2...
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 04-07-2012, 12:14 PM   #34
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
with some considerable seat time in the AP1 S2k i wouldn't dare talk about performance vs performance factor against the Zx6. The AP1 has considerable advantage on a cumulative scale.
Despite that, the BRZ still has something unique to its character that makes me overall always choose the Zx6 over purchasing a s2000. They explain it pretty well in that article above, even if they omit more reasonable technical jargon.
While I have yet to drive the current MX-5 and BRZ and i have only a few hours of real seat time in a Z34 370z. I can pretty much gauge what kind of driving experience ill have with the BRZ, and its looking very positive.
WingsofWar is offline   Reply With Quote
Old 04-07-2012, 12:14 PM   #35
SUB-FT86
86 Member
The ap2 is heavier at 2800+ lbs. The ap1 is 2750 lbs.
Old 04-07-2012, 12:17 PM   #36
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
You sure? I thought both were over 2800.
Old 04-07-2012, 12:21 PM   #37
ichitaka05
Site Moderator
ichitaka05's Avatar
Yes, you're correct both AP1 & AP2 is over 2800 lbs
Old 04-07-2012, 12:22 PM   #38
ZDan
ZDan's Avatar
Drives: '23 BRZ
*Estimated*
*Claims*
Not necessarily...
In any case, with a driver and fuel the FR-S/BRZ is going to be carrying 8% more weight on the fronts than the rears, whereas the S2000 will actually have ~2% more weight on the rears than fronts.
Even if the FR-S/BRZ c.g. is 1"-2" lower, I bet it is putting more load on the outside front while cornering (of course spring and sway bar rates play heavily in this).
Old 04-07-2012, 12:24 PM   #39
ZDan
ZDan's Avatar
Drives: '23 BRZ
My '01 is bone stock except for a 40 lb. roll bar. Weighed in at 2780 lb. at the track with ~1/8 tank of fuel (~10 lb.).
Pretty sure the early AP1s are closer to 2750 lb. and the AP2+ are ~2850 lb.
Old 04-07-2012, 12:26 PM   #40
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Subaru is known for saving weight, mainly because there drivetrain is so heavy because of awd. The body panels are so thin on my car the hood quivers on the highway.
Old 04-07-2012, 12:31 PM   #41
ichitaka05
Site Moderator
ichitaka05's Avatar
*Estimated*
Unless you can prove it wrong, my statement to be true
*Claims*
Yes, which they have posted/stated several official papers, so I'll take that as official #.
Not necessarily...
I'll wait for your proof... til then it's your estimation
*pretty sure* isn't a proof. Also show your S2k's curb weight doesn't mean anything. Dry weight, +-2700lbs for S2k is understandable
Old 04-07-2012, 12:31 PM   #42
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Curb weight includes a full tank of gas. Which weights 8lbs per gallon.
Nissan 370Z thread S2KtoFT86 Other Vehicles & General Automotive Discussions 116 04-07-2017 10:40 PM
FR-S vs. 370z, end all be all of discussions OldSkoolToys FR-S / BRZ vs.... 1491 09-25-2012 06:58 PM
BRZ vs 370z Video carbonBLUE FR-S / BRZ vs.... 48 04-17-2012 12:31 AM
FT 86 & 370Z similarities blur FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 10-05-2010 12:39 AM
